Grinding your own lathe cutters
Home › Forums › Beginners questions › Grinding your own lathe cutters
Viewing 25 posts - 1 through 25 (of 83 total)
  • #424062
    Chris TickTock
      @christicktock
      Hi, am I right that no heat hardening is required for HSS tool blanks that are used to grind cutters for my Sherline lathe? Obviously just checking otherwise once ground they could be too soft?
      regards
      Chris
      #9798
      Chris TickTock
        @christicktock
        #424065
          HSS was formulated to work at temperatures in excess of what you are likely to produce by grinding.
          … Don't worry.
          Chris TickTock
            @christicktock
            Thanks Michael, just crossing the t/s and dotting the i's.
            Chris
            #424071
            Bill Davies 2
              @billdavies2
              Back when I was in industry, we made large HSS tools. It was considered very bad to have any grinding burns. On the other hand, other sites have reported brazing HSS onto shanks.
              If off-hand grinding, it's considered good practice to avoid heating too much, with frequent dipping into a can of coolant, or alternatively to grind dry. The issue is more about thermal shock causing small cracks, rather than causing a tempering or annealing of the material.
              Bill
              #424072
              AdrianR
                @adrianr18614
                Dont let it get too hot and then quench, the sudden cooling can cause micro cracks that weaken the tool. So if you are quenching, quench often before it gets too hot.
                #424252
                John Reese
                  @johnreese12848
                  I am glad to see someone grinding his own tools. Too many folks start off with carbide which, with a few exceptions is ill suited to hobby lathes.
                  Even getting the bit hot enough to turn blue will not harm it. I have silver brazed a steel rectangle to the side of a HSS parting blade with no ill effects.
                  #424269
                  Lainchy
                    @lainchy
                    I'm learning this fast (Carbide on hobby lathes that is) I've been using it for roughing cuts without issue, but the insert tooling certainly doesn't like taking 2 thou off something as much. I've not been at it long, but very much seeing the benefits of HSS, and just venturing into trying to grind my own tools.
                    #424274
                      Posted by Lainchy on 15/08/2019 07:18:44:
                      ………….. but the insert tooling certainly doesn't like taking 2 thou off something as much…………….
                      Get yourself some half decent **GT inserts, they work well on small lathes and can be used on all metals.
                      #424275
                      Lainchy
                        @lainchy
                        Cheers JasonB, will look into these. I'm currently using TCMT which came with the lathe.
                        #424276
                        AdrianR
                          @adrianr18614
                          Have you heard of tangential tool holders? Lots of designs around if you want to make one and I am in the middle of trying to design my own. Eccentric Engineering make one, see the adverts on this site, and there are some youTube videos about tangential tools.
                          The big advantage of this type of tool holder is you only need to grind one face.
                          Adrian
                          #424279
                          Lainchy
                            @lainchy
                            I have Adrian, and seen one in use. Not used one myself though yet.
                            #424376
                              Made my first Tangential Tool to a set of drawings in an article in MEW, a long while ago. Was so impressed that I bought the Eccentric Engineering model. Sharpening is an absolute doddle, with only one face to grind, and a jig to hold it in the right orientation, for grinding.
                              Used almost all the time, except for hardened material, when carbide tips are necessary. The only carbide tips in regular use are CCMT0604 in a Boring bar, and the holder for the 100 degree corner, when the 80 degree corners in the Boring Bar become chipped. This is then used for roughing.
                              The parting tool used for almost all jobs is HSS. This blade must be over 20 years old, and still about half length!
                              HSS toolbits are ground up for any specialised jobs, like chamfering, screwcutting, etc
                              HSS seems to be cheaper in the long term, in that grinding is pretty easy, and nothing like like replaceable carbide tips.
                              #424489
                              Vic
                                @vic
                                Posted by AdrianR on 15/08/2019 08:10:43:
                                Adrian
                                This is the one I made. No plans just made it up as I went along!
                                #424608
                                John Reese
                                  @johnreese12848
                                  I am a fan of tangential tools, as well. Notice the tool stickout on Vic,s tool. You can get to the bit with a stone to keep it sharp. It might even be possible to grind the bit without removing it from the holder. Unfortunately, when I made my tangential tool holder I kept the metal around the bit too high to allow stoning.
                                  #424643
                                  Chris TickTock
                                    @christicktock
                                    Posted by Vic on 16/08/2019 11:56:31:
                                    Adrian
                                    Nice because its simple. Having made it like everything else how would you now make a better version?
                                    Chris
                                    #424645
                                    Chris TickTock
                                      @christicktock
                                      I am looking for a simple, diagramic explanation to carbide code designations that I can refer to. To date I have a few but I am looking for what is the simplist / easiest to work from. Anyone got a favourite?
                                      Chris
                                      #424648
                                      Former Member
                                        @formermember32069
                                        #424650
                                        Vic
                                          @vic
                                          The Tangential tool pictured is version three, the one I use.
                                          With retirement approaching I considered the relatively high cost of inserts compared to a piece of HSS. I made a small tool that took 1/8” HSS but it didn’t work too well. I got the angles right but I don’t think I ground the HSS correctly. I considered the cost of buying the Eccentric Engineering one would soon be recouped so invested in one. It worked very well with both round and square tool bits. And loaded with carbide easily deals with tough materials. One thing I didn’t like though was that the head was cranked over at an angle (they have now changed this). As a result I decided to make another one with a straight shank but I didn’t allow enough clearance around the cutting edge, this was V2. Version three is as you see it with plenty of clearance. Could it be made better? Yes, I’ve seen a version made by one enterprising individual where he simply flips the hole unit over onto a flat surface to set the tool height. In place of this I made and use a dedicated height gauge. They are fun to make and in my experience work very well for both turning and facing.
                                          #424656
                                          Chris TickTock
                                            @christicktock
                                            Posted by Barrie Lever on 17/08/2019 09:56:09:
                                            Chris
                                            You really should get yourself a copy of the book written by Joe Martin who was the owner and real driving force behind Sherline, although not the creator.
                                            The book is called 'Tabletop Machining' ISBN 0-9665433-0-0 and covers exactly the points you ask.
                                            The book is a complete inspiration on using small machines.
                                            I visited the Sherline factory about 6 years ago, they make a superb product that punches way above it's weight.
                                            If you are going to buy the book, you can borrow my copy until yours arrives.
                                            Barrie
                                            Barrie, very kind offer, let me have a look through my books first which as I have not needed to to date I have not read. My policy is never borrow a book as it lead to falling out if it gets forgotten, but your a mate for offerring.
                                            Chris
                                            Chris
                                            #424657
                                            Chris TickTock
                                              @christicktock
                                              OK guys I have come across the CarbideDepot's insert table and they do for me. Looking at the table I have a few silly questions which you guys will know the answers to:
                                              (1) Looking under the Shape table is a Greek Symbol…anyone care to explain
                                              (2) What is the difference between Ansi and ISo as in the Size table, they are obviously 2 standards, Ansi is I think American and ISO probably international?
                                              (3) whats the best mnemonic or memory aid anyone knows to remember order of designation of Code?
                                              meanwhile I shall look up the book recommended
                                              Chris
                                              #424658
                                              David Standing 1
                                                @davidstanding1
                                                Posted by Christopher judd on 17/08/2019 10:22:38:
                                                Chris
                                                Same here. Have had a few fallings out over exactly that in the past (books that were borrowed from me, in one case the borrower having subsequently 'lost' it).
                                                #424659
                                                Former Member
                                                  @formermember32069
                                                  #424665
                                                  David Standing 1
                                                    @davidstanding1
                                                    Barrie
                                                    And obviously my borrowing/lending books comment was not pointed at you, Christopher, or anyone else on here smiley
                                                    #424666
                                                    Chris TickTock
                                                      @christicktock
                                                      Posted by David Standing 1 on 17/08/2019 11:23:12:
                                                      Barrie
                                                      Thanks Barry my man is sorting out a copy of said book, I already have another 'the home Machinists book' so with the 2 should have a fair source of information.
