An unusual thread…maybe
Home › Forums › General Questions › An unusual thread…maybe
  • #24955
    Breva
      @breva
      #273361
      Breva
        @breva
        A friend of mine was rebuilding a 3" marine pump and the technical spec for the thread on one end of the drive shaft specified a thread which was described as G3/4A, that is G threequarter A, with a major diameter of some 26mm.
        Not one we came across before and 3/4" being about 18mm we were a bit puzzled. It seemed to be about 14TPI.
        Can any knowledgeable person on the forum give me any information as to what we might be dealing with please?
          John,
          It may be to with DIN 908 or DIN 910 parts
          … see here: **LINK**
          http://www.hytec-hydraulik.com/standard-parts/lock-screws.html
          Keith Rogers 2
            @keithrogers2
            Hi John,
            It's G series 3/4 BSP Parallell thread that's 14 TPI.
            Whitworth form (55deg) 1.04" major diameter.
            Keith.
            Edited By Keith Rogers 2 on 23/12/2016 01:14:55
            #273371
              Find that description on european plumbing fittings quite often as Keith says 3/4BSP external
              See thread designations for what the numbers and letters mean
              Edited By JasonB on 23/12/2016 07:50:38
              #273460
              Breva
                @breva
                That was quick! Thank you all for your help. Much appreciated indeed and problem solved.
                Best wishes to you all for Christmas.
