I have made several back-plates for the Myford out of both cast-iron from an un-machined casting, College Engineering Supplies (I think), and from a 6" noggin of steel, although I don't know what it was it machined pretty freely.
I don't know what lathe you are making the back-plate for or the mounting, but if it's for a Myford/Boxford screw on mounting and this is the lathe it's intended for, I would suggest you obtain an un-machined cast iron casting. The rationale for this suggestion is that, if you haven't got a big lathe to part it off or a big enough power hacksaw/band saw, sawing through a round 6" noggin will take you all day. I have parted 6" in a Colchester with no problem at all but some people seem to have an inordinate amount of trouble with parting off.
When/if you screw-cut the thread, mount the tool up-side down and cut the thread of the rear face of the bore. Doing it this way means you can still use the set-over top-slide method and you don't have to think about reversing the direction of the cross-slide when withdrawing the tool, you can also see what is happening too. If you are making it for a Myford use a nose-threaded tail-stock chuck mounting as a gauge for the thread and be sure to make the register part as accurately a diameter as possible. Put a mark, or better still a positive stop on the lathe bed at just over the length of the thread so you don't accidentally run the tool into the bore. Screw-cutting does not have to be done at the speed of light as the same amount of metal is removed and same number of cuts taken whatever speed the lathe is running at. Cast iron dust is something a vacuum cleaner takes care of in seconds.
Edited By Chris Crew on 15/02/2021 20:15:36
Edited By Chris Crew on 15/02/2021 20:17:39
