Aluminium Bronze
Aluminium Bronze
Home › Forums › Materials › Aluminium Bronze
  • #653783
    Speedy Builder5
      @speedybuilder5
      Just spent an hour making a complicated composite elbow using some 1/4" dia copper tube and a piece of Al bronze to form a nipple to a 1/4 BSP gland nut.
      First one turned out a bit too short, so spent a bit more time and turned up a second nipple.
      Went to silver solder the tube into the nipple and THEN I remembered that Al Bronze (If that is what I have) doesn't silver solder (or lead solder).
      A few choose words selected !!!
      Bob
      #30290
      Speedy Builder5
        @speedybuilder5
        #653787
        Nigel Bennett
          @nigelbennett69913
          It can be silver-soldered, but it does usually need some specific flux for the job. I recall mixing some aluminium flux with silver solder flux for a job at work a long time ago and it worked well. Luker in his current Fire Queen series in ME shows what looks like an excellent join in aluminium bronze.
          #653810
          Speedy Builder5
            @speedybuilder5
            Thanks Nigel
            From model engineering pro boards:-
            "As the content (of aluminium) increases so does the need to remove the aluminium oxide. A special flux is often recommended. This special flux has a higher content of chloride.
            Make your own by adding 25% by weight of kitchen salt (sodium chloride) to your conventional flux! Use it in the same manner."
            That is an easy one to try out tomorrow. I will let you know.
            #653842
            not done it yet
              @notdoneityet
              How about the ‘lumiweld’ rods/wire for the job? I use it quite often for all sorts of jobs. No flux just scratch the surfaces to get the filler to run.
              #653843
              Speedy Builder5
                @speedybuilder5
                Quick update – EF flux plus 25% of common salt worked a treat to wet the joint surfaces and allow the silver solder to flow properly.
              Home › Forums › Materials › Topics
