Min lathe steady rest for up to 65mm diameter
Home › Forums › Beginners questions › Min lathe steady rest for up to 65mm diameter
  • #387747
    andrew lyner
      @andrewlyner71257
      One of the 'excuses' I used for buying my Mini lathe was to allow me to make up 2" extension tubes and adaptors for my astro telescopes. Ideally, they have internal threads to suppress reflections from the sides of the tube (shallow and no particular pitch required). The lengths of tube involved would be up to say 150mm, which is a lot of overhang so I wanted to make a steady rest so I can work inside the tube safely.
      There are dozens of designs on Google Images to give me a clue as to a design for a steady that I would have a chance of making but my main question is just how chunky it needs to be. It would be easier if I could make it mostly out of aluminium, and to use some tough 40mm steel angle to sit on the bed. There would be a good area of contact so the off-plane clamping arrangement would not be a problem I think.
      I do have some 6mm steel plate of the right size but I hesitate to try to mill it on my mini lathe vertical mill slide. I could go easy, I suppose and I could weld it to be steel angle base. Mig welding is another thing I am getting into so it would be a suitable learning project for that skill. Unfortunately it could end up looking like a dog's dinner right next to the nice new painted lathe.
      I guess home made steadys must be a popular project so maybe a member might have some experience and ideas about my prob. The large diameter means I can't buy one afaics – not that I would really want to for £££.
      #9460
      andrew lyner
        @andrewlyner71257
        #387748
        Ady1
          @ady1
          Drummond owners tend to do their own
          The original Drummond M had a very poor fixed steady
          #387749
          Ady1
            @ady1
            I tried ball bearings to start with but the loading was too heavy, they dig in
            Nice fat (phosphor?) bronze finger tips worked best for me
            #387750
            Nick Wheeler
              @nickwheeler
              You could easily fabricate a steady from your 6mm plate by screwing and welding it together after cutting out with a jigsaw; barely any milling required.
              #387751
                This was a popular design a few years decades ago: **LINK**
                https://auction.newengland.co.uk/lots/4-point-fixed-steady-suitable-for-myford-lathe
                The concept would adapt, I'm sure
                Robbo
                  @robbo
                  Have a look at this page on Harold Hall's website homews.co.uk – **LINK**
                  There are lots of designs about
                  #387765
                  Michael Cox 1
                    @michaelcox1
                    #387769
                    roy entwistle
                      @royentwistle24699
                      At a pinch could be made from wood but keep lubricated.
                      Roy
                      #387776
                      Mick B1
                        @mickb1
                        Go for the easiest solution you can afford. If there's a suitable 3-point for your model of mini lathe, or one you could modify, don't waste time you could be using to make the things you actually want. It's too easy to become enmeshed in tooling projects that never leave you free to pursue your real interests.
                        #387778
                          Here's an alternative approach…
                          Ian P
                            @ianp
                            This was a quick lashup on a Boxford. (Tailstock and carriage obscure where the contraption is fixed to the bed)
                            Ian P
                            Edited By Ian P on 27/12/2018 10:48:32
                            #387791
                              How much excess meat does the supplied one have, there may be room for enlargement?
                              #387821
                              andrew lyner
                                @andrewlyner71257
                                Posted by JasonB on 27/12/2018 10:51:12:
                                The lathe comes without one. But I have only a small milling slide and no circle facility either.
                                #387822
                                andrew lyner
                                  @andrewlyner71257
                                  Posted by Mick B1 on 27/12/2018 10:03:05:
                                  That's a good point but i need the practice and the steady wouldn't;t be 'on show' if it ends up a bit scrappy.
                                  It seems that I cannot do multiple quotes in one post – is that true? I have to say, the forum software is not as good as many others i have used, even down to what the Return Key does!!
                                  I can't find a 'like' button either.
                                  Edited By andrew lyner on 27/12/2018 14:42:58
                                  #387823
                                  andrew lyner
                                    @andrewlyner71257
                                    Posted by Michael Cox 1 on 27/12/2018 09:17:42:
                                    Here is my solution:
                                    http://mikesworkshop.weebly.com/large-fixed-steady.html
                                    Very nice Mike.
                                    #387928
                                    Paul Lousick
                                      @paullousick59116
                                      The January, 2019 edition of MEW has a design for a fixed steady with ball races.
                                      Paul.
