Boxford Model B
Boxford Model B
Home › Forums › General Questions › Boxford Model B
  • #338660
    Mike Wainwright
      @mikewainwright87512
      I am about to buy a Boxford Model B lathe and I am trying to find a manual / parts list for the lathe.
      it is going to need a strip down and clean.
      it does not come with any change gears so I am trying to find out what changes wild have come with the lathe so i can get a full set.
      Any help or information would be appreciated.
      #25781
      Mike Wainwright
        parts list
        #338668
        John Haine
          @johnhaine32865
          #338669
          Martin 100
            @martin100
            Boxfords Spares Website (ignore the prices they are long out of date)
            Plus loads of info in the files section of the Boxford Lathe group hosted on yahoo
            Edited By Martin 100 on 28/01/2018 13:02:24
            #338670
            Hopper
              @hopper
              As the Boxford is a clone of the US South Bend, you should get some good info from the Yahoo Group for Southbend and clones **LINK**     Have a look in their "Files" section.
              Also, the Practical Machinist forum has a very active section on South Bends. Here **LINK**
              I'm sure UK members will chime in with more Boxford-specific sources.
              Edited By Hopper on 28/01/2018 13:03:04
              #338681
              Martin 100
                @martin100
                The Boxford at first sight appears a clone of the Southbend at least for the saddle, apron and quick change gearbox. The design diverges for the headstock and the spindle, the thread on the nose being 55 deg on Boxfords and 60 deg on Southbends, one UK based supplier of nose fitting ER collet chucks didn't even acknowledge the difference.
                Lots of other detail differences with the crossfeed and top slide dials too (at least two Boxford designs and possibly three)
                #338687
                Mike Wainwright
                  Thanks for the information. I will get the manuals from the lathes web site once the lathe has arrived and I know the information that I need.
                  I have joined the yahoo user group for both.
                  #338691
                  Bazyle
                    @bazyle
                    On the apron there is a star wheel. The screw in the middle of this has a thread opposite normal so undo it the other way to avoid breaking it. Have fun getting the clutch back together.
                    There is a grub screw on the side of the apron that holds the half nut lever I think it is that has a second grub screw deep down the hole.
                    The shoe that runs in a groove in the bull wheel to engage back gear probably needs renewing – just file it up from brass bar no need to buy one.
                    Is it a B or a BUD?
                    #338713
                    Martin 100
                      @martin100
                      Posted by Mike Wainwright on 28/01/2018 14:09:55:
                      Stand to be corrected but there should be nothing literature wise you need for a strip and basic rebuild that isn't available for free from the yahoo group.
                      There are also scanned copies of the Boxford 'Know Your Lathe' manual floating around online maybe on the yahoo group, with chancers selling bound scans for silly money on ebay
                      I think the last Boxford reprint would be in the 1980's and its long been out of print.
                      Alternatively the genuine thing should be here 2nd hand for about 20 quid delivered
                      https://www.abebooks.co.uk/servlet/SearchResults?kn=boxford&sortby=17&tn=know+your+lathe
                      Edited By Martin 100 on 28/01/2018 16:59:47
                      #338717
                      Oldiron
                        @oldiron
                        Mike check your inbox.
                        #338722
                        Mike Wainwright
                          Bazyle
                          its a model B
                          old Iron
                          Thanks for the files. That the information I was looking for.
                          Once the lathe arriving I will post pictures and maybe asking some questions if I can't figure out what I need to do.
                          #800207
                          memphis
                            @memphis
                            Hi Mike
                            Did you have any luck finding a manual for the Boxford Model B as I have this model and have problems with the cross slider and could do with a manual before dismantling
                            #801355
                            Gavlar
                              @gavlar
                              The manual is called ‘know your lathe’ and is available as a free download. A copy is on the facebook Boxford user group, also here;  https://groups.io/g/BoxfordLathe-UserGroup. Both groups are free to join. If you don’t want to join either of them, message me your email and I’ll send you the PDF.
                              #801394
                              Speedy Builder5
                                @speedybuilder5
                                Most important – the screw holding the “STAR” wheel on is left hand thread !  Otherwise strip down is pretty simple.
                                Bob
