Posted by John Smith 47 on 12/01/2022 23:09:04:
When one buys some "M" system of metric nuts and bolts, by default are they normally fine or course pitch?
e.g. If you purchase some standard "M4" bolts, the diameter of the outside of the thread should be about 4.0mm… but will the pitch normally be 0.7mm ("course" ) or 0.5mm ("fine" ) per revolution?
Most metric threads come in both coarse and fine, and sometimes extra-fine as well. They're all standard.
In ordinary life, what you happen to buy or salvage depends on the purpose for which the fastener was made. Purpose drives choice. Coarse threads are quick and easy to assemble, but weaker, so most of the time they are preferred for ordinary work Fine threads are stronger and less likely to vibrate loose, but are more likely to cross-thread on assembly. As fine threads slow the job down they're avoided unless specifically called for.
Fine threads tend to be found on precision gear, such as instruments and whenever coarse threads aren't 'good-enough'.
DIY store threads are almost always coarse because they're sold as general-purpose fasteners. Ironmongers, convenience shops, and such are in the same class. An exception is box sets, which sometimes contain a mix because they're sold as spares. Otherwise, threads from these places are probably coarse.
Engineering sellers carry both coarse and fine threads, and expect the buyer to order what he needs. They too sell spares as mixed box sets. Buying online, I always check the pitch.
Properties like strength and corrosion resistance etc. are often important in engineering applications. DIY store nuts and bolts are made to the lowest standard and zinc-plated because there's no reason for general-purpose fasteners to be wonderful. They're plenty good enough for most jobs. But beware! They're no good for brakes, aircraft, load bearing structures, and anything else safety critical. For these purposes it's vital not to substitute ordinary fasteners for the proper item. Likewise, not smart to mix brass, steel, stainless or nylon just because they happen to fit together!
