Belt sander
Belt sander
Home › Forums › General Questions › Belt sander
  • #269397
    Scrumpy
      @scrumpy
      I have been given a early Christmas present it being a Clarke 1 ins belt sander with 5 in disc it states for wood does anyone have any idea were metal belts or discs can be purchased
      #24912
      Scrumpy
        @scrumpy
        #269398
        pgk pgk
          @pgkpgk17461
          Standard Al Oxide belts and discs work fine on my (larger) belt/disc sander for mild steel, copper, brass and ally.
          #269407
          mechman48
            @mechman48
            I have the larger version & the belts available from MM are adequate for all metals.
            George.
            #269443
            Tractor man
              @tractorman
              Hi scrumpy.
              There are many belt suppliers who can provide everything from aluminium oxide belts to diamond impregnated belts if ypu have deep pockets. The length is critical as some machines will struggle with belts not exactly the right length. I have quite a range of belt types and use mine fir everything from shaping metal to taking sharp edges off machined parts with old worn belts. Mick
              #269476
                Standard brown/red emery belts eat metal at a surprising rate, I even rough out HSS on mine these days as it is easier to set up angles accurately than offhand grinding
                I find the lapped joints on the MM belts lead to rapid wear at the joint followed by earlier failure when used on metals.
                I sourced some belts with taped joins from MSC recently and so far still on the first one.
                Ajohnw
                  @ajohnw51620
                  Thanks Neil. I have one and had been wondering about that aspect on metal.
                  Ian S C
                    @iansc
                    Stan Bray in his book "Introducing the Lathe" advocated the use of the belt sander for sharpening HSS lathe tools. With the belt vertical, and a suitable tool rest, just the thing.
                    Ian S C
                    #269495
                    Scrumpy
                      @scrumpy
                      Many thanks for all your help have ordered some from MM and some from MSC just to see what's best Derek
                      #269537
                      Ajohnw
                        @ajohnw51620
                        I'm told that the industrial ones that usually have a 4" or so wide belt can get things surprisingly flat. Not sure how it would work out on the hobby come woodwork ones as the belt run is a lot shorter.
                        The Chinese have also been know to finish off certain lathe beds with a linisher of sorts – belts in other words rather than grinding wheels. They must be similar to the wood working ones for sizing very thin panels with some added complications. The machine I was told they used this on had a dovetail bed. Saddle fit to the bed wasn't it's problem. That aspect was fine.
                        Edited By Ajohnw on 02/12/2016 13:27:26
                        #269539
                        Sandgrounder
                          @sandgrounder
                          Posted by Neil Wyatt on 02/12/2016 08:30:52:
                          I have these belts on my Elu hand held belt sander and I've always used them for my plane irons and chisels before finishing off on the oil stone.
                          Edited By Sandgrounder on 02/12/2016 13:26:01
                          #269560
                          Scrumpy
                            @scrumpy
                            I have just sharpened some lathe tools on it the belt that came with it looking good so very pleased thanks everyone
                            #269565
                              The belt mine came with lasted ages – it had a better made joint.
