Adcock And Shipley vertical milling head – worth anything?
Home Forums General Questions Adcock And Shipley vertical milling head – worth anything?
  • #809134
    ell81
      @ell81
      I have an Adcock And Shipley vertical mill in bits in my shed.
      I have a vertical milling head in good condition – is it worth anything? I would prefer to sell the mill in bits rather than have to put it all together.
      I also have the horizontal milling parts for it too.
      Would I be able to sell them possibly? Thanks.
        … If not, then the world really has gone to the dogs !
        Bazyle
          @bazyle
          Location can have a big effect also sorting out shipping.
          #809330
          ell81
            @ell81
            OK thanks lads.
            #809589
            Nigel McBurney 1
              @nigelmcburney1
              I used to own an A&S 2e universal mill with the vertical head, When having a conversation with a machine tool dealer about 20 years ago, his comment was the vertical head was worth more by itself than the rest of the mill, arbours,arbour supports and arbour sleeves should sell as they get lost rare missing. due to the weight of the head I would suggest that the buyer collects.
              #809749
              southernchap
                @southernchap
                <p style=”text-align: left;”>Heh! Yeah, I’d say so!</p>
                If I hadn’t stretched my budget on tooling over the last year or so, I’d have contacted you the moment you put this thread up and taken advantage of your missing knowledge about this topic and bought it off you for as little as I could get away with, and then gone on to eBay to look for a 1ES! 😲😆
                You can pick up a horizontal 1ES for £500 on eBay these days.
                The 1ES, when limited to horizontal milling, is a very capable, rigid, but relatively compact (relative to its rigidity and capability) machine, with a very respectable work envelope, but it is also awkward to use when performing the kinds of operations we tend to want to do, which suit a vertical milling much more; not impossible obviously, one can put a collet in the horizontal spindle nose, use angle plates, and accept that visibility of the operation whilst it’s being performed will be limited.
                However, stick a vertical head on the 1ES and one would have a machine most hobbyists would be envious of.
                Obviously the little stub vertical heads (which whilst rare, are the least uncommon), don’t have a quill and thus no down feed; one is stuck with just the knee travel, but a DRO can provide reasonably attainable accuracy on the Z axis.
                Given a tight budget and the information you now have from this thread, I can’t ‘steal a deal’, so to speak, so my advice is to squeeze any potential buyer until the pips squeak! 😄
