Posted by Oldiron on 17/01/2021 13:43:47:
Posted by V8Eng on 17/01/2021 10:47:30:
If you live in the U.K. this might be notifiable work under Part P of the Building Regs maybe be best to check that out first.
Only notifiable if the work is in a bathroom, kitchen or outside wiring/sockets/lights in garden as far as I can remember. If the worshop/garage is connected in a properly installed manner with the correct protection at each end it is considered to be inside. I see no problem with moving or replacing the comsumer unit if it is done properly. I would suggest using an extension cord to power the freezer as suggested by Grinstone Cowboy.
regards
I have not needed to look at Part P for a long time and understand that it changes, but consumer units used to be specifically mentioned as requiring notification. That’s why I suggested checking.
mgnbuk must type a lot faster than I do.
Edited By V8Eng on 17/01/2021 14:20:00
Edited By V8Eng on 17/01/2021 14:28:11
