Boiler water level gauge background
Home › Forums › Locomotives › Boiler water level gauge background
  • #476425
    Bob H
      @bobh
      Hi, who can supply a background to go behind the boiler water level gauge on my 3 1/2” loco to make it easier to read?
      #1938
      Bob H
        @bobh
        Making level gauges easier to read
        #476489
        David Davies 8
          @daviddavies8
          Hi, you could make your own, a strip,mounted behind the gauge glass, painted white with diagonal black lines thereon is used on full sized locos. The water defracts the image of the diagonal line and so helps the viewer to see the level.
          hth
          Andrew Tinsley
            @andrewtinsley63637
            Plus 1 for that!
            Andrew.
            #476505
            duncan webster 1
              @duncanwebster1
              You can get glass tube with a line down the back, when it has water it looks that colour all across, I think it's called Schelbach
              #476509
              Bob H
                @bobh
                Yes it had a blue line glass fitted but the seals had perished were leaking and stuck to the glass. I almost got it out before it broke! I can only find plain glass replacements.
                #476513
                duncan webster 1
                  @duncanwebster1
                  what size and how long? I might have some spare
                  #476521
                  Paul Kemp
                    @paulkemp46892
                    Polly Models do red line glass in various sizes, that's very good.
                    Paul.
                    #476676
                    Bob H
                      @bobh
                      The holes in the gauge nuts are 4.4mm and in the fittings 4.8mm. The old glass measured 4.18mm so I guess it was nominally 3/16”. This model being from Clarksons is all in imperial.
                      #476686
                      Paul Lousick
                        @paullousick59116
                        The glass which I purchased for my engine has a red line painted on the back which works well but needs a white background behind the glass to see the level in low light.
                        My preference though is for clear glass and a white background with red or black diagonal lines which is what we use on full size engines. The angle of the lines is inverted as light passes thru the water.
                        Paul.
                        #476696
                        Nick Clarke 3
                          @nickclarke3
                          All the blue glass tubes appear to have had the line and white background deposited on the glass during manufacture.
                          Would I be wrong in assuming a blue line quite literally painted on would work?
                          #476848
                          Paul Lousick
                            @paullousick59116
                            Give it a go Nick, nothing to lose. Those that I bought have a red line in the middle and a white line on each side but a single painted line would probably be OK.
                            Also a white reflector as shown in my previous post as they are hard to see in dim light without it.
                            Paul.
