Bantam gearbox oil filling
Home Forums Manual machine tools Bantam gearbox oil filling
  • #505473
    Nick Belton
      @nickbelton95587
      Good afternoon all,
      After a while of reading the manual and googling, i am a bit stuck..
      I have a colchester 1600 bantam, i need to fill the headstock and gearbox with oil, headstock is fine, a nice big cap to unscrew to fill it, perfect, but, i cannot see where i fill the screw cutting gearbox?
      can anyone shed some light to help?
      thank you!
      nick
      Nick Belton
        @nickbelton95587
        #505507
        Simon Williams 3
          @simonwilliams3
          Take off the fibreglass gear cover (LHS of lathe).
          There is a knurled plug about 25 mm dia on top of the curved surface of the cast cover LHS of the gearbox. It's got a breather hole in the centre. Its just in front of the 100/120 gear cluster.
          Unscrew it and there is a 20 mm or thereabouts filler hole below.
          HTH Simon
          edit If you have a copy of the manual, it's the lower picture on page 6 of the parts book, If you need a copy I can't do it now the wife is on the scanner, but I'll add a picture later
          Edited By Simon Williams 3 on 05/11/2020 19:29:16
          #505509
          Nick Belton
            @nickbelton95587
            Thank You Simon, i see the bit now! The manual does not help much here! Even on how much oil the headstock and gearbox hold.. (luckily i found the answers to that on here in another post!).
            Much appreciated and thank you again,
            nick.
            #505512
            Emgee
              @emgee
              Nick
              I recently checked the oil level in my Bantam lower box but found the oil level sightglass was very stained and I couldn't see the oil level so thought it must need topping up.
              Added about a pint of oil and still didn't have any level showing in the sightglass, I later found out the reason being it was above the sightglass level all the time.
              I found this out by drilling a hole in the centre of the plastic sightglass and allowed 1.5 pints to drain out.
              Turned a delrin plug up to fit the drilled hole so now just need to remove the plug when topping up so not to overfill.
              Emgee
              Edited By Emgee on 05/11/2020 20:22:19
              #505515
              Simon Williams 3
                @simonwilliams3
                You've got me going now. But the manual does have oil fill capacities, they just hid 'em. Page 18/19 of the User Manual says the headstock takes 6 pints, the gearbox takes 1 pint. Suggests Shell Tellus 27, but that's just a general purpose thinnish hydraulic oil. I use 30 grade in a hydraulic hedge trimmer, I'm sure that'll do the job.
                Rgds Simon
                #507186
                Nick Belton
                  @nickbelton95587
                  Thank you for all of the replies, you have all been of great help! And its all done. (Sorry for the late response, i am moving house, and its been a nightmare, forgetting how heavy some of my machinery is!)
                  nick.
