Boring head then fly cutting – OK or naughty step
Home › Forums › Beginners questions › Boring head then fly cutting – OK or naughty step
  • #8691
    Keith Matheson
      @keithmatheson47708
      #295663
      Keith Matheson
        @keithmatheson47708
        Hi
        Another question that may seem a bit daft to some but having just done it I now need to know if it's 'acceptable' practice.
        I was boring a hole about 50 MM in a piece of aluminium with a boring head and a cutting tool with an insert. After I had finished cutting the hole to the correct size I thought how much simpler it would be to just wind the cutting tool out a big more and then Just lightly fly cut the top surface ( the flat surface looked like it had been drawn so needed a 'tickle'. Happy with the surface finish. ( it's for a motorcycle fork brace as it happens)
        Is this an acceptable short cut or do I need to be sent to the naughty step for miss using my tools. I await all your words of wisdom.
        Regards keith MM in SE London
        #295668
        Martin Connelly
          @martinconnelly55370
          It is said that the proof of the pudding is in the eating. If you have an acceptable result it falls under the "more than one way to skin a cat" category.
          Martin C
          #295681
          Maurice Cox 1
            @mauricecox1
            Can't see a problem with it. I have gone one stage further on my home made boring head, having fitted a self feed star wheel to the adjusting knob. It enabled be to bore the trunk guide on a Stuart engine, the face the target end to take the cylinder, all at one setting.
            Maurice
            #295683
            Maurice Cox 1
              @mauricecox1
              Should read "then face". Sorry
              Maurice
              #295820
              OuBallie
                @ouballie
                Maurice,
                Sounds similar in concept to the design featured in ME or MEW moons ago.
                Have you used a round bar secured to the mill/drill that makes contact with the star wheel at each revolution?
                Geoff – About to start repairing the Austin's front Mud Wings, then onto the main body at last.
                #295864
                Nick Hulme
                  @nickhulme30114
                  Given that boring and facing heads are boring heads with some bells and whistles I can't see any reason not to use a boring head for facing
                  – Nick
