Hi JCC
I have been digging through a box of custom made High speed steel boring bars made by a family friend who passed away last year. He did a lot of fine work. Some of the bars were only 30 or 40mm in total long the smallest being about 2mm in diameter (Not for the entire length) but with a working length of maybe 20mm. All of these tiny bars… there is a tobacco tin full of them in with different grindings to fit their intended purpose…. and have razor sharp cutting edges some so small they are hard to see.
No doubt he used them to precision bore tiny holes prior to lapping or burnishing.
High speed steel obviously does not have carbides ability to remove metal at high speed. However most carbide inserts have a rounded cutting edge it is not sharp. unless you have purchased specially ground inserts. carbide in a way works like a plough rather than a knife.
But a boring bar is long and thin, it flexes. So we have a plough on the end of a stick! not Ideal.
If you are using a boring head, and have purchased the generally available Asian boring bar set for it you may find that the carbide quality is a little lacking (Well on the two sets I have it is a soft grade) I actually use them quite a lot so this is not a complaint just an observation. As commented earlier you will need to re grind the boring bar tip to provide proper clearances, and make sure the tip is not touching along the side of the hole for more than a mm or so, always a good way to encourage chatter.
When finishing to size a blunt cutter can just burnish the work ok if you are at size but if you are still a little under so add a little more feed which causes the cutter to actually cut due to the increased pressure you can get a bigger cut than you dialled in, possibly ending up oversize. spoiling the work.
Sharp is the key.
When I get near size I like to make a second cut at the same dial setting to work out any spring in the bar, it is often enough.
I still have a preference for high speed steel for precise hole work in mild steel and aluminium because of its ability to take really fine cuts.
No doubt there will be commercially made boring bars out there that would change my mind but unfortunately they would not mind my change, too much of it in fact. Anyway making your own tooling is a lot more fun.
