What am I doing wrong???
Home › Forums › Beginners questions › What am I doing wrong???
  • #44320
    Mark Harrison 1
      @markharrison1
      Hi all, I am trying to cut a thread in a 3mm brass bar, I am using an m3 0.5 die but it’s just not cutting a thread. At best it is chewing the end of the bar up. What am I doing wrong???
      #4800
      Mark Harrison 1
        @markharrison1
        #44321
        Paul Boscott
          @paulboscott25817
          Hello Mark
          One of the possibilities may be that the split die is not adjusted correctly you should test the setting by running it down an existing 3mm thread.  It should be just tight without removing any metal.
          Paul
          #44322
          Mark Harrison 1
            @markharrison1
            Hmm don’t have a 3mm thread but could you please explain how I set up a split die?
            #44324
              Most dies have a slight lead taper, this is on the side with the size engraved on it, make sure byou have this side facing the work.
              Your diestock will have 3 screws, place the die in the stock and tighten the middle one until it just starts to expand the die, then just wind the othe two in until they touch the die. You can then  start threading. Turn the die one full turn forwards and half back and so on to break the chip off (not really needed with brass)
              Now try a nut on the thread, if its too big slacken the middle screw & tighten the outer ones to close the die and cut again, repeat until you get a good fit.
              A small chamfer on the end of the rod will help the die to start
              Jason
              PS you are not trying to thread 1/8″ bar by mistake ?
              Edited By JasonB on 18/10/2009 21:31:00
              #44327
              Rob Manley
                @robmanley79788
                Oh and make sure you aren’t using a die nut (hexagonal in shape and non adjustable) Oh and a quick warning about adjusting dies they should only require minimal adjustment from stock – close them up too tight  and they will break into two halvs.
                #44328
                The Harper
                  @theharper
                  Hi
                  Further to the above, make sure the brass rod is 3mm dia and not 1/8″ (3.17mm) as the die will find this too much for it to cope with. Infact, anything above 3mm will make it awkward to get a start, also make sure you put a chamfer / lead on the front of the rod too as this will help the die to get going.
                  Cheers and good luck
                  Paul
                  #44334
                  Mark Harrison 1
                    @markharrison1
                    Hi all and thanks for the posts, I have tried adjusting and it does not appear to make any difference. Checked the rod and it is 3mm so I am now stumped. Above pictures show the bar and Die I am using, if you can spot any issues please let me know.
                    Many Thanks
                    M
                    Edited By Mark Harrison 1 on 19/10/2009 08:52:04
                    #44336
                    IanT
                      @iant
                      Hi Mark,
                      Two things – try backing off the two outside ‘holding’ screws mentioned above and opeing the die a little more with the centre screw (then just nip up the holing screws)  This will enlarge the die slightly. Then use the drill chuck nose (mounted in your tailstock – with the ‘jaws’ wound back into the body – to keep the die square as you apply a small ammount of pressure on the back of the die. Keep the die steady as you turn the chuck (that’s holding the rod). This should form a slighly over sized thread – but it will get it started correctly.
                      Once you have done this – try a nut on the new thread – it will probably be too tight. Ease off the centre screw on the die slighly (half turn), ease, then re-tighten the outside screws and thread the rod again. Use the nut as a guide to correct size again. It should thread on using ‘finger’ force.
                      This appraoch should work. If it doesn’t – I guess the die is faulty in some way and should be replaced.
                      #44337
                      NJH
                        @njh
                        Hi Mark
                        All previous advice is good but from your ‘photo i would place the split in the die under the silver screw and tighten this first to expand the die.Failing this follow Ian T’s latest advice!
                        #44339
                        Ian S C
                          @iansc
                          Hi mark,move the gap to the 12 0’clock possition and use the silver screw for adjustment,checkthat you are starting from the correct side of the die- like a first/second tap the first few threads are tapered off to start the cutting process not all dies have this indicated in writing,but its a bit difficult starting it the wrong way!IAN S C
                          #44340
                          Mark Harrison 1
                            @markharrison1
                            Hi all, Right.. I have now tried forwards, backward, split compressed and split open and even tried the chuck method and it just wont cut a thread at all?????? Must be a faulty die?
                            #44341
                            NJH
                              @njh
                              Looks like it.
                              Is this a one off requirement for a length of 3mm brass thread?  – You could pick up a piece of 3mm brass studding for about £3.   Even so the die is always useful of course ( as long as it works!)
                              #44342
                              David Clark 13
                                @davidclark13
                                Hi There
                                Stupid questions.
                                Is it a left hand die?
                                Have you tried it on an existing 3mm bolt?
                                regards David
                                #44344
                                Mark Harrison 1
                                  @markharrison1
                                  VICTORY AT LAST!!!
                                  Managed to find an old 3mm bolt and ran it through a few times…..sorted. must have been a blocked thread on the lead in of the Die, one thread now cut.
                                  Thanks all for you help
                                  M
                                  #44347
                                  Jim K
                                    @jimk
                                    Just for the record if you have the problem again try reversing the die in the holder maybe the die is stamped on the wrong side. i have had this problem with dies before.
                                    regards
                                    JimK
                                    #44359
                                    Ian S C
                                      @iansc
                                      David C,you beat me to it,I was just about to suggest a possible left hand die,but sounds like the problems been solved.IAN S C
