Thanks for replies, all helpful.
vintagengineer, thanks for suggesting dimensions, that was what I was hoping for in my original post.
Bazyle – sadly castors on the outboard end are not an option as the living room floor is flagged with well worn stones, so far from flat..
Nick – many thanks for the link, I had in fact Googled but one man's 'simple Google' is another's maze of irrelevant links. It's a matter of getting the search terms right. You did, I didn't. My bad. The project in your link is very similar to what I want to do.
It's clearly doable – given the info I've had I'll go for either a welded frame or the 'knock in' fittings Clive suggests.. I think I'll try a thrust bearing for the bottom pivot and a ball race at the top.
An Other – My wife is opposed to the bookcase idea and if she saw your alternative solution it might undermine my strategy!! It's a good plan B though – thanks.
Rob
Edited By Robin Graham on 25/12/2017 23:14:40
