Blown Fuse
Blown Fuse
Home Forums General Questions Blown Fuse
Viewing 25 posts - 1 through 25 (of 31 total)
  • #26770
    KEITH BEAUMONT
      @keithbeaumont45476
      KEITH BEAUMONT
        @keithbeaumont45476
        I would appreciate peoples opinions and possible explanation of the following.
        This afternoon ,machining the aluminium prop driver for a model aero engine I am making, taking a final light facing cut, 400rpm,slow hand feed, there was a sudden loud bang and a flash of flame at the tool point and everything stopped. I checked the lathe fuse and it had blown. Replaced it with new one and all started working I then switched everything off, took the cover off the electronics,suspecting a stray piece of swarf had shorted something, but all looked clean with no smell of burning, so I put it all back together and continued where I had left off.
        I am completely mystified. The tool was a brand new,shiny tip for ali. cut was about 3 thou, slow feed and was about half way to the centre of 3/4"dia H 15 aluminium, so friction was minimal.
        Keith
        #423816
        Phil Whitley
          @philwhitley94135
          Hi Keith, this sounds a bit dodgy, and tbh almost like a lightning surge, as there should be no potential difference between the work and the tool point! Check the earthing on the lathe, and also check the earthing to your workshop and your house, or wherever the lathe is fed from. I suppose it could be a static discharge, but very unlikely, and impossible if the lathe and the installation is correctly earthed. Get it checked to be on the safe side!!
          Phil
          #423821
          KEITH BEAUMONT
            @keithbeaumont45476
            Thanks for that Phil, I will certainly get things checked out,as you suggest. The bang was very loud and the lacy swarf at the tool tip burned. It was not a "pop" that you get when a fuse blows. The failed fuse did not show visual signs of burning out..
            Keith.
            #423833
            Emgee
              @emgee
              Posted by KEITH BEAUMONT on 12/08/2019 21:18:54:
              Keith.
              What type and rating of fuse are you using ?
              Emgee
              #423837
              Farmboy
                @farmboy
                As Phil says, it should be almost impossible for there to be a potential difference between tool and work . . . unless there was, say, a plastic sleeve protecting the workpiece from damage in the chuck jaws dont know Even then the tool should conduct any charge away from the workpiece while it is cutting.
                The metal-to-metal contact between component parts of the machine, including the bearings, should equalise any static charge build up. I'm not sure any sort of static charge would blow the mains fuse anyway as there should be no connection between that and the machine chassis. The fuse 'blows' when it passes excessive current in the live supply lead.
                Very strange . . . can we asume you don't have a modern consumer unit with MCBs etc? If you did, surely this would have tripped out if there was a short-circuit anywhere in the power supply.
                Just some random thoughts to throw in the mix . . .
                #423867
                Brian Wood
                  @brianwood45127
                  Here is a radical and perhaps fanciful suggestion,
                  The aluminium being machined was from a faulty batch having alloying elements like magnesium or titanium included that had not integrated properly and Keith's tool tip ran into just such a piece of segregated material.
                  I am unable to think of any electrical cause for what happened that would manifest itself as a one off in this way.
                  One thing he hasn't described was what did the discharge, to give it a name, do to the tool tip and workpiece, other than he carried on with a new fuse in place.
                  Certainly very curious.
                  #423881
                  KEITH BEAUMONT
                    @keithbeaumont45476
                    I have this morning, checked the earthing of the lathe by connecting the earth on the 13 amp plug to every bare metal part of the lathe I can see and getting a positive ring on my meter.. I also have one of those plugs for checking correct earth on 13 amp ring main sockets and all sockets in the workshop and house are correct.
                    Emgee,The lathe fuse is 6.3 amp HRC, 20MM cartridge.
                    Farmboy, I do not have a consumer unit . Still with original fuse box.
                    Brian, The discharge did not damage the tool or the workpiece,other than to ignite the swarf on the tool. Would your suggested mix up with the metal cause the fuse to blow?
                    Keith.
                    #423895
                      Hard to imagine how the tool and work on a lathe could be at a different potential but that seems to be what happened.
                      If you have a multimeter check for electrical continuity between all the metal parts of the lathe back to the earth pin on the plug. Everything should be the same low resistance to earth.
                      Older lathes may rely entirely on being bolted together to provide an electrical earth and perhaps over time corrosion or oil somehow formed an insulating layer. Modern lathes are explicitly earthed. All the main parts of my Chinese lathe are interconnected with earth wires BUT these could conceivably come loose or be broken. So in both old and new lathes it's possible one part of the lathe might get to float electrically above above the rest. Very unlikely I would think, but not impossible.
                      Another thing to check is where the unwanted power came from. Natural to assume it came out of the wall-socket in the normal way and the blown fuse suggests that's the case, but worth making sure nothing else in the workshop could have earthed itself via the lathe. Not, for example, a good idea to earth a welder via the body of a machine tool!
                      If the phenomenon was caused by lightning, a power surge, or a neutral or earth fault on the supply side you were lucky the electronics survived!
                      I quite like the swarf inside theory combined with an earth fault. If a bit of swarf shorted out the mains input to the headstock ( and disappeared in the process), AND the headstock ISN'T properly electrically bonded to the bed, AND the bed IS correctly earthed then a blue flash at the tool would be possible.
                      Very odd though.
                      PS I see Keith did a multimeter test while I was dithering.   To prove my theory, he should have found differences.  Ho hum , wrong again…
                      Edited By SillyOldDuffer on 13/08/2019 10:45:14
                      #423899
                      Andy Carruthers
                        @andycarruthers33275
                        Is it possible the flash when viewed was behind the tool ie within the motor casing which from the viewing angle gave the impression of being at the tool tip?
                        An arc sufficient to blow the fuse should have left some mark on the tool tip and work item
                        #423902
                        Dave Halford
                          @davehalford22513
                          It is entirely possible for a fuse to fail due to mechanical reasons when no electrical fault is present.
                          I have had a spark fly past the motor pulley on my rear drive Rockwell 10" bench lathe during a stall, the tip was also chipped. Motor? Nope, that is a sealed externally cooled one. Turned out to be an errant out of view QCTH jamming the vari drive pulley and also producing the spark.
                          This in the OP The tool was a brand new,shiny tip for ali. sounds like a carbide tip, which 99% of the time will chip or flake if the drive stalls.
                          #423904
                          Cornish Jack
                            @cornishjack
                            Totally unqualified musing – was the material aluminium? … Might there have been a magnesium/mag alloy inclusion which heated to explosion point (hence the flash and burned swarf) and a concurrent electric surge to blow the fuse?
                            retires to comfortable ignorancesad
                            rgds
                            Bill
                            #423933
                            KEITH BEAUMONT
                              @keithbeaumont45476
                              I have had a second look at the electronics board and it is perfectly clean with no sign of any over heating. The flash and explosion,for that is what it was, was definitely at the tool tip, hence the burning swarf. The bang was so violent that I was still feeling the effect over an hour later.
                              The loading could not have been lighter and still be cutting.Low feed,fine cut and new tool tip rule out any chance of overload, surely. Everything is working perfectly at the moment, but I will admit to being somewhat apprehensive. I have now started to make the crankshaft, with high tensile steel, so hope I do not get a repeat.
                              We clearly have a mystery here and I thank you all for your input.
                              Keith
                              #423935
                              Speedy Builder5
                                @speedybuilder5
                                I don't suppose you are machining magnesium alloy, although that has NOTHING to do with the fuse blowing.
                                Whoops !  Just seen Cornish Jack's post
                                Edited By Speedy Builder5 on 13/08/2019 14:01:35
                                #423937
                                Mike Poole
                                  @mikepoole82104
                                  My audio amplifier gave a loud bang and cloud of smoke, after a good look round I could see no problem and powered it up and it worked perfectly. After a second coat of looking at I found the capacitor across the mains switch had failed, apart from the ear splitting bang and smoke the only physical damage to the cap was a hard to see split. It might be worth a very close look at things as not everything fails with dramatic burn marks and catastrophic physical damage.
                                  #423950
                                  Farmboy
                                    @farmboy
                                    Just a further thought, pursuing the lightning theory: is the workshop supplied by an overhead power cable? Or is there anything else that might act as a lightning conductor in the vicinity of the lathe? Having asked that I'm thinking you should have felt something if it was a bolt of lightning while you were hand feeding!
                                    Reading the original post again, and some of the answers, I'm more incliined to wonder if there might have been some sort of inclusion in the aluminium which caused a spark. I seem to remember reading that fine aluminium swarf/dust can ignite violently when suspended in air, although I have no experience of it. I still can't think of a connection between either event and the fuse blowing though . . .
                                    #424015
                                      Interested to see if this can be solved.
                                      If the swarf burned, it isn't aluminium, it's probably a magnesium alloy.
                                      If you were hand feeding is it possible that you were taking an over heavy cut and the shock of seeing the pop made you jump, advancing the tool and stalling the lathe?
                                      Farmboy
                                        @farmboy
                                        Finally found a reference here to prove my memory still hasn't completely failed regarding aluminium burning.
                                        It clearly requires a particular set of circumstances, but I would suggest it is a possibility.
                                        I would be really interested to find out exactly what did happen.
                                        Edited By Farmboy on 13/08/2019 23:02:18
                                        #424053
                                        roy entwistle
                                          @royentwistle24699
                                          I have had aluminium burn on the lathe ( it was very thin like spiders web ) Aluminium again like a web was included with magnesium in photographic flash bulbs
                                          Roy
                                          #424058
                                          David George 1
                                            @davidgeorge1
                                            We had a new cleaner at work and he decided to burn some papers in a skip which had aluminium swarf in and the aluminium caught fire. The fire brigade could not use water to put out the fire with a hose as water reacts with the aluminium fire and produces oxygen they covered the skip with fire blankets and cooled the outside of the skip and building nearby.
                                            David
                                            #424066
                                            KEITH BEAUMONT
                                              @keithbeaumont45476
                                              If it was caused by  something with the H15 aluminium, would that have created a situation that blew the fuse also? The lathe has an overload trip and on the few occasions when I have stalled it for some reason,the overload device has tripped out. I have not had reason to change the fuse for many years. So far as the event is concerned, I remember the flash of flame to be yellow and the burning of the lacy swarf to be almost instantaneous.
                                              Keith
                                              Edited By KEITH BEAUMONT on 14/08/2019 09:32:52
                                              #424075
                                                The fuse blowing surely indicates the cause was electrical. Inclusions in Aluminium alloy are unlikely, believe it or not commercial metals are rarely made by blokes melting stuff in a pot any more! But even if Keith was machining a highly active metal and it ignited, it wouldn't blow a fuse. There's no way of translating chemical energy in a fire into electrical energy in the fuse.
                                                On the other hand electrical faults do start fires and blow fuses!
                                                I agree with others suggesting failure of a suppressor capacitor on the mains input; they are highly stressed, and not any old capacitor will do the job. If the dielectric fails a heavy current flows to earth, very likely enough to blow a fuse, but then leaving the capacitor open-circuit so everything works again. (Apart from the exploded suppressor function!) An electrical fault could create Keith's symptoms, which suggest the headstock isn't properly bonded to the bed electrically. Bonding ensures all metal parts are at the same potential if a fault occurs, and, earthing the whole, makes the machine safe. If bad bonding is behind the event, Keith would have been electrocuted had he been touching the chuck when the capacitor let go rather than cutting metal.
                                                I'd check the earth wires are all properly connected.
                                                Werner Schleidt
                                                  @wernerschleidt45161
                                                  Hello,
                                                  I had in my workshop some drill machines and the lamps with surpressor main capacitors. They worked very fine till an age of 20 years then they fail with a shortage of the mains. The capacitor had a self healing feature. That means after the first shortage the blown the plastic film in the capacitor gets very hot and build a new film. The film is thinner then before an after some time it happens again. And in the time between you find with normal measurement possibillities no fault. You have to have a meter which measure the quiscent current at a high test voltage and this is expensive. I cut them out and make bridges or put some in with a higher voltage.
                                                  The next is the harmonizing of the main voltage of 220 V to 230 V for the first look no big difference, but they change the tolerance, as I know before 220 V +- 10 % and then 230 V + 10% . In our house with solar on the roof we have till 256 Volt main voltage. The suppresor capacitors have a print on of 220 V, it is only a question of time when they fail.
                                                  Werner
                                                  #424139
                                                  Georgineer
                                                    @georgineer
                                                    One possibility occurs to me which I haven't seen mentioned. Are there any mains conductors with chafed insulation, possibly at entries or corners? If the insulation finally wore through – vibration could cause this – and the conductor made contact with earthed metal, it would give a big spark, and could very easily burn itself clear, for a while at least. I cannot explain the spark at the tool point, however.
                                                    George
                                                    #424144
                                                    mark costello 1
                                                      @markcostello1
                                                      Was the spark strong enough to pit the metal?
