Anyone Else Having Radio Four Problems?
Home › Forums › The Tea Room › Anyone Else Having Radio Four Problems?
Viewing 25 posts - 1 through 25 (of 28 total)
  • #773098
    Nigel Graham 2
      @nigelgraham2
      Time now 7:36 am.
      Two radios on in the house, both on BBC Radio Four.
      A couple of minutes it crackled briefly then fell silent for perhaps ten seconds. It had done this about quarter of an hour previously, for a bit longer.
      I’ve had that happen on other occasions, but don’t recall hearing any apologies which suggests the fault is restricted to certain areas (I live in Dorset) so Broadcasting House is unaware of it.
      I don’t know it it hits other channels as I listen mostly only to Rs 3 and 4. It’s not a local or domestic electrical fault. Bot of my wirelesses go silent, all my lights stay on, the computer remains unruffled.
      Anyone else known of this happening?
      #773102
      Robert Atkinson 2
        @robertatkinson2
        What frequency / band are you listening on?
        LW (198kHz) is being turned off and service may be intermittent.
        Robert.
        #773113
        Martin Connelly
          @martinconnelly55370
          There was mention of it that due to a high pressure over the UK (the cause of the fog and mist as well) the radio waves used for things like digital broadcast TV and radio was being disrupted. If you go onto a computer/pad and get BBC iPlayer you should be able to get a clear signal using the internet. It is also only temporary and affecting different areas to different degrees, but no, you are not alone.
          Martin C
          #773118
            Not had any problems with Radio 4 recently but it, and other services, aren’t rock solid, and never have been!
            Unfortunately Nigel hasn’t said which Radio 4 he’s listening too, and there are at least 6 possibilities.
            • Streamed off the internet – probably not what Nigel is doing, but you never know these days.  I’ve seen these devices sold as ‘radios’.
            • The National Service is Amplitude Modulated on 198kHz Long Wave, broadcast from near Daventry in the midlands.   The transmitter is antique, and when the unobtainium transmitting valve gives up the ghost, I expect the BBC will save lots of money by closing the station down.   Not because all the old master-craftsmen who built it are dead, but because it’s not worth spending money on a channel not many listen too.  It’s expensive: an massive antenna strung between two tall towers, on a plot the size of a small farm, with a megawatt power supply!  The advantage is long range – R4 LW puts a good signal into most of Europe and the Atlantic.  Most Long Wave, Medium Wave and Short Wave broadcast services have already gone –  BBC LW is one of very few survivors,
            • FM.   On VHF Radio 4 is broadcast from many local transmitters.    Some are tiny, used to extend the service into valleys, others big, covering a region.  Local transmitters are needed because VHF is essentially short range, say 60km.  Although audio quality is better than R4 LW AM, the service is still analogue and subject to “noises off”.
            • DAB.  This is a digital service, also transmitted at VHF, but twice the frequency of FM.  Very different from AM or FM: it’s a packet system, very like the internet,  in which many stations share the same channel.  The receiver selects packets corresponding to the wanted channel and ignores the others.  The packets contain compressed data with mathematical error checking and automatic correction.    The receiver, which is mostly a computer, unpacks the data and plays it.  Although DAB still fails if the signal is too low, or interference too strong, it outperforms FM and AM, and allows many more stations to be packed into the spectrum.   For convenience, DAB transmitters may be located on the same tower as FM services,  but this ain’t always the case.
            • Freeview.  Like DAB but on a UHF TV channel.
            • Satellite.  Like DAB except the source is a GHz TV Channel transmitted from Outer Space.
            All these transmitters get content from a distribution network that connects studios together.  The studio can be almost anywhere, other than near a transmitter!  To avoid interference, they are usually kept well apart.  A big studio complex will have high-end comms, these days almost certainly packet-switched fibre, but possibly microwave, or copper in an older installation.   Not unusual though for the ‘studio’ to be in an ordinary home, using rather ordinary consumer audio equipment and an internet connection.
            The system is not straightforward or 100% available.  Being a complex mesh of interconnections, it’s more likely than not that something will be poorly.  And although the network provides redundancy, it doesn’t always self correct in the blink of an eye.
            My guess is Nigel is listening to R4 FM being roadcast by a small repeater somewhere in Dorset that doesn’t have millions of listeners.  As a low priority service, it’s power supply might be iffy, the equipment approaching end-of-life, and the data feed vulnerable.
            Today, the UK is blanketed in fog, so if Nigel’s local transmitter has a microwave feed,  then it might be struggling.  Those who live in a large conurbation get a better service, though we might recall BBC 2 TV’s disastrous opening night, where Battersea Power Station blew a fuse, the grid failed to cope, and the BBC’s launch studio went dark.  So rather than a well-rehearsed live launch, the BBC had to transfer to a poorly staffed underprepared back-up team in Alexandra Palace, only there to cover a short break.   This was a long break, and chaos ensued!
            Another possibility today is the sunspot cycle.  This morning the HF bands are open.  This is due to the sun putting more energy than usual into ionising the upper atmosphere, causing radio signals to bounce or be absorbed anomalously.   This can affect microwave and other links, and a really bad solar storm can flip out a 50 or 60Hz power grid.
            I also live in the country, and notice occasional issues.  My signals come from the Mendip transmitter near Wells, normally very reliable, but I live in a shadowed valley and notice when power is reduced due to high-winds, thunder-storms, and maintenance work.
            There are dozens of reasons Nigel might experience short breaks, and it’s very unlikely “Broadcasting House” will interrupt R4 programmes to apologise for a 10 minute outage in darkest Dorset.  Or when it happens in my little part of Zummerzet.
            john halfpenny
              @johnhalfpenny52803
              Is this more duff information from SOD? Daventry LW transmitter closed 30 years ago. Droitwich is still, I believe, broadcasting LW.
              #773142
              Martin Connelly
                I can see my local transmitter from my house, it is 25 miles away and I have had issues as described on the news and by the OP. It’s a weather problem affecting the broadcast signal. There is a Freeview item regarding this and it was mentioned in the national news.
                Bad weather is affecting my TV signal
                Certain weather conditions, including high pressure (which generally brings fine weather or morning fog), may sometimes affect your Freeview reception.
                Interference caused by atmospheric conditions is temporary and should clear once the weather changes.
                If you suspect that your signal is being affected by weather please don’t retune your TV or box. If you have already retuned it, you’ll have to retune again once the weather has cleared.
                Martin C
                #773159
                  Daventry is indeed a mistake, sorry!
                  One word wrong in an 810 word post!  Dreadful.  Have made an appointment with the Lord High Executioner.  Meanwhile, sackcloth and ashes …
                  Daventry and Droitwich are both in Worcestershire. Daventry is the closed one.  I’m tuned to Droitwich at the moment and it’s fine.
                  The station’s masts can be seen a little north of Junction 5 on the eastern side of the M5.  Very disappointing, my long wave car radio never burst into flames when I drove past. Or showed any sign whatever of overloading!
                  john halfpenny
                    @johnhalfpenny52803
                    Dave, it’s not important, but you like to give long posts with an authorative air and extra extraneous info – so it should be checked and correct. BTW, Daventry is not in Worcestershire, but in Northamptonshire.
                    #773189
                    Robert Atkinson 2
                      @robertatkinson2
                      One thing that will be lost with the R4 198kHz transmitter is an independent frequency reference. While mostly replaced by GNSS (GPS) systems there are still lots of 198kHz locked frequency standards in use.
                      Nowhere near the perfrmance of the GNSS units but a sovereign capability and would work if GNSS failed or was shut down.
                      Robert.
                      #773192
                        Seems important to you John!   You are after all a well-known Duffer basher!  (It’s allowed.)
                        In a post explaining why R4 might be misbehaving in Dorset, I’m not too worried about confusing the radio station near Droitwich with the other ex-Long Wave station near Daventry.   The location of the 198kHz transmitter makes no difference to Nigel’s problem.
                        I reject the notion the post contained extra extraneous info – Nigel didn’t say how he receives R4 so I covered all the main possibilities, plus the distribution network.  If John can show which parts of the post were extraneous, I’ll apologise.  But I’m confident he can’t.  Him not being interested in the big picture isn’t my problem!
                        Sorry if anyone doesn’t like long posts, but they don’t have to be read.  Worth a try though, might learn something!  This includes explaining how economic factors often influence technology.  Again, some dislike this, but like it or not, engineering doesn’t exist in a vacuum.  Many technical decisions only make sense if the history and economics are laid out.   Can’t help those who prefer not to know, or find the information upsets their belief system.
                        Hope everyone has noticed that the style of my posts varies to show how much I know about the subject.   Happens I know a fair bit about Radio Engineering, so this one was written positively, authoritative if anyone wants to throw rocks.   The tone just means I’m confident it’s mostly correct, though I’m always open to factual corrections.   When not sure, my posts contain hints like “I think”, “I believe”, “I suggest”, “probably”, “likely” , “hope an expert will comment”, or “dunno”.   These phrases are clues that the post is not positive knowledge.
                        Mark Rand
                          @markrand96270
                          I would humbly point out that the Rugby Radio station at Normandy Hill was, in fact, mostly in Warwickshire, with a small part in Northamptonshire.
                          The Home Service is, and has been broadcast from the BBC Droitwich Transmitting Station at Wychbold.
                          Have a nice day. 😀
                          #773210
                          Bazyle
                            @bazyle
                            I have more than one button programmed to the stations I listen to a lot as signals seem to vary a lot. Though maybe it is not that often and it is just so attention grabbing when it does happen. I remember my father deftly band switching and turning the knob at certain times of day retuning BBC World Service as short wave is affected by the sun at dawn and dusk.
                            #773214
                            Nigel Graham 2
                              @nigelgraham2
                              I think the gremlins have found this site now: It has taken me SIX attempts to log in, at one point asking me if I know what a bridge looks like and still refusing to co-operate!
                              My radios are all conventional ones set to receive normal FM broadcasts.
                              The breaks were abrupt in starting and finishing, apart from a slight distortion for a second or so prior to the second. They have occurred in the past, readily proven as external by tuning the set to some other station.
                              That two radios in different rooms were affected identically, we can discount a fault within them. Also all other mains appliances were working normally, including this PC, the one thing most likely to be affected by supply problems.
                              The fog was no more than thin mist here, this morning.
                              So I discount weather, individual radios, house wiring and mains supply problems as causes, so I rather suspect an electrical fault in the relay station, wherever that may be, as others suggest.
                              The Sun does appear to affect seriously the one in the kitchen, in Summer, while its companion in the North-facing front room suffers far less. It does not cause complete silence, and the effect grows and fades over the day, but instead it very heavily attenuates and distorts the FM reception.
                              #773233
                                There is help available, Nigel:
                                https://www.bbc.co.uk/reception/issues-with-analogue-radio/#/undefined
                                Martin Connelly
                                  I would just point out that it was not being claimed that fog was causing interference, rather that fog or fine weather was often the result of the high atmospheric pressure that is the cause of the interference. So discounting the weather because there is no fog is not a logical choice.
                                  Martin C
                                  #773363
                                  Chris Crew
                                    @chriscrew66644
                                    The only problem I had with Radio Four was hearing the Shipping Forecast read in an American, or at least a mid-Atlantic accent, the other morning. I was appalled! A bulletin so quintessentially British, is nothing sacred? I have a good mind to write to the BBC.
                                    Disgusted of Tunbridge Wells. (well, mid-Lincolnshire, actually!)
                                    #773408
                                      On Martin Connelly Said:
                                      … So discounting the weather because there is no fog is not a logical choice.
                                      Martin C
                                      Very true!
                                      Weather is another example of our world where human senses can only detect a little bit of what’s going on.  Without instrumentation our view is extremely restricted.   Of our 5 basic senses,  touch, sight, hearing, smell and taste, two are useless as weather sensors.  Then hearing doesn’t help much, apart from detecting strong wind and rain, so we rely on ‘touch’ to indicate temperature (hot, cold or comfy), and sight.    Apart from sight and heat, which are a small part of the spectrum, humans have no built in way of detecting electromagnetic radiation.
                                      Nigel’s FM radios detect Very High Frequency signals, which are affected by weather humans cannot see.    Stuff like high and low air pressure, temperature inversions, humidity, how strongly ionised the upper atmosphere is, plus natural and man-made interference.   Ordinary weather just over the horizon may be beyond our ken, yet still be on the radio path.
                                      Conclusions based on human senses alone are flimsy.   Even with instrumentation, wireless propagation is a seriously complicated subject, full of variables, and after 120 years of research the subject still springs new surprises.  The sun is a major factor, but not human obvious.  Apart from day and night changes,  the number and size of sunspots vary on an 11-year cycle, and these profoundly alter what radio waves do on earth.   Looking out of the window at human weather doesn’t help much!
                                      That said, I think Nigel is right to suspect a problem at his local relay station, or maybe it’s power supply.  Repeaters tend to be located on empty hilltops, probably powered by vulnerable wires strung between poles, and repeating programmes sent over a microwave link, that’s more influenced by fog than VHF.   This part of the radio distribution system can be quite agricultural, not highly reliable!  The short breaks Nigel experiences are consistent with a system resetting automatically  after a fault.  Which system or root cause we can’t tell.   Could be the electronics in the relay station, the antenna (protected against lightning), the power supply, or the programme feed.   Three of these are weather sensitive, including the aspects of weather that humans can’t experience directly.
                                      A non-propagation possibility:  I’ve read cracked or dirty ceramic insulators tend to flash over when well moistened by fog.  The flash dries and cleans the insulator, so after a short outage the line works again.   Except perhaps there are several iffy insulators on a befogged power line, that will flash before reliable power is resumed.   Dunno.
                                      Nigel Graham 2
                                        @nigelgraham2
                                        Thankyou for that link, Michael.
                                        I have bookmarked it for reference.
                                        I was wary of meteorological or astronomical causes in this case because the breaks were too abrupt in starting and ending, too short and infrequent.
                                        #773413
                                        Greensands
                                          @greensands
                                          I am learning a lot from the above exchange of views on redio transmission and would like to be able to extract certain posts, naming no names, to contacts of mine who are not members of the forum. How would i go about doing this?
                                          #773445
                                          bernard towers
                                            @bernardtowers37738
                                            Copy and paste or screenshot and put in a folder. Like this only paste to a folder o r desktop.
                                            #773486
                                            John Haine
                                              @johnhaine32865
                                              Click your cursor at the beginning of the first post, the “select all”, copy, and paste to a word document to tidy up.
                                              #774573
                                              old fool
                                                @old-fool
                                                Hi all. I’ve been reading the above with a lot of interest. Not suffered any abrupt outages, but my UHF TV is constantly “on the blink” The high sunspot count at present is currently a factor, UHF signals are, as previously noted a short range service, but when the sun is very active (like now) that range is increased so you get signals from distant transmitters you were never meant to get interacting with those you were. For the last few weeks I’ve never had the full range of Freeview channels all working at once. Re-tuning sometimes helps, 2-3 times per week is the norm.
                                                Bob
                                                #774582
                                                Dave Halford
                                                  @davehalford22513
                                                  Power lines crackle continuously in fog, if it’s dark enough you can see the feint light show from close up. We have a small one on the park nearby.
                                                  The big ones 400 to 600kv can be shorted by thick smoke from bonfires if some farmer lights one underneath the route.
                                                  #774587
                                                  John Haine
                                                    @johnhaine32865
                                                    Local farmer here had a different approach – collided with an 11kV o/h pole in the middle of his wheatfield, brought it down, shorted and set the straw alight.
                                                    #774588
                                                    Nigel Graham 2
                                                      @nigelgraham2
                                                      My pen-friend living about “half-way up” Norway told me of Nature doing that all by itself a few years ago.
                                                      An unusually dry Autumn ended with freezing fog that iced one set of power lines near her town, heavily enough to snap, fall and set the dry grass and heather alight.
