Decided to make a test bar for the lathe and check the results.I used a length of my favourite stuff [EN24T] Ø40mm I reduced the main length to Ø35 and machined 2 collars at 220mm apart. The result when held only by the Rohm 4 jaw chuck is, collar1 furthest from the chuck Ø38.741mm collar 2 nearest chuckØ 38.737mm would it be worth adjusting the alignment of the Headstock [it can be pivoted on the axis] bearing in mind this lathe is about 11 years old .
I might add that I boobed when making the test bar as I should have made 1 to fit my 0-25mm mic so now I have a new 25-50 Mitutoyo it would certainly have been cheaper to make a new test bar but I suppose the bigger Øwill have less flex [that’s how I convinced myself to get the larger mic].
Raymond.
