Adept and Wizard lathes
Home › Forums › Workshop Tools and Tooling › Adept and Wizard lathes
  • #19918
    modeng2000
      @modeng2000
      #491413
      modeng2000
        @modeng2000
        Can someone let me know the considered upper spindle speed for these small lathes please? The headstock bearings are plain cast iron with a hardened shaft (or so I believe)..
        Edited By modeng2000 on 19/08/2020 15:06:10
        #491419
        Roderick Jenkins
          @roderickjenkins93242
          The similar Flexispeed lathe instructions gave a maximum speed of 1000rpm. These have un-hardened spindles as I suspect was the case with the Adept and Wizard since that were built down to a similar price.
          HTH,
          Rod
          #491425
          modeng2000
            @modeng2000
            Ok Rod, many thanks. The spindle looks well made with no wear so it was a guess as to its hardness. I have tried the spindle with a file now and it is not hardened.
            The background to this question is that I have been given both a Wizard and a Super Adept. The Wizare is in good condition together with most accessories. Not so the Adept but it might not be beyond restoring.
