Boxford 280 info
Boxford 280 info
Home › Forums › General Questions › Boxford 280 info
  • #617892
    Ian McVickers
      @ianmcvickers56553
      I am waiting on delivery of a Boxford 280 lathe which hopefully arrives on Friday. Been trying to find a manual for it, Boxford dont have any and I dont fancy paying £60 for one. Does anyone know the lifting arrangements for it?
      #28882
      Ian McVickers
        @ianmcvickers56553
        #617895
        Richard Millington
          @richardmillington63972
          PM me your email address and I'll send you a pdf of the manual.
          It has lifting details in it.
          #617898
          not done it yet
            @notdoneityet
            IF it is the same of nearly the same as an 11-30, l know of a fellow who might send you a copy, if he still has it – it was 5 years ago…
            #617902
            davidk
              @davidk
              Hi Ian,
              From the Boxford manual:
              To lift the lathe, there is an M16 x 2mm pitch tapped hole in the bed cross bracing, near the spindle nose. This is designed to take what the manual calls a "Dynamo-Type Eye Bolt".
              The position of the carriage when lifting depends on the length of the bed. For 20" centres machines, the carriage should be to the right of the eye bolt, and for 30" centres machines, the carriage should be to the left of the eye bolt.
              Hope this helps
              David
              #617951
              Ian McVickers
                @ianmcvickers56553
                Sorted now. Thanks very much.
