Denham Lathe crash :>(
Home Forums Help and Assistance! (Offered or Wanted) Denham Lathe crash :>(
Viewing 25 posts - 1 through 25 (of 39 total)
  • #654684
    Roger Clark
      @rogerclark
      Stupid me had an episode while setting up the lathe to do a 6tpi internal thread and crashed the toolpost into the chuck. This snapped the end off the mandril that takes a feed from the chuck spindle out of the head for running the treading spindle and the power feed.
      Is there someone who could face, drill and ream the end to take a new piece, either to press fit, silver solder or some other way of reparing it for me?
      The largest diameter of the shaft is 1", the diameter of the bearing surfaces that run in I think a Babbit bearing is 0.75" and the broken bit is 0.5" with a 3/16" keyway that I could do on my mill.
      Overall length is approx. 5"
      I live in Ross-on-Wye, Herefordshire but could mail the bits if anyone can help please?
      Roger
      #34257
      Roger Clark
        @rogerclark
        Snapped the end off the mandril
        #654686
          Try visiting the Hereford Society of Model Engineers at Broomy Hill in Hereford.
          In my experience, they are a very friendly and helpful bunch.
          They will have a running day on Sunday 13th August.
          You may be able to contact them through their website.
          Am surprised that you are not a member already!
          #654692
            Ouch crying 2
            … Howard’s suggestion sounds good to me.
            Dave Halford
              @davehalford22513
              That might have been nasty enough to damage the chuck as well.
              #654701
              old mart
                @oldmart
                I would find out first just how hard it is and if it is machinable, bore the main shaft and maybe thread it and then fit or screw a new small end into it. Loctite and possibly pin the joint. If your saddle cannot move without the broken part, it is possible to use the tailstock to push it and then back off the tool and pull it back manually. The compound, if aligned dead parallel to the spindle axis can also work for short lengths. The end which goes in the bearing bush should be made a tiny bit big and then rubbed down at low spindle speed with some wet and dry on a file to get a nice finish. Care should be taken not to let the file hit the moving chuck. The pinning can be done using the mill.
                I thread internally with a left hand bar with external inserts in it in reverse. This cuts a right hand thread away from the chuck and is much safer. Make sure the chuck is nice and tight if it is a screw on one and use the slowest speed the lathe can do. Locking the chuck on the spindle is good, but Smart & Brown model A lathes are screw thread and their manual allows reverse if slow speeds are used and care is taken not to use big cuts.
                Edited By old mart on 01/08/2023 15:13:35
                #654705
                Roger Clark
                  @rogerclark
                  Posted by old mart on 01/08/2023 15:06:30:
                  Yep, love to do that wink, please see below laughcheeky
                  That's what was necessary in order to retrieve the bit of shaft with a 40 tooth gear attached to it, so no chance of machining any time soon besides my spindle bore is 3/4" and I would be machining with at least a 4" stickout with no support, not a good scenario for accurate work.
                  Roger
                  #654706
                  Roger Clark
                    @rogerclark
                    Posted by Dave Halford on 01/08/2023 15:05:03:
                    Nope, would need more than 30rpm and a small toolpost to damage it, didn't even mark the piece of metal it was holding.
                    Strangely the power feed has a clutch built into the spindle but the leadscrew doesn't, I suspect it might of had a shear pin in it's early life but was replaced with one that wasn't a shear pin!!!
                    Roger
                    #654707
                    Roger Clark
                      @rogerclark
                      Posted by Howard Lewis on 01/08/2023 12:57:34:
                      Posted by Michael Gilligan on 01/08/2023 13:26:06:
                      Ouch crying 2
                      I am a member even though I haven't visited for quite a while but their lathes don't have large bores except for possibly one that isn't that accurate any more, also they are committed to building a couple of 7 1/4" locos.
                      Roger
                      #654709
                        Size not a problem except for maybe a watchmaker's lathe. Hold thick end in chuck with operation end in fixed steady. Perhaps best to locktite in oversize piece and turn to size to ensure concentricity.
                        #654710
                        Roger Clark
                          @rogerclark
                          Posted by Bazyle on 01/08/2023 16:32:58:
                          And you're going to run the fixed steady on a bearing surface?
                          #654711
                          Ian Parkin
                            @ianparkin39383
                            If you want to send me a accurate diagram i can make you a new shaft complete and post it on?
                            #654712
                            Martin Connelly
                              @martinconnelly55370
                              Roger, since you have an ape as your avatar maybe you should be aware that a mandrill is a primate and what you have snapped is mandrel. Snapping the end off a mandrill makes a different type of mess devil
                              Martin C
                              #654713
                              Roger Clark
                                @rogerclark
                                Posted by Martin Connelly on 01/08/2023 16:46:19:
                                Martin C
                                Haha, I knew it didn't look right but my meds have been messing my head lately so I knew someone would put me right laughcheeky
                                Oh and that ape is a silverback gorilla….. watch out wink
                                Roger
                                #654715
                                Simon Williams 3
                                  @simonwilliams3
                                  Roger –
                                  If I can offer use of a lathe to make a fresh one or whatever repair you think is appropriate let me know. I'm in Ruardean, less than 10 miles from you. I have sent you a PM with contact details.
                                  Rgds Simon
                                  #654716
                                  old mart
                                    @oldmart
                                    When you get the lathe repaired, you should research the possibility of a frangigle link that is common tith most lathes. Plastic gears in an accessable part of the drive train or a little drive pin like Smart & brown lathes have. It would lower the likelyhood of a major crash.
                                    You could repair the shaft using a mill if you had a rotary table.
                                    #654724
                                      Posted by Rockingdodge on 01/08/2023 16:38:31:
                                      Shock horror. using a bearing as a bearing will never do!
                                      Maybe rebuilding with an aluminium key would help as someone advised me on a recent thread wrt an engine flywheel.
                                      #654729
                                      Roger Clark
                                        @rogerclark
                                        Martin C
                                        Sorry Martin had to do this devildevil
                                        4/487 is the part broken
                                        snipped out of the circa 1937 user manual cheeky
                                        Apologies can be considered laugh
                                        Roger
                                        #654730
                                        Roger Clark
                                          @rogerclark
                                          Posted by old mart on 01/08/2023 17:24:27:
                                          I must investigate if this is a just a taper pin or meant to be a weak link
                                          Doesn't give the pin at the end of 4/316 a number so maybe replace it with some cheddar cheese might work? indecision
                                          Roger
                                          #654808
                                            FWIW, When i did some unintentional metal mangling, During the strip down for repair, the roll pins came out.
                                            As soon as the lathe could be used, totally manually, I made two (For the Leadscrew, and for the Feed shaft ) brass pins, 5 mm OD 2.5 mm ID to act as replacement shear pins if I was stupid enough to do it again!
                                            On a friend's Raglan the feed s did not work, The shear pin had failed. Replacement cured that problem!
                                            Definitely worth having something, easily acessible that breaks easily, and is easiloyb replaced, rather than an expensive and complicated repair job!
                                            If the worst comes to the worst, remodel a knitting needle to act as a shear pin.
                                            #654823
                                            Roger Clark
                                              @rogerclark
                                              Posted by Howard Lewis on 02/08/2023 10:52:39:
                                              I totally agree, I'll take out the taper pin and fashion up a brass replacement and see how it holds up when threading, the motor is a circa 2kw one and I thread at 30rpm so it'll be interesting to see if it holds up against that kind of torque.
                                              Roger
                                              #654824
                                              Graham Meek
                                                @grahammeek88282
                                                Hi Roger,
                                                If you have not got your part sorted yet I can repair this on my Compact 5, I am in Cinderford.
                                                Gray,
                                                #654825
                                                Roger Clark
                                                  @rogerclark
                                                  Simon has kindly offered to make a new one for me and he lives only 10 miles from me but it is a more tortuous journey than you would think, back of beyond would probably describe it. smiley Certainly an interesting drive.
                                                  Thanks to all who offered help and or advice, very much appreciated.
                                                  Roger
                                                  Edited By Rockingdodge on 02/08/2023 12:16:10
                                                  #654831
                                                  Roger Clark
                                                    @rogerclark
                                                    Posted by Graham Meek on 02/08/2023 12:11:58:
                                                    Hi Roger,
                                                    Gray,
                                                    Thanks Graham but I'm sorted now.
                                                    Strange how a couple of you pop up out of the woodwork, Forest of Dean, geddit? devil
                                                    Ok now retiring to my padded quiet room.
                                                    Roger
                                                    #654837
                                                    John MC
                                                      @johnmc39344
                                                      Good to see that repair has been arranged.
                                                      have you checked for any other damage. Distorted gear teeth? What would trouble me most about this sort of mishap is distortion of the bed, not unkown with this sort of crash.
                                                      Easy to check with a precision spirit level. If you don't have such a thing then see if the lathe still turns parallel when its up and running again.
