Smart and Brown Model L
Home Forums Workshop Tools and Tooling Smart and Brown Model L
  • #503526
    Paul Doyle 1
      @pauldoyle1
      Hi all,
      I have been reading this wonderful forum for quite some time, the level of information available here, the positive and helpful community, and beautiful work is just so inspiring on so many levels.
      I am a total noob (with some high school experience) who wants to get into model engineering.
      I have the opportunity to purchase a Smart and Brown Model L lathe. It's a basic model and it does need work – the original owner was restoring it himself, but unfortunately due to ill health, has to forfeit the completion. From my naive POV, it needs sandblasting and painting, and reassembly, (as far as I know, the original owner has replaced bearings in the headstock. It has no motor or motor mount or electric controls.
      It has no tooling or collets either, or as far as I know, no live centre in the tail stock. It does come with a 4 jaw chuck.
      I would be very happy to have a little lathe like this and would have no problem undertaking the restoration, but I am concerned sourcing parts. Although they may not be genuine Smart and Brown parts, are there parts available from other lathes that may fit? For example, would Myford cutting tools and live centres fit?
      Or would I be better to skip this lathe and look for another lathe, which may have screw-cutting capabilities among others?
      I would greatly appreciate any and all help you may be able to offer me!
      Many thanks,
      PAUL
      #19993
      Paul Doyle 1
        @pauldoyle1
        Noob requiring advice
        #503532
          Hi Paul,
          Welcome to the forum.
          Most accessories like centres, chucks, toolposts and cutters are 'device independent' and can be bought in sizes that will fit, although the small size means more limited choice. Chucks are likely to need a custom backplate making up.
          It's part like collets that you may find hard to source.
          Check out http://www.lathes.co.uk/smart-and-brown-model-L/
          JohnF
            @johnf59703
            Hi Paul, It depends on what you intend to do/make but as a plain turning lathe for small parts you will find none better but it will never replace a surfacing. sliding, screwcutting lathe i.e. a traditional lathe such as Myford or similar whether its of home origin or Far Eastern origin.
            If the machine is affordable I would go for it but you will probably find the need another more versatile machine as well ?
            Anonymous
              Paul; welcome to the forum.
              Now for the bad news. The Smart and Brown L is a plain lathe. Although there was a toolroom version it was primarily intended for second operation work. In other words simple repetitive operations to finish a workpiece. Smart and Brown are long gone although there is a UK company (Bracehand) just down the road from me in Shefford, close to Biggleswade where the S&B factory was located, that deals in Smart & Brown (and Pultra) lathes. However in my limited contact he doesn't have much in the way of spares. It is highly unlikely that parts from other lathes will fit. Even the collets were proprietary. In short what was essentially a production lathe is of little use without tooling.
              Interestingly there are some S&B collets on Ebay, but they are not dead length collets, so not intended for use with the L lathe.
              Personally I'd pass and look for a more general purpose lathe with screwcutting and power feed capability.
              #503539
              David Colwill
                @davidcolwill19261
                I would have to agree with Andrew.
                Unless you were wanting to make the most basic of models I think you would pretty soon hit the limitations of the lathe.
                That said S&B are excellent (I have a 1024).
                If you have a ton of room and the money is no issue, then as a project to learn on, maybe but demand for such lathes second hand is not great.
                A Smart and Brown model A or a 1024 would be a good bet.
                Regards.
                David.
                #503542
                larry phelan 1
                  @larryphelan1
                  Hi Paul,
                  I dont know the machine in question, but as you are starting out, I doubt if you would have it very long before seeing its limitations. Once you get into things, you will want to try screwcutting,,facing, boring ect, this is where the powerfeed comes in. Andrews advice is spot on.
                  PS Take care, you have been bitten by a bug worse than Chinese flu and harder to shake off !cheeky
                  #503545
                  Paul Doyle 1
                    @pauldoyle1
                    Hi everyone!
                    Thanks for the warm welcome! And the swift responses!
                    I think I knew what everyone has been suggesting already, but just needed to hear it independently. SOrt of disappointing, but the reality. Thanks everyone. I suppose I really just want to get my hands on a lathe and start making.
                    With regards affordability, the seller is looking for ~ £340 (converted from €380 – although I would have been hopeful for some negotiation).
                    I suppose this is a subjective question, but…what would be a good alternative lathe? I won't be doing big work, but would like the option of using power feed and cutting threads, etc. Myfords are seen as the Rolls Royce of lathes, but far outside my budget.
                    What is the possibility of finding a nice S+B A or 1024? The 1024 tends to be the most desirable? What do they reach money wise?
                    Thanks again all.
                    PAUL
                    #503546
                    Dave Halford
                      @davehalford22513
                      Paul,
                      It's OK to start with, it's good to learn steady handle winding skills on, plus you can normally turn much longer tapers on plain lathes. It swings 9" dia. where as Myford's only manage 7" But in it's current state it's not worth much being underdrive unless it has the stand and even then only just 3 figures. Don't forget a motor is at least £50 +, an 100mm 3 jaw chuck is approx £80. Morse taper #1 tooling is out there
                      Andrew is right if your budget goes that high, but if you just are testing the water the S&B will do for now.
                      #503555
                      David Colwill
                        @davidcolwill19261
                        In my opinion that sounds very high for what is essentially a project.
                        Sadly it is quite difficult to offer advice on prices of second hand lathes as condition is everything and this is not always obvious if you are new.
                        Having said that if you could find a Model A for £500 / 600 That would be not too bad.
                        Personally I would try to find one that is complete with chucks / collets and or other accessories and is or has been recently used. If you can have it demonstrated all the better.
                        David.
                        #503560
                        old mart
                          @oldmart
                          Welcome to the forum, Paul, there is information on the model L on the "lathes UK " website. A lot of good work can be carried out on one of these lathes despite its basic specification. As it doesn't have a saddle, and relies on the compound, you will need a lever type indicator on a magnetic base to check the alignment before turning anything parallel. The degree scale is not sensitive enough.
                          Unfortunately, unless you know quite a lot about lathes, this model is rather too basic for a beginner to cope with.
                          Edited By old mart on 26/10/2020 14:00:57
                          Edited By old mart on 26/10/2020 14:05:58
                          #503563
                          Paul Doyle 1
                            @pauldoyle1
                            Hi all,
                            Thanks again for all your time and help.
                            I acknowledge myself that it's a little on the expensive side. Especially as David Halford points out, that as I add the motor and tooling, collets, etc – regardless of their scarcity, the price would be sky rocketing for what would still be a basic lathe.
                            I've been doing some research on the Smart and Brown Model A. What is the likelihood of finding one of those for sale? Preferably complete, with all the tools. I still wouldn't mind restoring a lathe, but, just want something that after investing time and money into, I wouldn't find myself at a dead end unable to source a specific part.
                            Thanks,
                            PAUL
                            #503564
                            Bob Stevenson
                              @bobstevenson13909
                              At Epping Forest Horology Club we have a 'fleet' of S&B 'L' lathes and the required tooling,…we currently have a couple standing unused and there is a question mark over their future,…..just saying!
                              If there is no motor then that would be a very bad mark against that lathe as the massive 1 HP motor is kind of integral to the whole design…..other motors can probably be coerced into use but the originals were well designed for the purpose.
                              It's not generally well known but 'Bracehand' can supply some parts from new and still make collets to fit,…if you can afford the considerable price! In fact, Bracehand actually quoted some prices to us in 2013/4 for restoration of our 'L' models and included a new price of approx £14,000 per lathe, and basic restoration for £4,500 (if I recall)…..not surprisingly we decided to do much of our own restoration and re-built three machines.
                              The 'L' lathes were/are superb small parts machines and turn beautifully when run nicely. They are/were built to last three life times but you really do need some other lathe(s) to com[liment them if you are doing general turning.
                              #503566
                              old mart
                                @oldmart
                                Model A lathes are not cheap unless they are close to scrap, and you have to factor in the weight, 3/4 of a ton. 1024 models are even more expensive and heavier. The cost of a VFD of 1-2 kw to run one from single phase domestic power supplies is added expense.
                                #503590
                                larry phelan 1
                                  @larryphelan1
                                  What,s wrong with a new Chinese "junk" machine at half the price ?
                                  It,s new, no need to go hunting for parts, can be used right away and will do all you want it to do.
                                  OK, it may not be a "Cult" machine, but so what ?, I bought one to begin with and am still using it 20 years down the line. I dont know about you, but I did not have either the time nor the skill to set about "Restoring" a clapped out lathe, I wanted something which worked and which I could use straight off.
                                  Regarding cost, there might not be very much in the difference and remember, you are not making parts for spaceships. If you are like most of us, many of your efforts will end up in your scrapbox !
                                  How do I know ? Ask me ! but it,s all part of the fun. Buy a lathe and get stuck in, remember
                                  SWARF IS BEAUTIFUL !!!!! [ Just a bit messy ]
                                  #503602
                                    In addition to what Larry has just posted, the myford is most certainly not the RR of the lathe world – it’s more like the Morris Minor of the car world, I would suggest. Works OK, can still get lots of parts (that are needed regularly?) and examples available range from desirable to worn out junk (that can be resurrected, if enough is spent on them).
                                    #503609
                                    Paul Doyle 1
                                      @pauldoyle1
                                      @Bob Stevenson, thanks for the reply. I'd be very interested to know more about the unused Mode Ls you have at the Epping Forest Horology Club. Can I send you a message?
                                      @larry phelan 1, I guess I'm a traditionalist or sentimentalist in some ways. I have a few old English cast iron woodworking machines that I have restored myself also.
                                      So not only do I love the quality of build of the older cast iron machines, but I also get tremendous satisfaction out of bringing these machines back to glory and keeping them going. It's not so much about the half the price either.
                                      @not done it yet, maybe not the same quality as a Rolls Royce, but definitely have built a fan base with a significant price tag – and as you mention, lots of parts available. Maybe they are over rated and overpriced.
                                      #518875
                                      MARK RIGG
                                        @markrigg57943
                                        Hello all .
                                        I have been interested in the comments and the various post regarding the S&B model `L` lathes . Over the past couple of years I have acquired I think, 4 of these machines in a variety of completeness and condition .
                                        I am currently using one which is a mixture from the collection of parts that I now have . Although it is basically a very useful bit of kit , it does have its limitations if you want to do some conventional turning or any screwcutting.
                                        I am planning to buy another machine which does have sliding and surfacing power feeds and screwcutting facility – possibly a model `A` or a model `M `. I will re- assemble a model `L` as a second operation machine with the capstan slide assembly fitted with a Coventry Die Head which I have .
                                        As others have commented , these machines are beautifully made and solid – but the base casing – that is so heavy and moving it is a real problem ! And the other potential problem is deciding what route to go as to converting the machine to single phase drive . The machine I am currently using is mounted on a wooden stand with a separate single phase motor and under- mounted pulley system – all works OK . I did manage to bore a large casting – quite a bit larger than the swing on the machine . I achieved this by carefully grinding out part of the bed – making a gap about 2“ long and able to swing about 10 1/2 “ diameter. I used the worst condition bed casting I had , but I got the job done !
                                        MARK RIGG
                                        BRIDGNORTH
                                        #518913
                                          As long as you don't want to screwcut, a plain lathe is OK. You certainly learn how to feed steadily. Having been made before the days of drastic cost cutting, a heavy machine is likely to be more rigid.
                                          If you can get the machine at sensible price (You mentioned Euros, don't forget the shipping / import duty costs! )
                                          And then a motor and drive arrangements have to be bought and set up.
                                          it may well be a satisfying first machine and learning aid, whilst you restore it. If it lacks graduated dials, you can make these, although you may need ingenuity or help in graduating them.
                                          Restoration can be part of the hobby
                                          I have used a little Loughborough plain lathe at The WaterWorks museum from time to time, and get on well with it. Prefer it to the big Colchester if truth is told.
                                          If the machine is in reasonable condition, you can make some accessories with it, such as a Centre Height Gauge Tailstock Die and Tap holders, Floating Reamer Holders and a Mandrel Handle. ( Very useful for producing threads with Taps or Dies ).
                                          All these will extend the range of work that can be done on the lathe. And in making them, you become more familiar with the lathe whilst you gain confidence and skill.
                                          Hope that you eventually find what you want, but don't bite off more than you can chew successfully with the knowledge, skill and facilities available to you..
