Milling Aluminium
Milling Aluminium
  • #282583
    Paul Lousick
      @paullousick59116
      What is the best way to mill slots in aluminium ? Are there special cutters ?
      I have a sheet of 1/2" thick aluminium (aircraft grade. not sure of spec) and used my mill to cut various shapes with new,  5mm, 2 flute slot drill and a 4 flute roughing cutter. The aluminium is sticking to the cutter. Have tried cutting dry and using an aluminium cutting fluid and tried different cutting speeds and feeds. Using a vacuum cleaner to keep swarf away from the cutter. Setting up a new mill and flood coolant not installed yet.
      Paul.
      Edited By Paul Lousick on 06/02/2017 01:55:00
      Paul Lousick
        @paullousick59116
        #282585
        ronan walsh
          @ronanwalsh98054
          Flood coolant is what you want, if you watch a cnc milling aluminium at high speed the coolant blasts the swarf away so as not to interfere with the cutter. Make sure your end mills are very sharp to, or they tend to smear the surface.
          #282586
          Paul Lousick
            @paullousick59116
            Thanks Ronan, I suspected that I needed flood coolant.
            I recently sold my X3 mill for an RF-45 clone, (a bit bigger), and am in the process of fitting all of the accessories including a flood coolant system which was on my old mill. Making brackets to mount the DRO at the moment. Looks like I should have fitted the coolant first.
            Paul.
            #282587
            Thor 🇳🇴
              @thor
              Hi Paul,
              As Ronan says; sharp cutters and coolant, and yes, there are special milling cutters for aluminium, see here, or here. I havent tried them myself, I just use new slot drills.
              Thor
              #282588
                Use uncoated cutters and a small amount of parafin. In smaller sizes I use FC-3 Type cutters but the HSS aluminium specific ones work well too though the length of the ARC ones can cause chatter in the smaller diameters.
                Couple of 6mm slots cut recently FC-3
                And an aluminim cutter in action
                Edited By JasonB on 06/02/2017 08:02:35
                #282590
                Tony Pratt 1
                  @tonypratt1
                  Paul,
                  You don't have to use flood coolant but as you found out cutting Aluminium dry is also not a good idea, try brushing on Paraffin, soluble oil or cutting oil, all will help to prevent 'sticking'
                  Tony
                  #282595
                  Allan B
                    @allanb
                    Hi Paul
                    The ally sticking is where you get the metal near to the melting point, I always use flood cooling while machining any ally, I have cut it dry in the past but using small cuts to reduce the friction heat.
                    Allan
                    #282685
                    John Reese
                      @johnreese12848
                      I use soluble oil in a squirt bottle. It does not take a lot prevent chips sticking. When slotting the occasional air blast will help remove swarf. I am going to try a mist coolant unit. Haven't got it set up yet.
                      #282689
                      mechman48
                        @mechman48
                        WD 40 is also very good for milling aluminium.
                        George.
                        #282703
                        Vic
                          @vic
                          The grade of aluminium alloy has a huge influence. I've only once had a problem and just accepted it was a poor grade of alloy for machining and discarded it. I do all my milling dry except sometimes for a finishing cut.
                          #282710
                          Tim Stevens
                            @timstevens64731
                            Hello Paul
                            It looks to me as though the alloy grade might be what is marked in big black letters on the metal you have. Any clue about what it said before you attacked it?
                            Regards, Tim
                            #282713
                              Tim, that's my photo and the plate is 6082 T6, HE 30 in old money and I had no problem cutting it.
                              Edited By JasonB on 06/02/2017 17:53:55
                              #282716
                              John Haine
                                @johnhaine32865
                                Another vote for milling dry for machinable alloys, but sometimes using a mix of cutting oil and paraffin on "sticky" stuff.
                                Now for a theory which seems to work for me. Metal cutting is really a thermal process anyway where the shearing action of the tool causes the metal to soften 'cos it gets very hot near the tool tip – I read this in a long and erudite tome on machining methods some years back. I think a problem one gets sometimes is that the metal doesn't get hot enough to properly melt and detach itself from the tool. I have found that actually increasing cutting speed can make everything work better with aluminium, and since I started using my CNC mill I find that I'm usually turning the speed to max (~5000 rpm) on the biggest cutters I have a collet to hold, 10mm, on ali and having no problems. It will be even better I hope when I have my chip blower set up.
                                #282728
                                  The hollow in this 6082 bar is about 275mm long and 7mm deep, I chewed it out with an ARC uncoated cutter to full depth at each pass. Not the very best finish as I was just hogging out waste to reduce weight.
                                  #282742
                                  ronan walsh
                                    @ronanwalsh98054
                                    I do find wd40 good on aluminium, but its expensive, and i cannot stand the pong. One reason i like a lot of coolant is it washes away the swarf, if you let it build up around and on the cutter, swarf can and does smear between the cutter and workpiece.
                                    #282753
                                    Stuart Bridger
                                      @stuartbridger82290
                                      Screwfix do wd40 for £6 per litre if you buy 5l. More expensive than a neat cutting oil, but not rediculous.
                                      #282755
                                        Paraffin about £5 for 4lts from the local petrol station, garden ctr, etc and I quite like the smellsmile
                                        #282792
                                        ronan walsh
                                          @ronanwalsh98054
                                          Posted by JasonB on 06/02/2017 20:33:36:
                                          Me too, we had a paraffin heater at home when i was a kid, very distinctive smell.
                                          #282795
                                          rollingbrit
                                            @rollingbrit
                                            if cooling is not needed then Denatured alcohol, and rubbing alcohol can be used it will stop the build up on the cutter and will evaporate and does not leave residue behind a bit of searching and £4-£6 for 5ltrs also great for cleaning
                                            #282796
                                            John Stevenson 1
                                              @johnstevenson1
                                              I mix paraffin and ATF [ automatic transmission fluid] at 75% to 25% ratio and find you get the best of both worlds.but any light grade hydraulic oil will work, it's just that I have gallons of the stuff.
                                              Don't use a 4 flute cutter, there isn't enough space between the flutes to get the chips away given alloy being softer is cut faster.
                                              Routers that cut aluminium often use 1 flute cutters, no it's not April the 1st. These have maximum chip clearance than any cutter.
                                              Problem with flood cooling on small hobby machines with no full guarding is you can't get enough flood. You need to wash the chips out of the cut and once you are say 10m or 12 mm deep that's a fair bit of pressure to make things messy fast.
                                              In my new proposed hobby workshop at the new house [Tm] I plan to fit curtains to the bench mill, whatever model that is. Two / three brackets screwed to the ceiling both sides to support a length of plastic conduit with a slit in it. Into this slit will be some lengths of that black plastic DPC membrane you put on brickwork as a damp course [ because it's cheap ] This can be would up when bot in use and wound down when messy milling and it will catch the chips which will fall into a designated area to be cleaned up instead of all over the shop, in me boots and down me neck as it does at the moment.
                                              Don't know if I can apply for a patent wink or whether it's someones else's idea I have subconsciously remembered [ my excuse ]
                                              #282797
                                                Posted by Paul Lousick on 06/02/2017 01:48:25:
                                                This could be your problem. Could be any old soft, sticky and therefore hard to machine grade.
                                                Try to get a bit of 6061 T3 if you can. Machines beautifully.
                                                Edited By Hopper on 07/02/2017 01:31:42
                                                #282798
                                                John Stevenson 1
                                                  @johnstevenson1
                                                  Take your lump of alloy and a 1/4" sharp drill and belt a hole straight thru it using constant pressure all the way.
                                                  If when you turn it over it's got a small burr you can remove with a de-burring tool then it's OK.
                                                  If it's raised a big burr up like the Yellow Rose of Texas then it's T60softas$hit and needs throwing at next doors cat.
                                                  Simples.
                                                  #282801
                                                  Paul Lousick
                                                    @paullousick59116
                                                    The aluminium is Grade 5083 which is a high strengh aluminium used in ship building (which is where I got the plate from). The spec also says that because of the high strength, it has poor machining properties.
                                                    Higher strength is what I am looking for in this project so will perservere with it. Have re-installed my flood coolant pump from my old mill and will see if I get better results.
                                                    Paul.
                                                    #282805
                                                    Involute Curve
                                                      @involutecurve
                                                      I find 5083 actually machines better than 6082 the chips come off shorter, I always use flood on the cnc mill but somtimes use WD40 on the manual mill for finishing which I buy in 5ltr containers and apply with a spray bottle, cos I like the smell………
                                                      The better grades of Ali tend to ring if you tap em with a spanner etc.
                                                      Shaun
