Black crackle spray paint
Home › Forums › Beginners questions › Black crackle spray paint
  • #430447
    Former Member
      @formermember19781
      #9871
      Former Member
        @formermember19781
        #430457
          VHT is sold by Frosts and they are a specialised supplier to auto restorers.
          Their website says:
          " Dries within 24 hrs of applying (does not wrinkle when cold, try to use in a warm atmosphere and when humidity is less than 60%) "
          When did you use it/ That's not exactly the sort of weather we have had over the past several days…
          They also suggest using a heater or heat gun.
          Edited By Neil Wyatt on 25/09/2019 20:28:03
          #430460
          Grindstone Cowboy
            @grindstonecowboy
            Agreed, heat is essential. I have also had good results (but more for a speckled effect rather than wrinkled) by heating metal parts on top of a paraffin stove and then spraying lightly with an ordinary satin black acrylic aerosol. Remove them from the stove first, of course
            #430475
            thaiguzzi
              @thaiguzzi
              Wrinkle Black can be purchased in Harley Davidson dealers in aerosol can form as an official HD part.
              More matt than gloss, and high temperature too.
              Good stuff, but it aint cheap last time bought some.
              Edited By thaiguzzi on 26/09/2019 05:04:02
              #430488
              BOB BLACKSHAW 1
                @bobblackshaw1
                My MGB dash was done in the car using masking tape.l heated the dash with a hairdryer and a good result with the finish.
                Bob
                #430503
                Former Member
                  @formermember19781
                  #430512
                  BOB BLACKSHAW 1
                    @bobblackshaw1
                    I will dig out of the garage today and let you know.
                    It was best to remove most of the old paint if you can as my part by the rev counter you can see a slight imperfection, but only if you know it's there.
                    Bob
                    #430515
                    BOB BLACKSHAW 1
                      @bobblackshaw1
                      I found it its called Hycote Wrinkle Finish. UK 0201
                      The minimum temperature needed is 25 deg C recommended three coats.
                      Bob
                      #430517
                      Former Member
                        @formermember19781
                        #430540
                        john brown 17
                          @johnbrown17
                          If its any help ,when l was into car dash boards and have done a lot of them ,l used to put them in the green house after painting and never had a problem,but the hycote brand is very good.
                          john
                          #430564
                          Andrew Tinsley
                            @andrewtinsley63637
                            Bob is absolutely correct. The object being sprayed should be warm if not hot. I ignored this when I resprayed my Midget dash, with black crackle paint. Result a disaster!
                            Cleaned it off and sprayed on a heated dashboard and the results were very good indeed. As I said in another post, It pays to read the instructions!
                            Andrew..
                            #430643
                            Nigel Graham 2
                              @nigelgraham2
                              Thank you all, for this thread. When I find the time I intend to overhaul my dear old EW lathe (it needs its headstock and spindle un-wearing), and it would be good to finish it with a new coat of the right paint.
                              #430895
                              Tim Stevens
                                @timstevens64731
                                I used this sort of paint about 15 years go. First attempt was a failure – no wrinkles. My wife suggested I need to get a pension book for it (ha ha). Then I read the intructions, and got results. But there is a difficulty: the wrinkling starts as the surface skins, and is prompted by small irregularities which might be scratches in the surface, bits of old paint not removed, and dust in the atmosphere. Best results are obtained by regular use, so perhaps there does need to be the right sort of dust in the atmosphere?
                                Cheers, Tim
