Boxford model a cross slide
Home Forums Help and Assistance! (Offered or Wanted) Boxford model a cross slide
  • #317128
    kevin large
      @kevinlarge76611
      I’ve been searching for a while for a cross slide with t slots to no avail can the myford be adapted
      kevin large
        @kevinlarge76611
        #317130
        Nick_G
          @nick_g
          This is one of the things I wish my Boxford had.
          I have considered drilling and tapping my cross slide to take something like this **LINK** that could easily be removed when not required for 'line boring' and such.
          Nick
          #317140
          Old Elan
            @oldelan
            Have you tried John Ward?
            http://www.latheparts.co.uk/
            #317141
            Yngvar F
              @yngvarf
              Or if you want to machine it yourself
              Clive Brown 1
                @clivebrown1
                Boxford spares list a Tee-slotted cross-slide, part no. 3656-6A @ £100.22. , +VAT presumably.
                I think that's for the older models, ie A, B, C etc.
                #317151
                kevin large
                  @kevinlarge76611
                  Checked with boxford no longer available
                  #317152
                  Robbo
                    @robbo
                    Tony Griffiths at **LINK** has boxford T-slotted cross-slides but at an eye-watering £200 +.
                    For perspective, there was one on ebay recently which I think went for £130
                    Edited By Robbo on 15/09/2017 13:52:26
                    #317154
                    Nick_G
                      @nick_g
                      Posted by Robbo on 15/09/2017 13:50:19:
                      I am not for one second implying that £200 ish is not a lot of money for an item that has a feature that may only be seldom used for it's T slot capability.
                      But if one considers the material cost and the amount of machining required to produce the item to a satisfactory standard it's actually not a bad price for a new one.
                      Maybe a nasty pill to swallow though.
                      Nick
                      #317159
                      mark smith 20
                        @marksmith20
                        On my south bend i turned some dovetailed round spigots to enable you to fix things directly to the existing cross slide with the top slide removed of course. Certainly a lot cheaper option that can be done easily.
                        Similar is detailed here,the way of fixing the spigot to whatever plate or solid boring bar holder is up to you.
                        Edited By mark smith 20 on 15/09/2017 14:20:35
                        Edited By mark smith 20 on 15/09/2017 14:20:59
                        #317169
                        John Hinkley
                          @johnhinkley26699
                          Kevin,
                          You may like to consider whether you need a new cross slide at all. I contemplated a similar modification to my Asian 9 x 20 lathe some while ago. Even purchased a secondhand Myford cross slide in preparation for it. I got a fair bit through the mods when I sat back and re-appraised the situation. Comparing the two cross slides, I realised that there was so little difference in the overall dimensions, that I could probably, quite safely, mill some tee slots in the original cross slide, thus avoiding much butchery of the topslide. Long story short, I did ( with much trepidation, mind you ) and the end result I find entirely satisfactory. Obviously, your cross slide may not be up to it, though I very much doubt that. Only you can decide. I am not familiar with the Boxford, though I suspect, if you are contemplating a Myford part to replace the existing one, it must be of similar size. Good luck. Here's a couple of photos to give you some idea of how it turned out – from my album ( Cross slide Modifications )
                          Before:
                          Asian original cross slide
                          and after:
                          With the topslide re-fitted
                          Best of luck,
                          Robin King
                            @robinking15611
                            FWIW John Ward has quoted me £100 + postage for a T slot cross slide for my Boxford 'A' , today.
