Disposing of Gas Cylinders?
Home Forums The Tea Room Disposing of Gas Cylinders?
  • This topic has 23 replies, 14 voices, and was last updated 8 May 2021 at 05:40 by colin wilkinson.
  • #543696
    Vic
      @vic
      How do folks dispose of empty Gas Cylinders like this:
      Propane
      Vic
        @vic
        #543705
        Jeff Dayman
          @jeffdayman43397
          Outdoors, away from any flame, remove the fill valve in the centre of the threaded stem. Most will unscrew like a car tire valve core. This will vent any pressure inside the bottle. If it does not unscrew, depress the valve stem to vent all remaining pressure, then drill the valve out while running water around the twist drill. Leave outside to vent for a day or two. Fill with water, place in jaws of workmate, Drill a 3/8 dia hole midway up the bottle. Using a hacksaw blade in a handheld jigsaw, or a portable bandsaw, cut the bottle in two midway up the bottle. You now have two harmless pieces of steel scrap that can not be pressurized or cause explosion or fire. You can divide the pieces further of course if you want. I usually leave the pieces outdoors for a few more days to allow any odorant from the gas or entrained gas in or on the metal to dissipate.
          Note that you need to be aware of all local laws about such practices, and not do it at all if it is prohibited where you are.
          Edited By Jeff Dayman on 07/05/2021 14:36:11
          #543721
          DC31k
            @dc31k
            Your Screwfix link was fortuitous as one of the questions on the page is about a key, to remove the valve.
            It is shown here:
            https://www.stuartplumbing.co.uk/rothenberger-recycling-gas-bottle-cartridge-vent-valve-key/
            #543723
            Jeff Dayman
              @jeffdayman43397
              Or what I use, for 1.52 UK pounds at Amazoon:
              I would be surprised if several of your car-owning friends or relatives don't already have one though.
              #543724
              AdrianR
                @adrianr18614
                Depending on where you live, you may just be able to take them to the local recycling center.
                https://www.recyclenow.com/what-to-do-with/gas-bottles-1
                #543725
                ega
                  @ega
                  Is that gas mixture – see Screwfix website – hotter than the ordinary Calor propane?
                  #543738
                  noel shelley
                    @noelshelley55608
                    What size are we talking about ? Noel
                    #543740
                    Vic
                      @vic
                      Posted by noel shelley on 07/05/2021 17:24:21:
                      Click on the link. They’re about a foot tall.
                      #543741
                      Speedy Builder5
                        @speedybuilder5
                        More on this link: Disposing of gas bottles
                        #543743
                        DC31k
                          @dc31k
                          Posted by ega on 07/05/2021 16:13:08:
                          I believe propane is propane, so no. The torch that the gas bottle fits uses air at atmospheric pressure. If you want more hotness using propane as the fuel gas, I think you can use compressed air (like the Flamefast brazing hearths) or oxy-propane.
                          The same style of gas canister is available in a yellow colour and contains MAPP gas (also called MAP, MAP-X or MAP plus). Burning in air, this does produce a hotter flame.
                          #543746
                          Tony Pratt 1
                            @tonypratt1
                            Jeff D is spot on.
                            Tony
                            #543761
                            ega
                              @ega
                              DC31K:
                              Thank you.
                              I gather from Wiki that the MAPP story is a bit complicated.
                              #543762
                              IanT
                                @iant
                                Simples – The local tip – just hand it to an operative.
                                IanT
                                #543776
                                  Why does anyone not just use up all the gas for the purpose for which it is intended? You got money to burn?
                                  #543778
                                    Posted by IanT on 07/05/2021 20:23:47:
                                    IanT
                                    Not in Cheshire East !!
                                    [quote]
                                    What you cannot recycle at the household waste and recycling centre
                                    We cannot accept:
                                    • gas cylinders – they are the property of the gas company and you should return gas cylinders to the supplier
                                    [/quote]
                                    Ref. __ https://www.cheshireeast.gov.uk/waste_and_recycling/using-household-waste-recycling-centres/using-household-waste-recycling-centres.aspx
                                    Edit: Although I note that the item in Vic’s question is claimed to be disposable dont know
                                    Edited By Michael Gilligan on 07/05/2021 22:37:45
                                    #543781
                                    Jeff Dayman
                                      @jeffdayman43397
                                      Re using up all the gas – I always use these small cylinders until the torch won't run anymore, but there is always a wisp or two of gas in them afterward. Very little, but some. Can't see a way around it except to maybe refill the cylinder. I am aware this is technically easy to do – in fact I have been present when it was done – but locally it is against the law to do it. Not sure why. There may be a concern by authorities that the small cylinders could be over pressurized if fed from the wrong kind if gas supply, maybe? or maybe big merchants lobbied the regs so they can keep selling bags of these small tanks to people……
                                      Re giving these small cylinders to the local waste/ dump staff – local to me, the waste station / dump will not accept gas cylinders of any kind. No problem with scrap steel though, as mentioned in my first post above. smiley
                                      #543782
                                        This dates back to 2008 … but I don’t know if the idea was ever adopted in the U.K.
                                        https://outdoorindustry.org/press-release/coleman-provides-solution-for-disposal-of-single-use-propane-cylinders/
                                        IanT
                                          @iant
                                          I don't know what other local authorities do but my local Tip does accept disposable gas cylinders – I just hand them to the Man. Did it two weeks ago.
                                          Re-fillable cylinders are a different thing – I believe they are owned by the 'gas' company – but since they can be exchanged for refills – I'd just stick any unwanted spare bottles on Gumtree.
                                          IanT
                                          #543785
                                            On Vic’s specific question … This might help: **LINK**
                                            They even offer:
                                            • Gas Cartridge Disposal Information Available On Request
                                            Hacksaw
                                              @hacksaw
                                              I've been making these candlesticks for clients out of their horses old shoes .. they love them ! The cups are bits of exhaust pipe capped off with a disc of steel ,cheapskate me .. I thought of using core plugs, until i saw the price of them.. sj 410 014.jpg
                                              My daughters old pony died last month , and she asked me to make her one from his old shoes , but for only one candle.. The bottom of a disposable mig gas bottle came in handy !
                                              ( They won't take them at the recycle tip despite there being a recycle symbol on the cylinder ..)
                                              #543796
                                                Hacksaw — very nice work. I can see why they are popular.
                                                #543797
                                                  There must be millions of these disposable bottles worldwide that get thrown in the garbage or recycle bins but we never seem to hear reports of explosions etc. I suppose theoretically if the cylinder is full of gas but no air it can't explode? I would think they get sorted out at the garbage dump when recyclables are separated in most places. Otherwise buried in landfill so no great hazard. There is plenty of explosive methane gas coming out of those places anyway.
                                                  As far as drilling, cutting and welding etc of old gas bottles, it makes me a little nervous. I would never do that to a petrol tank or petrol tin without steam cleaning it first and filling with inert gas such as CO2 or argon. They do explode fairly regularly when being welded by careless bush mechanics and the like. Not sure how gas compares when it comes to lurking in seams and pores in the metal and lying in wait for the unsuspecting?
                                                  Edited By Hopper on 08/05/2021 01:02:52
                                                  #543800
                                                  colin wilkinson
                                                    @colinwilkinson75381
                                                    Posted by Jeff Dayman on 07/05/2021 22:45:36:
                                                    Jeff, refilling can be done but is dangerous if done without knowing what you are doing. I have refillable propane bottles for the Motorhome, just refill at an Autogas pump at the garage. BUT they have a float valve that cuts off at 80% full. This is to allow for expansion as they warm up, other wise the liquid propane comes out not gas. Bottles without a float have to be weighed as they are filled to ensure 80% max filling. Not something I would attempt.
