Anyone with experience of Myford 71 Vice
Home Forums Workshop Tools and Tooling Anyone with experience of Myford 71 Vice
  • #265421
    James Jenkins 1
      @jamesjenkins1
      Does anyone have experience of the Myford 71 Vice? Mine has just come through, from Myford, secondhand. And I have at least two issues. The first is that the corner where the fixed jaw meets the back of the vice is curved, meaning that square material held in it cannot sit on both the jaw and the back. The second is that the supplied T bolts are higher than the back, so that material wider than the narrow jaw sits on the top of the bolts.
      I am not 100% that the back is flat either. I am rather disappointed, anyone any thoughts or experience?
      James
      James Jenkins 1
        @jamesjenkins1
        #265425
        michael potts
          @michaelpotts88182
          Hello James.
          Do you have the loose piece that fits against the fixed jaw of the vice? If not, then that is your problem.
          Michael Potts.
          #265428
          James Jenkins 1
            @jamesjenkins1
            Hi Michael,
            Thanks for your post. No, the only loose piece I have fits in against the moving jaw. This the vice I bought.
            James
            #265429
            Hopper
              @hopper
              The bolts always get in the way like that. You can take one out and move it to the next slot in the base. Or put a small packing strip or parallel bar under the workpiece to lift it up a bit. Not sure about the rounded corner, never looked at mine that close, but never had a problem seating work in it either.
              #265434
              Mike Poole
                @mikepoole82104
                The corner on mine is not sharp either, a small parallel beneath or a thin packer behind could solve this. Mine is flat but as you see it is a lightly made device so enthusiastic tightening will tend to distort the body. I made some button headed screws to screw into tee nuts but be very careful about the length, if you make them too long they will burst the tee slot when the screw bottoms out, this is bad practice but I am aware of the risk and it has not been a problem. You could machine an undercut to remove the radius but this would create a stress point and may cause failure. It will help to prevent distortion if the vice is bolted down with all four bolts before tightening the work. At the end of the day this is a light but useful piece of equipment and can also be useful mounted on the faceplate for turning. Myford and others do make a heavier but still small vice for vertical slide work.
                #265438
                michael potts
                  @michaelpotts88182
                  Sorry. My mistake.
                  Michael Potts.
                  #265442
                  Swarf, Mostly!
                    @swarfmostly
                    Hi there, James,
                    Regarding the curved junction between the fixed jaw and the base of the vice, I believe the curve is to avoid the stress-raiser that would be the result of making the corner sharp. As others have suggested, a packer will usually overcome that problem. I have a short length of round rod with a flat machined along its length that I use.
                    Regarding the tee-bolts to secure the vice to, say, the vertical slide, there are two problems here. One is that the washers and nuts don't seat well onto the as-cast surface of the vice. I machined flats on the flanges of my vice base (think 'spot-face' if it were a closed hole rather than a slot). To deal with the second problem, I then attached the vice to the vertical slide and machined away the surplus lengths of the tee-bolts to make their ends co-planar with the vice. This included skimming a few thou off the nuts as well.
                    Please forgive me if the following constitutes 'teaching Granny to suck eggs'! When fitting the vertical slide and vice to the cross-slide, I grip a long parallel in the vice and, with the tee-bolts & nuts snug but not tight, I wind the vertical slide down until the far & near ends of the parallel come to bear on 1-2-3 blocks standing on the cross-slide each side of the vertical slide. This aligns the face of the fixed jaw with the cross-slide surface. I then fit a face-plate to the lathe and turn the vertical slide about its vertical axis until the two ends of the parallel are equidistant from the face-plate, then nip-up the tee-bolts & nuts securing the vertical slide to the cross-slide. If more precision is required, then one could use a dial gauge and mag-base on the lathe bed, turning the vertical slide until the dial gauge reading doesn't vary with movement of the cross-slide.
                    All the preceding paragraph refers to the case where the vice 'faces' the lathe head-stock – a similar but slightly different procedure applies if the vertical slide is to be installed with both its tee-bolts in the same cross-slide slot, i.e. with the vice facing either towards or away from the operator.
                    Best regards,
                    Swarf, Mostly!
                    #265451
                    Robbo
                      @robbo
                      James,
                      You have discovered 2 of the problems that all these vices have, and excellent solutions have been suggested.
                      The 3rd problem is looseness of the moving jaw, ie up and down slop, and this can be cured by carefully filing a minute amount from the bottom of the slide under the jaw. The holding bolt is always done up tight through the holding plate, so care is needed not to remove too much.  The jaw insert should stop this being a problem if you use it.
                      I solved the tee bolt problem by completely machining away the slotted sides of the base and fixing on a new thicker steel base, but that's a hammer to crack nuts solution.
                      Edited By Robbo on 08/11/2016 16:02:09
                      #265486
                      Nigel McBurney 1
                        @nigelmcburney1
                        just been out to workshop and have a look at myford type 71 vices,one I bought new in 1968 marked 71 the other is possibly older no markings ,and came from a scrapyard. the fixed jaw is square to the base and the corner is dead sharp,my all hardened M& W square with really sharp square edges ,fits right into the corner with no rock or daylight showing. I did not use T studs with nuts,i used T nuts which fitted in the T slots and used 1/4 BSF hex head bolts with a thin washer ,the bolt head sits just below the bottom of the vice jaw.Never did like T studs .A vice with a rad in the corner is useless as far as I am concerned. And when Myford were ok they made sliding jaws that did not lift.
                        #265499
                        John Stevenson 1
                          @johnstevenson1
                          This pattern of vise is something I have known as a drilling vise all my working life, milling vises are more robust and the price reflects it. A very popular and cheap version was "The Nippy"
                          If the radius is a problem then fit a new fixed jaw with a small radius on the back but larger than the radius on the body.
                          It's not only machine vises that have this problem, a lot of bench vises have the same problem but on the moving jaw and not many realise.
                          You open the vise and put in two or three pieces of material all accurately lined up and tighten the vise only to have the front one ride up on the radius and put the job out of line.
                          The felt tip line is where the vertical is. In my case as this bench vise is never used for heavy work and usually has either ground smooth jaws fitted or smooth brass jaws, I just cannot get on with slip jaws and keep picking them up every fats end, I decided to mill a section out and inlay a piece of gauge plate to increase the parallel part.
                          Nice tight fit and a dab of superglue and jobs a good in. In my case it hasn't weakened the vise as it's always used well under limits. I have presses for fitting tight bushes and vises with heavy grip jaws on the welding bench for heavy crude work.
                          #265577
                          James Jenkins 1
                            @jamesjenkins1
                            Dear all,
                            Thank you so much for all your thoughtful responses – very helpful. I am sure, with the work arounds that have been suggested, this will prove to be a useful addition to the lathe. I am a little concerned though at it's usefulness for a few milling jobs I need to do, but we'll see. The larger vice that Myford produce won't fit on the plain vertical slide that I have just bought. So maybe at some point I will need to save the pennies and try and get the larger slide and vice.
                            Thanks again,
                            James
