All my bar is undersize!
Home › Forums › Beginners questions › All my bar is undersize!
Viewing 15 posts - 1 through 15 (of 15 total)
  • #7358
    nigel jones 5
      @nigeljones5
      #168631
      nigel jones 5
        @nigeljones5
        Ive just remade a crank pin as the old one was starting to knock. I checked the dia of my bright bar (1/2&quot and found it was 2 thou undersize. I then checked all of my various pieces of raw bar and everyone was 1 – 2 thou under. Is this to be expected. Is 2 thou to big a gap between pin/bearing with high visco oil?
        #168637
        Keith Long
          @keithlong89920
          Think if I found all my raw stock was undersize by the same amount I'd be checking the calibration of the measuring device first before coming to any conclusions.
          What are the tolerances on sizes for bright bar – or any other bar for that matter? I'd have thought that selling bar under stated size might just fall foul of trading laws unless made very clear that size is nominal and by how much under it might be.
          2 thou clearance on 1/2in. is definitely in the "large clearance" range as defined in Tubal Cains Model Engineers Handbook. How much better is that fit than the old knocking version – do you need it to be a better fit – too good a fit and you might get binding from other tolerances and inaccuracies in the mechanism.
          #168638
            Yep quite usual, if you need it bang on size either buy precision ground mild steel or machine from the next size up
            #168641
            John Stevenson 1
              @johnstevenson1
              If you check the tolerance put out by the various steel companies you will find they are all in this same ball park.
              Trying to hold dead size over a continuous run of many tens of thousands of feet , travelling at about 30 mph off the rollers, is impossible.
              It's a question of scale, you are only interested in 2" long being to size, they are interested in metric tonnes.
              #168644
              The Merry Miller
                @themerrymiller
                When I was a young draftee in the 1960's I was told by chiefy that the standard tolerance on BMS (bright mild steel) was +0.001" to -0.003", that still holds good even now for up to about 1.5" square or round.
                Len.
                #168645
                  I'll join in the festival!
                  You should celebrate Fizzy, you are not going crazy and all your bar is well within BS spec.
                  What is important is the bar must NOT be oversize and between 6 and 18mm diameter it can be up to 0.07mm (nearly 3 thou) undersize.
                  Bright bar is not intended as being a bearing surface as supplied and the biggest likely problem is if it won't fit in a hole.
                  You may be surprised just how much undersize it can be:
                  Compare with silver steel:
                  Tolerances
                  Produced and supplied as a precision ground bar with a surface finish better than 0.6 microns silver steel round bar is supplied to the following tolerances.
                  Imperial Tolerances Metric Tolerances
                  Up to 1” +/- 0.00025" Up to 25mm +0/-0.015mm
                  Over 1” +/- 0.0005" Over 25mm +0/-0.025mm
                    Posted by fizzy on 05/11/2014 12:30:18:
                    I checked the dia of my bright bar (1/2" and found it was 2 thou undersize. I then checked all of my various pieces of raw bar and everyone was 1 – 2 thou under.
                    … Well, it is getting colder now devil
                    Did you stabilise the temperature of the bar-stock and the micrometer question
                    [sufficient serious comments have already been supplied by others]
                    #168671
                    frank brown
                      @frankbrown22225
                      I was close to Southampton one day and so popped into the metal Wharehouse to buy some 16mm square bar by about 14" long. when I got home I found that the bar was 5/8" (15.825mm). It would have been a 60 mile return trip to exchange it, so I bit the bullet and used it. Moral, take your mic when buying stock!!
                      Frank
                      #168675
                      nigel jones 5
                        @nigeljones5
                        Mic is calibrated….first thing I suspected! It feels like a good fit but without supporting data I dont know if this is acceptible or not?
                        #168676
                        Gordon W
                          @gordonw
                          Nothing at all to do with this but- Last week I wanted some 3/8" bsw cup-square bolts for a special job. Dropped in at local garage on the off chance, man said "we only do metric now, have some 10mm over there", so picked up the box and they were 3/8" bsw.
                          #168708
                          Anonymous
                            Coincidentally I had a steel bar delivered this afternoon; so having left the micrometer in the workshop for a while to reach the same temperature as the steel bar, I thought I'd measure it. The bar is nominally 1.5 metres long and 3" diameter. The length is spot on, with a tape measure, and the diameter is 3 thou under; so within spec. It's still ***** heavy, even if it undersize.
                            #168715
                            Russell Eberhardt
                              @russelleberhardt48058
                              Fizzy,
                              It depends on the application but my ME Handbook (Tubal Cain) suggests a clearance of 1 thou plus 1.5 thou per inch diameter for a "normal running fit" so you're not that far out.
                              Russell.
                              #168718
                                Andrew if you kept all your tools in the workshop rather than the kitchen/lounge/diningroom like the rest of us you would not need to wait for the temperatures to equalisesmile p
                                #168721
                                Anonymous
                                  Posted by JasonB on 05/11/2014 20:10:13:
                                  Not enough room! A quick count reached 30+ micrometers, and that's only the external ones. They'd just be more things to trip over, and after recent events I'm thinking "safety" in the workshop. thumbs up It would be really dumb to trip over something and grab hold of a rotating machine. A guide might help put things in context:
                                  Garage = workshop
                                  Dining room = Tool room, cutter store and measurement area
                                  Lounge = 3D printing and technical library
                                  Kitchen = Casting aging, work in progress and assembly hall
                                  Study = Drawing office
                                  Actually, the kitchen is dual purpose, and I am about to prove that by knocking up a curry for supper this evening.
