Boxford Industrial 11.30 lathe
Home Forums Workshop Tools and Tooling Boxford Industrial 11.30 lathe
  • #299736
    damian
      @damiannoble34800
      Hi all
      A little help required.
      Does anyone have a manual for one of these?
      Also is there an eye bolt in the bed for lifting it and what thread size is it?
      Thanks
      Damian
      #18528
      damian
        @damiannoble34800
        #299749
        Tractor man
          @tractorman
          I have a Boxford X10 lathe and I’ll have a look at the manual to see if it covers the 11 30.
          Do you need anything specific. Mick
          #299750
          damian
            @damiannoble34800
            That would be great thanks.
            It is essentially an x10 lathe and any manual is better than nothing.
            Cheers Mick
            #299751
            JohnF
              @johnf59703
              Hi Damien, Yes I have an 11-30, don't recall there being a lifting eye bolt hole but will have a look over the W/End, we used slings and a tractor to move it. I am pretty sure we have manual but it need to be scaned so PM me with your email and I will try and do it for you or maybe a photo copy. Mine is metric.
              Edited By JohnF on 26/05/2017 22:58:26
              #299754
              David Standing 1
                @davidstanding1
                The X10 manual is available from Boxford. http://www.boxford.co.uk
                There is a lifting eye tapped hole in the bed cross bracing nearest to the chuck, and it is threaded M16x 2. You can alternatively lift it by putting a sling round this bracing (fore and aft through the bed, NOT round it).
                #299796
                damian
                  @damiannoble34800
                  Morning all,
                  I have had two people say there is a tapped hole for an M16 eye bolt. I have one of these (correct one rated at 0.8T).
                  Many thanks for the help
                  Damian
