American Popcorn engine .
Home Forums Beginners questions American Popcorn engine .
  • #87033
    Chris machin
      @chrismachin
      As a relative beginner i read with interest the series in ME about the American Popcorn engine. Having almost completed my first engine (Elmers tiny) and also Tubal Cains 'Polly engine' i was considerig this for my next project as i find it easier to follow the step by step build rather than just a set of plans at the moment. I will be getting a mill at some point but my question is regarding the lathe work – I have a Chester Conquest lathe and as i wont be changing this for some time was wondering if this has the capacity to produce all the neccesary parts for the popcorn engine ?
      Also any advice or recomendations on plans e.t.c. for any other suitable projects in order to advance my skills / knowledge would be of great help.
      Kind regards
      Chris.
      #6031
      Chris machin
        @chrismachin
        #87037
          With 180mm swing you should not have a problem fitting the popcorn engine onto your lathe.
          Drop Stew a PM and if you ask nicely he will send you a set of plans and you may also want to look up his build threads on this engien as there is often more in them than mag space allows, they can usually be found on HMEM and Madmodder.
          J
          Edited By JasonB on 12/03/2012 12:18:12
          #87061
          magpie
            @magpie
            Hi Jason
            Not sure but i think Stew might just be in south africa at the moment,so a reply might take a while.
            Cheers Derek
            #87063
            Terryd
              @terryd72465
              Posted by JasonB on 12/03/2012 12:17:55:
              J
              Hi Chris,
              As Jason says Stew would certainly let you have a set of his plans. A lot of the guys who were following the thread asked for and received a PDF version of his plans. The initial plans were really a 'Beta' version and he asked for bugs to be reported and many were discussed on the thread. If Stew is away as Derek says (I recall him complaining about a sore arm after his jabs for the trip – sad ) I am sure that an appeal on the thread that Jason has linked to will yield results as the guys there are a really helpful bunch. The build is well worth looking at.
              Terry
              #87069
                Drawings also mentioned in this thread on ME.
                #87083
                Mike Wainwright
                  @mikewainwright87512
                  Chris
                  Send me a PM with your email address and I can send you the drawings that Stew sent me.
