4.70mm #12 G Silver Steel
Home Forums Materials 4.70mm #12 G Silver Steel
  • #603414
    Peter Cook 6
      @petercook6
      Does anyone know where I might get some Stubb's #12 (4.70mm .01850) silver steel rod.
      I have acquired a partial staking set and would like to make a few new punches.
      The holder takes 4.70 diameter punches. 3/16 (4.7625) is too big. New Bergeron punches are 4.70mm, so it must be available.
      Edited By Peter Cook 6 on 28/06/2022 21:28:10
      #30234
      Peter Cook 6
        @petercook6
        #603415
        Nigel Graham 2
          @nigelgraham2
          The punches are probably ground to size, not necessarily left a stock size.
          #603416
          HOWARDT
            @howardt
            Coventry Grinders could possibly supply, centreless ground from 3/16”.
            #603417
            Tony Pratt 1
              @tonypratt1
              Interesting never heard of Bergeron & their expensive staking punches until now, I doubt you will get 4.7 mm silver steel but after heat treat & polishing the 3/16 maybe will fit? Is hardened 4.7 drill rod from Zoro any good? Also your size is listed at Mcmaster Carr. Likely to be made originally from 5mm hardened stock.
              Tony
              Edited By Tony Pratt 1 on 28/06/2022 21:42:55
              #603418
              peak4
                @peak4
                Posted by Peter Cook 6 on 28/06/2022 21:27:38:
                I guess it depends on how many punches you plan on making.
                Phoenix Steel will supply metric in 0.1mm increments, but perhaps only in a 2m length
                http://toolsteels.co.uk/silver-steels-ground-polished.php
                "We have large stocks of silver steel available, ex-works in both metric and imperial sizes. Our primary stock is 2000mm and 1000mm lengths.
                We can supply the industry standard 13”/333mm lengths in single or any quantity you require.
                We also stock a unique product in 2000mm lengths (from 2mm up to 18mm) of 0.10mm incremental metric sizes for that exact fit."
                Bill
                #603424
                  Posted by Tony Pratt 1 on 28/06/2022 21:41:47:
                  Interesting never heard of Bergeron & their expensive staking punches until now, …
                  For info.
                  Bergeon has been around for quite a while: **LINK**
                  https://www.bergeon.swiss
                    What about 12g piano/music wire, it's the diameter you want and has a similar carbon content to Silver steel
                    #603446
                    speelwerk
                      @speelwerk
                      Punches of a watchmaker staking tool I have (Boley/Star/Bergeon/Helios) all are 4.7mm diameter, why I don't know but t is not handy if you want to make your own punches. The guide bush for the punches on top of the tool has its bore placed eccentric and a small spring loaded ball to prevent the punchen from sliding down but it would be not to difficult to make one with a 5mm bore. Niko.
                      #603448
                        Knocking two thou off a piece of 3/16" in the lathe to reduce it from .187" to the desired .185" (4.7mm) shouldn't be too hard should it? Bit of emery tape would do the job pretty quickly. Or a fine cut with an HSS toolbit if the job is held dead true in a collet or 4-jaw.
                        Depends on how many punches you want to make though. A dozen or so should be easy enough. More than that could be a bit tedious I'm sure.
                        Edited By Hopper on 29/06/2022 08:12:41
                        #603497
                        Peter Cook 6
                          @petercook6
                          Thanks for the feedback. McMaster-Carr has exactly what I need and at US$6.29 for a 3ft length! However they don't ship to Europe.
                          Bill, I have asked Phoenix for a quote for a couple of 1 Metre lengths, and have also asked an outfit called raptorsupplies who claim to supply any McMaster-Car part in UK. Hopefully their prices will not resemble their name!
                          Hopper – taking a bit of 3/16 down is my fall-back position, but if I could get the material for anything like McMaster-Carr's price I would do so in preference.
                          Jason, not sure 12g piano wire is the same wire guage – all the suppliers I can find make 12g = 0.75mm i.e. AWG rather than Stubbs.
                          Niko, there is a bit of a discussion about the reason behind the size used at
                          https://mb.nawcc.org/threads/identify-staking-punch-and-size.135442/post-1048863
                          Thanks again.
                          Edited By Peter Cook 6 on 29/06/2022 15:18:44
                          #603499
                            Always been SWG when I have bought it, same with the first few hits on google
                            #603501
                            Dave Halford
                              @davehalford22513
                              Posted by Peter Cook 6 on 29/06/2022 15:02:19:
                              Thanks again.
                              I just thought it was for a really big piano smiley
                              #603504
                                Posted by JasonB on 29/06/2022 16:36:02:
                                dont know … I’m confused, here in my little corner:
                                Why would anyone want 2.65mm [or thereabouts] wire to make 4.7mm punches ?
                                  The heading is asking for 4.7mm or 12gauge 2,642mm is 12gauge by the SWG standard. Unless Stubbs had their own gauge system?
                                  #603511
                                  Peter Cook 6
                                    @petercook6
                                    They wouldn't want 12 SWG which is as you say 2.65mm diameter.
                                    No 12 piano wire (AMWG – not AWG my mistake in the reply post) is 0.75mm
                                    They would want #12 Stubbs steel wire guage an old and probably obsolete wire guage. Not to be confused with Stubbs Iron wire guage. The Stubbs #12 steel is 4.7mm. This from a K&D catalogue of staking tools dated 1910.
                                    They seem to have been the instigator of such devices, and everyone copied their standard.
                                    Edit – the metric to inch conversions presumably use the US inch rather than the UK inch – they were different at the time, only standardised to 25.40mm in the 1960's
                                    Edited By Peter Cook 6 on 29/06/2022 18:27:00
                                    Edited By Peter Cook 6 on 29/06/2022 18:28:42
                                    #603512
                                      Thanks For that peter, did not know they had their own system.
                                      Think I had brain fade this morning and had 2.7mm in my head not 4.7embarrassed
                                      Edited By JasonB on 29/06/2022 18:31:27
                                      #603532
                                        I am now unconfused/deconfused [or whatever] … yes
                                        Peter Cook 6
                                          @petercook6
                                          OK 3/16 and time on the lathe it is.
                                          Phoenix only offered 3/16 not 4.70 special.
                                          Raptor supplies wanted £16.70 each for the bars, £63.00 shipping and handling plus Vat so £115+ for two items totalling US$12.50 at McMaster-Carr.
                                          #603634
                                          Nick Clarke 3
                                            @nickclarke3
                                            Tracy Tools list drill branks in all sizes if that would be long enough?
                                            #603638
                                              Posted by Nick Clarke 3 on 30/06/2022 16:39:02:
                                              That sounds ideal yes
                                              Edited By Michael Gilligan on 30/06/2022 16:50:40
                                              #603639
                                              Roger Woollett
                                                @rogerwoollett53105
                                                Drill Service also have 4.70mm drill blanks. 89mm long and £2.28 + VAT
                                                #603640
                                                  If the 4.7mm stock is going to be shaped like some of the available staking tools would HSS drill blanks be a bit more difficult to work than silver steel which can easily be machined before hardening. HSS would really need grinding.
                                                  Edited By JasonB on 30/06/2022 17:04:11
                                                  #603645
                                                  Peter Cook 6
                                                    @petercook6
                                                    Thank you for the idea. Drill blanks are something I did not know you could buy – filed for future use. However as Jason says, shaping HSS drill blanks (drilling holes in them and shaping them) may be more work than thinning down a bit of silver steel.
                                                    I am also not too sure about using HSS as a punch given my ability to chip the edges of HSS lathe tools!
                                                    A cheaper source of material may be to buy some old punches off Ebay and anneal and reshape the tips
                                                    Thanks again.
                                                    #603653
                                                      Posted by JasonB on 30/06/2022 16:57:08:
                                                      The information seems difficult to locate on the U.K. site … but this supports my understanding:
                                                      https://www.metalsupermarkets.com/what-is-drill-rod/
                                                    Home Forums Materials Topics
