Robert,
I would be inclined to use 10 tpi blades, they are less likely to clog on bar cuts. The 14 tpi blades are better suited to cutting tube and thin sections.
The usual guide is to aim at keeping two teeth engaged in the cut with thin sections, coarse blades bridge over the wall thickness and are likely to snatch with unpredictable results.
Regards Brian
