availability of Abrafile saw blades
Home Forums Workshop Tools and Tooling availability of Abrafile saw blades
  • #90645
    John Burridge
      @johnburridge26484
      does anyone know where you can buy or does anyone have Abrafile saw blades they would like to sell.
      I can not find any either in catalogues or off the net except the tunsten carbide type that you use for tiles.
      John Burridge
        @johnburridge26484
        Abrafile saw blades
        #90655
        maurice bennie
          @mauricebennie99556
          HI John ,You do not say what you want them for ,but for thin metal cutting I use the blades sold for jewellery or silver smithing.They are a bit fragile and take some getting used to., they can be hand sawed or I use them in my hegner saw machine.fret saws are sold in many model shops or Axminster tools sell them made of H.S.steel from 9.5 to 27 TPI .BAHCO blades metal 36,40 and 60TPI .Also spiral blades.Hope this helps Maurice.
          #90658
          M0BND
            @m0bnd
            Try here?
            http://www.millhillsupplies.co.uk/catalogue%20pages%20pdf/page24-29.pdf
            I am not endorsing this site but a quick Google search came up with this result.
            Andy.
            #90670
            John Burridge
              @johnburridge26484
              Thank you all for the reply.
              I was today using the abrafile to cut out a electric panel on one of our test rigs at work,I could of cut a hole big enough and then split a band saw blade and re–welded it, i could also of used the flypress and cut out as near as possible to the shape that i required.
              I have pad saws and peicing saws of differing shapes and sizes but i find that the abrafile because you can change direction because it has cutting teeth all around the saw is most usefull.
              I have considered buying a fret saw but for the amount of times i think i would use it outways the expence,but as they say if you had it i would proberly use it more.
              One of the people from work who makes clocks says his dad uses a simiar saw in france sold under a nother name, as with my father he used to refer to them as Davis files by the old inventor until another firm started to make them calling them Abrafile.
              #90691
              Cornish Jack
                @cornishjack
                Unfortunately, Abrafile blades are no longer made. I have had them on my Ebay wants for over a year and, although they come up occasionally, they can go for ridiculous prices. Beware of listings of Abrafile "type" blades. They lack the so-useful small ends of the real thing. Permagrit (no connection) do a blade which cuts in any direction but, again, has end fittings which require a larger entry hole.
                Rgds
                Bill
                #90694
                MICHAEL WILLIAMS
                  @michaelwilliams41215
                  Abrafile is a trade name only . If you search on the more general tooling description of ' tension files ' then several results come back .
                  Here's one :
                   http://www.vitrex.co.uk/products.php?cat=26
                  Edited By MICHAEL WILLIAMS on 12/05/2012 20:07:40
                  #90698
                  Ed Duffner
                    @edduffner79357
                    Whenever I installed electrical boxes (switchgear etc) I used any of the following for slot making; drill, hacksaw, jigsaw, holesaw and files. Depends on the shape you need to remove. I've only used abrafiles on Aluminium sheet or ceramic tiles.
                    #90868
                    John Burridge
                      @johnburridge26484
                      Thank you all both on this site and http://www.homeworkshop.org.uk site which i also posted a request
                      #191845
                      Ed Duffner
                        @edduffner79357
                        Was Googling for letter punches today and came across some abrafile type blades/cutters. Just thought I'd post a link here as I remembered this thread.
                        Ed.
                        #191850
                        Enough!
                          @enough
                          Posted by M0BND on 12/05/2012 09:52:31:
                          Try here?
                          Could I suggest that if you are going to to post links dredged up from Google, you actually try the link first?
                          (It's also easier on everyone if you use the link tool in the editor toolbar to post it as a proper, active link).
                          #191857
                          Ed Duffner
                            @edduffner79357
                            Hi Bandersnatch,
                            This was an old thread.
                            Ed.
                            #191908
                            Aeronut
                              @aeronut
                              John, are these the ones I only have 8" course, I can let you have a packet if you PM me your address and I'll deal with it as soon as I get back home from hols. regards Lee
                              #191909
                              Aeronut
                                @aeronut
                                Just realised this was an old post PM'd John in case he still requires them.
                                Lee
                                #191933
                                Enough!
                                  @enough
                                  Posted by Ed Duffner on 31/05/2015 17:22:52:
                                  Oooops – sorry!angry
                                  #191937
                                  John Ockleshaw 1
                                    @johnockleshaw1
                                    Hello John,
                                    Back in the 1950's Tyler Spiral Hacksaw Blades were developed and made in England, they are very similar to Abrafile blades but longer.
                                    They are now made by, and still available from, Bestway Products in America.
                                    Contact stuart_gordon@bestwayproductscompany.com
                                    I have no connection with them apart from being a very happy user, pleased to be able to get these blades.
                                    Dennis D
                                      @dennisd
                                      I found some blades a while ago at a boot fair (posibly from a shed clearance ) but the frames are now as rare as hens teeth as people most likely thew them away once they could no longer get blades readily. I did get some adapters from fleabay to allow them to be used in a hacksaw frame but I now need to find a shorter frame. I still hope to spot an abrafile frame in another shed clearance box.
                                      #191950
                                      John McNamara
                                        @johnmcnamara74883
                                        Hello John
                                        You could try making your own?
                                        Nickel plated Diamond powders are available
                                        Recently at a monthly meeting of the Melbourne society of experimental engineers it was explained buy a member who used the process to make lapidary grinding disks. He plated diamond onto copper.
                                        He even plated his own diamond dust. Apparently not that hard.
                                        I ran this search and found some good links…..
                                        There may even be a plater near you who could help you ?
                                        M0BND
                                          @m0bnd
                                          Hi Bandersnatch,
                                          Ed.
                                          ….mmmm about 3 years old! I'm sorry that my post caused any inconvenience!
                                          Andy ;-(
                                          #192030
                                          frank brown
                                            @frankbrown22225
                                            I have a cheap hacksaw frame set up with an abra saw blade in it permanently. it is such a faff taking it down to pass the end of the blade through a 1/16" diam hole to get started, I hold the "other" end of the saw and adapter to the hacksaw with tape. Otherwise you need four hands.
                                            Frank
