Electrical conducting paint
Home Forums Materials Electrical conducting paint
  • #460133
    Speedy Builder5
      @speedybuilder5
      The electrical tab connector has detached from the rear screen heating grid on the car. I have seen a tube video showing a guy soldering it back onto the grid, but I hesitate as I have a concern that the thermal shock may shatter the glass.
      Would electrical conducting paint be better with an epoxy coat to make it more secure once the paint has dried.
      Anyone had same experience ?
      #29999
      Speedy Builder5
        @speedybuilder5
        Car demister panel
        #460149
        Stuart Bridger
          @stuartbridger82290
          Wow, it must be over 30 years since I used that stuff for the exact same repair. From memory it worked well, I didn't need epoxy on top. Still have a little bottle rattling around in my took box, not sure if it still any good!
          #460150
          noel shelley
            @noelshelley55608
            Solder with as big an iron as you can ! In, solder flows and out, quick ! Heater is high current. I would question resistance of the paint which may heat. Best wishes Noel
            #460162
            Robert Atkinson 2
              @robertatkinson2
              Assuming the element is on the surface, rather than embedded in laminated glass, the best repair is t use silver loaded conductive epoxy. Not cheap though
              https://uk.farnell.com/multicomp/mc002966/epoxy-adhesive-syringe-6ml-silver/dp/2917615?st=ilver%20epoxy
              Make sure it says it is ELECTRICALLY conductive, some are designed for thermal conducttivity and may not be good electrically.
              Robert G8RPI.
              #460199
              old mart
                @oldmart
                I bought some of this, but haven't tried it yet, I am waiting for warmer weather.
                Speedy Builder5
                  @speedybuilder5
                  This is the video I saw:
                  de mister repair
                  #460214
                  old mart
                    @oldmart
                    It looks like you could get away with soldering it, but during this lockdown at present, if the window did shatter, who would replace it?
                    #460234
                    john fletcher 1
                      @johnfletcher1
                      I think I used my 100 watt soldering iron, maybe it was 80 or 90. I warmed up the connector first, then quick dab, job done.I also remember buying some expensive Silver conducting paint, from I think Radio spares now RS for fail rear widow heater and that worked. John
                      #460480
                      Speedy Builder5
                        @speedybuilder5
                        Thanks for the replies, so soldering iron it is, but A) wait for some hot sunshine and B) do it when the auto glass shop is open for business.
                      Home Forums Materials Topics
