5 inch gauge Stirling single injector position
Home › Forums › Locomotives › 5 inch gauge Stirling single injector position
Viewing 2 posts - 1 through 2 (of 2 total)
  • #868124
    Michael Callaghan
      @michaelcallaghan68621
      Hi out there. Well I must say that the Stirling single must be the hardest loco to plump. My question is this. Just how many bends can I make to and from the injector. From the steam turret I have around 3 easy 90 degree bends on the pipe work. However due to the clack valve being on the back head behind the injector I need to made a 180 degree bend and then a 90 bend. Will this be ok? Due to limited space I am using 3/16 tubing.
      #868137
      Baz
        @baz89810
        If you are using a 12 or 18oz injector the 3/16 tube should be ok, especially if it is thin wall tube. Keep the bends as big as possible and pipe runs as short as possible. I have had to use 5/32 tube on a 12oz injector for water, steam and delivery due to limited space, the injector is mounted between the frames, left to right on a small 5” loco, Gemma, designed by David Malcolm and serialised in EIM, it works faultlessly every time, injector is made to the design of DAG Brown in his superb book.
