Disposable Gas Bottles
How to dispose of gas bottles ?
Speedy Builder516/01/2021 11:36:29
2407 forum posts
191 photos
Having several empty 600grm and 2.2L Argon / CO2 bottles hanging around, I took them to the local "re-cycling" centre where they were refused. Was told to return them to vendor.
Arrived at vendor to be told, no return without receipt of purchase ! Also I had other bottles from unknown vendors.
I now have the problem of disposal - Do you have the same problem in the UK?
Bob (France).
Nick Clarke 316/01/2021 11:43:46
1253 forum posts
50 photos
I have seen them used as vacuum reservoirs for 7 1/4" rolling stock but as an alternative if you ran a saw through the middle, cutting them in two, are they then just scrap steel and no longer pressure vessels or gas bottles?
Edited By Nick Clarke 3 on 16/01/2021 11:43:59
V8Eng16/01/2021 11:44:56
1634 forum posts
32 photos
Posted by Speedy Builder5 on 16/01/2021 11:36:29:
Bob (France).
Online advice for out local tip (U.K.) is that these are not domestic waste and therefore a £6 charge applies, it does appear they are accepted on that basis though.
Nick’s idea looks interesting as well.
Edited By V8Eng on 16/01/2021 11:50:54
Oldiron16/01/2021 11:50:54
850 forum posts
23 photos
As they are non flammable open the valve or drill a small hole to vent any residual pressure then cut them up and dispose of as scrap metal.
regards
Nicholas Farr16/01/2021 11:56:02
2985 forum posts
1352 photos
Hi, the last time I went to a local scrap yard I had to vouch that my scrap had no pressurised containers whatever the contents in them was, the simple solution to this was to cut them open, they are then not classed as a pressurised container. Of course your own local scrappy may have a different view.
Regards Nick.
Michael Gilligan16/01/2021 11:57:51
18923 forum posts
941 photos
Just pondering ... dont know
I wonder what the legality of putting them in a kerbside Litter Bin would be.
Can the local council object to such use of a facility they have provided ?
Paul Lousick16/01/2021 12:09:10
1854 forum posts
661 photos
Similar problem disposing of gas bottles in Australia at the council wastel centres (aka., tip, rubbish dump). The problem is that if the metal waste is sent to for re-cycling and melted down thjere is a danger that they could explode. Even those that containing only air can explode when they are heated and the air inside expands. There are special disposal places for dangerous goods (gas bottles, poisons, paint, etc). Gas bottles can be displosed of here if they are cut in half (safely using correct procedure). as scrap metal.
Pau
SillyOldDuffer16/01/2021 12:11:58
7549 forum posts
1680 photos
Potentially!
UK public recycling facilities are set up to deal with domestic recycling and they guard against businesses trying to dump industrial waste at taxpayers expense. They're also nervous of private individuals dumping unusual materials because their processes may not be able to handle them.
My council has an arrangement whereby rate-payers can dispose of almost anything but it's by prior arrangement, I can't just turn up at my local tip and leave a box of radium painted aircraft dials for them to sort out!
Another possibility: sellers were made responsible for the cost of recycling certain products in the UK some years ago, and I think the legislation covers the whole EU. Recycling centres may refuse to take these, again because the taxpayer shouldn't pick up commercial costs.
I suspect you've been bitten by one of these. Either the recycling centre doesn't believe it's domestic waste, or they know its a supplier responsibility. As your supplier is unlikely to want to pay to recycle another firms sales, they want you to prove where the cylinders came from.
I don't know how it works in France, but my Council's 'we take almost anything by arrangement' policy is intended to stop desperate people dumping their dodgy rubbish in the nearest river! Not all UK councils do it, so what happens in recycling centres varies considerably.
I'd ask the local council. Be a comedy of errors if I enquired - my schoolboy French is nowhere near good enough to ask about recycling gas cylinders, let alone to understand the reply.
Adam Mara16/01/2021 12:15:51
155 forum posts
We are just getting a fourth wheely bin, and there is still a list of banned items you cannot put in any of them. As you go round town you see dumped old settee's, beds and tv's Our business premises are near the town centre, and most of the aforementioned have been dumped in our car park, besides a car, and 2 empty cash boxes from parking ticket machines!
Howard Lewis16/01/2021 12:22:54
5298 forum posts
13 photos
Our council refused to collect our recycling bin "Because it contained metal" two clean Aluminium extrusions.
When I asked the chap in the office if they took baked bin tins (I knew they did ) he said "Yes" When I asked if he knew what they made of, his rely was "Aluminium? He seemed to be surprised to be told "Tin plated steel".
The cabinet member for waste did not think that any of the staff needed training
Despite claiming to be "green" not all grades of plastic are acceptable, nor is Aluminium foil, and glass has only recently become accepted..
I despair!
ega16/01/2021 12:30:19
2255 forum posts
186 photos
May I add a query about a different kind of pressurised vessel?
I have had a number of gas lift office chairs over the years and have occasionally wondered about the warning their gas cylinders carry not to dismantle or open. In my experience these fail gradually and I assume this is through leakage; would it be safe to adopt the advice to cut them open so as to be able to dispose?
Brian H16/01/2021 12:49:13
2230 forum posts
113 photos
My local council workmen refused to take a bin containing steel tubes that had once been a greenhouse frame.
The councils excuse was that greenhouse parts were not on their list of recyclable items. So now only a very limited number of items are put in the recycle bin, the rest goes into general waste.
not done it yet16/01/2021 12:51:05
6321 forum posts
20 photos
Hi Howard,
Peterborough has different coloured bins than we do, only 10 miles down the road. I expect that particular bin goes to the leccy generation incinerator at the Viridor site, so should only contain combustibles. Although they do get a fair amount of ash and scrap metal. The ash goes over the road to make wall blocks, I believe, and any metal that gets through is disposed elsewhere.
The collection ‘hall’ (a large hopper, basically), about 20-30m square, has an overhead crane where the operator operator carefully transfers stuff around, removing any large non-combustibles (like gas bottles, buggies, etc🙂 ) to a separate line, before feeding ‘good stuff’ into the kit which feeds the furnace. I think they also have metal detectors on the feed belts to avoid blockages further along the line.
Edited By not done it yet on 16/01/2021 12:51:44
Paul L16/01/2021 13:07:24
69 forum posts
24 photos
In my experience, if you tape the empty canisters together with duck tape, wrap some black and red cable around the neck and attach an old alarm clock, and place near the local Nat West, someone is usually quick to dispose of them on your behalf. wink
JasonB16/01/2021 13:07:36
21435 forum posts
2448 photos
Some people get quite dreative with old gas bottles, quite fancy doing one of the se myself but would put a copper "boiler" inside the top half of the canister "shell" if running on steam.
Alexander Smith 116/01/2021 13:54:57
44 forum posts
26 photos
I can understand why scrappiest don't like gas bottles. A few years ago I was round there for a nosey round and saw they had just installed a brand new car crusher at huge cost. Literally a few weeks later I noticed that it was gone and they were using the old one again. Apparently, a car had come in with a hidden gas bottle in the boot. Went in the crusher and bang. It blew the front off the crusher and bent all the hydraulic rams like bananas. Had to go back to Belgium to be rebuilt at a cost of £100 grand. So their care with gas bottles is well justified and now they insist they are cut in half.
sandy
Vic16/01/2021 13:58:44
2912 forum posts
8 photos
I’ve got a couple of old disposable Propane gas torch bottles, what do I do with those? I suppose in theory the lightweight aerosol type could go in domestic waste? I’ve got the heavier steel ones though.
noel shelley16/01/2021 14:17:41
758 forum posts
19 photos
IF the original contents of the bottle were non inflammable then make ABSOLUTLEY sure the bottle is empty before you drill a small hole and then cut in half. For flamable content, empty completely, remove the valve gear if possible before filling with water and cut off the top. For larger gas bottles, as before but a good plan is to pour a quantity of hot water in to drive off any oily heavy fractions that may remain, then cut off the top whilst still brim full of water.
br16/01/2021 14:42:04
697 forum posts
Posted by Vic on 16/01/2021 13:58:44:
Rang tip about disposal of asbestos from a Stuart boiler back along - had to drive miles to a special depot and pay a large sum
Mentioned it to bin men at Xmas whilst giving them their bottle, and was told:-
As long as sack tied up and I can lift it, not interested as to what is inside.
He did say random checks were done once they emptied, so make sure no envelopes etc or anything that could identify was in the sack.
br
Dave Halford16/01/2021 15:09:56
1726 forum posts
19 photos
Speedy,
Have you no car paint supply warehouse near you that stocks refillables? Similar to Calor you rent the cylinder, then just pay for refills of Co2 or argon mix. Unlike BOC with their yearly expensive commercial only charge.
There's one in Birmingham does this, I tend to use a 10lb bottle every 3 or 4 years and they don't care.
Sounds like you have already spent enough to buy at least 3 cylinders.
BOLDON
JD Metals
walker midge
rapid Direct
