Reply To: Accuracy to be expected from a 0-1″ travel DTI
Home Forums Workshop Tools and Tooling Accuracy to be expected from a 0-1″ travel DTI Reply To: Accuracy to be expected from a 0-1″ travel DTI
#534225
    Posted by Clive Brown 1 on 16/03/2021 14:56:11:
    This thread prompted me to check a dial indicator currently set up in my workshop. Over its maximum travel of 0.4" it was less than a thou. out against a slip gauge.
    Which I suggest scores D minus compared with a micrometer, and C minus compared with a caliper!
    Good luck to anyone who happens to have an indicator that maintains accuracy across its range, but as a breed they are untrustworthy over a distance. The way they are used mitigates against accuracy too. A micrometer works in a stiff frame and often has an insulating pad to minimise temperature errors. It also has a precision ground thread, and a high-grade parallel anvil, polished and hardened. In comparison, an indicator is held in a wobbly stand, at any old angle, has a gear train of dubious precision, a wobbly mechanical movement, a rounded probe, and the dial needle is behind glass, which is classic parallax error territory.
    DTI's work extremely well as comparators, and measure well enough over short distances too, but they're not for metrology! Of course for home workshop purposes, one as applied by Greensands might be 'good enough' : I don't suppose many of us really work better than a thou/0.02mm – ish, in which case a DTI is in the zone.
    Be fun to have everyone on the forum make a rod exactly 31.4159mm long at 20°C and have them all measured professionally to see how scattered the result is! Only for interest though because roughly 31.42mm is generally good enough for most practical work. Chasing accuracy unnecessarily may be a sin, but why not enjoy it? Have fun!
    devil
