Hi, Arc's ER25 C/chucks come in three different sizes, Warco's seem to be just one size which appears to be the same size as Arc's biggest one. As jason says Warco catalogue says you need a backplate to mount thier own one, to fit on the WM-180, which is unmachined.
I bought a ER32 one from Arc and fitted it to my Warco 220 lathe which has a similar size chuck and I needed a backplate for that, made my own out of a thick stel blank that I had.
Regards Nick.
P.S. just looked again at Arc's and it seems the 100 mm may fit, if your lathe has a 72 mm register, but it may be prudent to turn tour own register for accurate concentricity.
Edited By Nicholas Farr on 26/02/2015 15:10:31
