Dougie: Beware, the old BS standard for imperial taper pins is as Jason says, the nominal diameter is the large end. However, the newer DIN standards for metric taper pins quote the nominal diameter at the small end.
Author
Please log in to reply to this topic. Registering is free and easy using the links on the menu at the top of this page.
