Poor cutting
Poor cutting
Home › Forums › Beginners questions › Poor cutting
Viewing 25 posts - 1 through 25 (of 39 total)
  • #289890
    Curtis Rutter
      @curtisrutter61973
      img_1196.jpgSo after finally getting the lathe set up accurately I got a chance to make first cuts on some brass I had but it's coming out like so when facing
      Edited By Curtis Rutter on 21/03/2017 15:30:32
      Edited By Curtis Rutter on 21/03/2017 15:31:05
      #8624
      Curtis Rutter
        @curtisrutter61973
        #289891
          Pic of cutting tool would help, hand or power fed? Speed? feed? grade of brass? diameter?
          Edited By JasonB on 21/03/2017 15:32:12
          #289895
          Curtis Rutter
            @curtisrutter61973
            The speed I'm trying to work out, excuse my ignorance but I'm still new! But this is the belt configuration. Diameter of brass is 40mm and I believe it's cz108img_1197.jpgThe cutting tool image.jpg
            #289901
            mechman48
              @mechman48
              Looks like you have too coarse infeed if you are hand feeding / power x traveling; the tangential tool is an excellent tool for just about everything…but try putting a small stoned radius on the front corner to take the needle point off, or use a HSS / insert RH knife tool with a small radius on the tip…e.g. .02mm.
              George.
              #289902
              old Al
                @oldal
                Because brass is so easy to machine, we gwt lazy and attack it with whatever tool is set up in the lathe at the time.
                Tools that cut brass do not need top rake and to get a better finish, a rounded tool is prefered. Try sticking a bit of mild steel in the chuck and repeating what you have done on brass.
                If you are on an ML7 use top speed and if you are on a super 7, one down from top speed would give you a good start. assuming your lathe is bolted down
                #289903
                Anonymous
                  CZ108 is a cold forming brass, usually supplied in sheet form rather than bar. It can be machined, but with slow speeds and light feeds. The colour of the bar seems all wrong for brass?
                  Bin it and get some CZ121; it machines beautifully, hard to mess it up!
                  #289906
                  Curtis Rutter
                    @curtisrutter61973
                    Posted by Andrew Johnston on 21/03/2017 16:06:53:
                    The colouring is due to the lighting in my workshop, I assure you it's brass in colour
                    #289907
                    Curtis Rutter
                      @curtisrutter61973
                      Posted by old Al on 21/03/2017 16:06:46:
                      ML7 it is, will get hold of some mild steel and attemp that
                      #289908
                        Also if hand feeding use two hands on the wheel, don't crank away on the handle if things are not tight you will lift then lower the tool as the handle revolved upwards and then downwards. Aim for a constant feed.
                        #289910
                        Jon Gibbs
                          @jongibbs59756
                          I like the tangential tools very much but there is still a bit of a nack to orientating them to get the best finish.
                          When using the tangential tool for facing IME it's better to rotate the tool to have just a small clearance behind the cutting tip (against the face) so that the point leads or is perpendicular to the cutting "front".
                          HTH
                          Jon
                          #289913
                            Are you seriously suggesting that a model engineer, the most impecunious of all archetypes, bins a 40mm brass bar?
                              As I've not seen anything quite like them before, can anyone explain what's causing the marks I've highlighted on Curtis' photo please?
                              In Red, the parallel lines running across the diameter, one through the centre, the others offset from it.
                              In White, the periodic nicks around the circumference.
                              My guess is that Aliens did them like the Nazca lines or crop circles! Please put me right.
                              Ta,
                                I'd noticed the ones marked white and could not think what they were unles sits a scrap bit of lacquered brass and the lacquer is being flaked off.
                                Red could be old saw marks if only a light skim has been taken and not enough to remove all saw marks
                                #289921
                                Anonymous
                                  Possibly a shallow facing cut on a previously sawn/dinged end, which hasn't entirely removed either saw marks or dings.
                                  Edit: Too darn slow yet again; back to machining, slow there too, but at least I'm being paid for it.
                                  Edited By Andrew Johnston on 21/03/2017 17:12:45
                                  #289925
                                  John Haine
                                    @johnhaine32865
                                    Somewhere on this forum I posted the grinding angles for a tangential tool to give zero top rake for brass. You can grind a bit with the conventional angle one end and reduced rake the other, then just reverse the tool when turning brass.
                                    #289928
                                    John Haine
                                      @johnhaine32865
                                      Posted by John Haine on 21/03/2017 17:53:59:
                                      Found it in this thread, third page I think.
                                      Brian Oldford
                                        @brianoldford70365
                                        Posted by Neil Wyatt on 21/03/2017 16:30:44:
                                        If he's gonna chuck it out I'll have it.wink
                                        #289931
                                        David Standing 1
                                          @davidstanding1
                                          I am guessing that the marks across the face are made by the cutting tool being dragged across the face of the brass after the spindle has stopped.
                                          I'm also guessing that the circumferential marks are made by the cutting tool being advanced into the material when it is stationary, then the lathe is being switched on.
                                          #289938
                                            Posted by David Standing 1 on 21/03/2017 18:16:55:
                                            Excellent suggestions Sherlock! I wonder if Curtis will confirm your theory. Even if it's wrong I like it!
                                            Ta,
                                            Anonymous
                                              In which case why aren't they all radial?
                                              #289942
                                              John Hinkley
                                                @johnhinkley26699
                                                Just a quick count – but I reckon that piece of brass is around 78 years old!
                                                (I don't have enough experience with brass to make a sensible contribution.  Sorry.)
                                                Edited By John Hinkley on 21/03/2017 19:39:18
                                                #289958
                                                David Standing 1
                                                  @davidstanding1
                                                  So here's an even more off the wall suggestion – is the tool holder contacting the brass?!
                                                  #289961
                                                  Curtis Rutter
                                                    @curtisrutter61973
                                                    So to answer some of the points raised….in regards to some of the markings, the initial facing cuts were very light and the material had some rough saw marks on. The outer marks were caused by me attempting to turning across some of the length and not getting that right either! The tool was never dragged across the face after the spindle had stopped, I've always moved the tool away from the workpiece before turning off the lathe. Will check out the post ref angles John, Ta.
                                                    #289962
                                                    Anonymous
                                                      Yes, precisely because we don't know it is brass, and even if it is, it is almost certainly not CZ108. I suppose it depends if one wants to waste time trying to machine mysterium, or move on and make something useful from known material. wink 2
