Hi.
I'm wanting to start practicing cutting threads on my ML. I have most of the change gears, 1 x 15t on a shaft???, 2 x 20t, 1 x 25t, 1 x 30t, 1 x 35t, 1 x 40t, 1 x 45t, 0 x 50t, 2 x 55t, 1 x 60t, 5 x 65t and one collar. I'm certain I have a 50t as well but I can;t find it and it's one of the gears I need for a 20UNF thread
Anyway the little chart in my garage says I need a 20t on the mandrel and 50t on the leadscrew and idlers on the 1st (upper?) and 2nd (lower?) studs. When I take the gears of the leadscrew and try and fit a 50t (must have been a 55t) the lower idler can't reach it as it's a compound gear and the larger of the 2 gears prevents the smaller one engaging with the 50t on the leadscrew.
So I'm wondering just what the idler gears should be. I recently bought the lathe of a chap who didn't really seem to know much about lathes so couldn't give much . On the upper rearmost stud (1st stud?) there's a single peace compound gear with MOD1-100 written on it.
On the lower stud(2nd stud?) is another compound gear with MOD1-80 written on it.
And on the leadscrew is a single gear with MOD1-80 written on it.
This is how they are arranged,
Also the diameter of te 1st and 2nd studs are much smaller than the holes in my change gears is there supposed to be some sort of bush I should have?
Here are my change gears.
If somebody could help me understand what gears I need and where/how to fit them I would be very grateful as I have been brought to an abrupt stop with my little project
Many thanks
Rich
