Atlas 10inch
Atlas 10inch
Home › Forums › Beginners questions › Atlas 10inch
  • #294774
    Rob Beardall
      @robbeardall37214
      Hi I've looked at a atlas 10 inch is it normal not to be able to reverse spindle rotation how would I overcome this
      Cheers Rob
      #8678
      Rob Beardall
        @robbeardall37214
        #294806
        Chris Gunn
          @chrisgunn36534
          Rob, Older lathes were not fitted with a reversing switch, so you will need a suitable reversing switch, depending on the motor, I imagine it is a single phase machine so you would need something like the Dewhurst switch fitted to many small lathes. Bear in mind the chuck could unscrew itself when the machine is reversed.
          Chris Gunn
          #294827
          “Bill Hancox”
            @billhancox
            Rob
            Is there not a Reverse-Neutral-Forward lever under the headstock at the end of the leadscrew?
            Cheers
            Bill
            #294831
            Russell Eberhardt
              @russelleberhardt48058
              Posted by "Bill Hancox" on 25/04/2017 02:24:46:
              That's to reverse the leadscrew, not the spindle.
              A Dewhurst switch will do to reverse the spindle but a 3 phase motor and inverter drive will be better. That's the best modification I've made to my Atlas and makes cutting metric threads much easier.
              Russell.
