Anyone willing or able to cast a small Top Hat ?
Home › Forums › Beginners questions › Anyone willing or able to cast a small Top Hat ?
  • #81796
    flintlockand steel
      @flintlockandsteel
      Might sound a bit strange but I’d really appreciate assistance with this.
      I have a cast iron Victorian inkwell commemorating Daniel Lambert (1770-1809). Daniel was the Georgian period’s fattest man at 52st+.
      I’ve had this for 51 years and last week found a 20th Century copy (in aluminium) complete with Top Hat (inverted by his side as a candle holder).
      I’d like to complete my old original casting but don’t have the facilities.
      The top hat is only about 25x25mm and hollow.
      Could anyone help?
      Cast iron would be great, though aluminium or brass is probably more practical.
      Thank you in anticipation
      Jon
      #5856
      flintlockand steel
        @flintlockandsteel
        #81815
        Terry Lane
          @terrylane
          Might be easier to fabricate one in brass.
          #81821
          Springbok
            @springbok
            Hi try this chap
            he doese fantastic one of lost wax castings
            Bob
            #81836
            Ian S C
              @iansc
              To make a casting, you need a pattern, then the casting, it would be just as easy to make the top hat in what ever material you require instead of making the pattern. If you need it a bit roughened to look like a casting, get it sand blasted. Ian S C Just my idea
              #81874
              flintlockand steel
                @flintlockandsteel
                Hello
                Perhaps it wasn’t clear but I have the aluminium one from the replica which will serve as a pattern.
                I’ll try Union Steam and see if they can help.
                #82127
                jason udall
                  @jasonudall57142
                  silicon rubber to make mould from original
                  Metal clay into mould
                  Dry clay into kitchen oven…
                  Metal part out of oven..
