@Neil
When I substitute to your equation extreme case where l=1/2 x d1 and d2 = 0 I cannot get sensible resuls.
I am getting l(belt) = 1/2Pi x d1 + sqrt5 x d1
This cannot be true as obvious correct answer is Pi x d1. After some trials I can propose an alternative equation:
l(belt) = pi x d1 + pi x d2 + 2 x sqrt{l^2 – [(d1-d2)/2]^2]}
this works for both extreme cases, second is where d1=d2=0. Perhaps it will also work for all cases between too?
Am I correct, or some rots have been proposed?
@Brian Sweeting
Formua given in your reference would read as follows:
l(belt) = 2 x l + pi/2 x (d1+d2) + (d1-d2)^2/4l
This cannot be true for l=1/2d1 and d2=0 because it delivers value higher than pi x d1, which is correct answer.
Alternative equation l(belt) = 2 x l + pi/2 x (d1+d2) – (d1-d2)^2/4l would be correct in both extreme cases. I wonder, what about cases between?
@oldiron,
Must know algoritm to trust calculator.
@Muzzer,
Good practical considerations. Regarding mentioned or other similar software – do not have access to such a luxury.
@ Robin,
No access to CAD etc. I also tend not to believe online calculators until proven correct for variety of inputs.
@Those who are suggesting "measure broken belt" etc.
I am designing 2 steps pulley system which is intended to work with *the same* belt. Do not want to fabricate parts which are not mating correctly.
Anyway, it seems that question is still not resolved. Any other ideas?
Martin
Edited By Martin Dowing on 28/10/2017 20:35:45
