Standard dead length Crawford collets
Home › Forums › Workshop Tools and Tooling › Standard dead length Crawford collets
  • #407674
    Pete.
      @pete-2
      I've been searching for some collets for my Portmac miller, Lathes.co describes them as 'standard dead length 1.5" crawford collets' that range in size from 1/8 to 1/2,
      I've not managed to find any from this description, am I searching the wrong thing? are these style given an 'F' designation of some description that I need to search, any help much appreciated.
      #19330
      Pete.
        @pete-2
        #407677
          Peter,
          Have a browse through this album: **LINK**
          https://www.model-engineer.co.uk/albums/member_album.asp?a=39260
          Martin Connelly
            @martinconnelly55370
            Sorry about the scribbling on some pages. I didn't know at the time that it was going to be a useful historic document.
            Martin C
            #407707
              I didn't know it was your scribbling, Martin surprise
              … I had assumed it was defaced by the apocryphal "previous owner" angel
              Martin Connelly
                I think I gave a copy to Tony at lathes.co.uk Thought it would go well with his archives. That may be how you got a copy. I downloaded it and printed it off years ago but have not found it online since then.
                Martin C
                #407715
                  Posted by Martin Connelly on 04/05/2019 15:15:18:
                  Martin C
                  No Martin, I got it directly from you [as PDF, if I recall correctly] and I converted it to jpg for this forum.
                  You are duly credited at the bottom of my album page.
                  I'm sure you can find our original conversation if you look.
                  Your eMail 16/12/2015 at 08:06
                  Edited By Michael Gilligan on 04/05/2019 15:27:08
                  #407716
                  Martin Connelly
                    I have obviously forgotten about it, I'll put it down to age and time passing.
                    Martin C
                    #407717
                      Pete.
                        @pete-2
                        Hi, thanks for the replies, but unfortunately I can't find anything on there that matches the description on lathes.co
                        #407776
                          Peter,
                          Try this catalogue: **LINK**
                          http://www.rotagriponline.com/datasheets/5C.pdf
                          .. ignore the 5C file-name !
                          Pete.
                            @pete-2
                            Posted by Michael Gilligan on 05/05/2019 07:21:40:
                            Peter,
                            Thanks again, I did actually come across that in my search before, they all seem to be larger than what the machine needs, I was speaking to Tony at Lathes.co a few weeks ago about this mill, I said I'd send him some photos of the machine when it's restored for his site, so I messaged him today to see if he can put any light on the collet situation.
                            #407891
                            Pete.
                              @pete-2
                              I received a msg back from Tony, he said if you find any, buy them all and trade duplicate sizes with others etc, others? I think I've only seen 2 others for sale, ever, which basically makes me think hen's teeth.
                              However, had a rummage through some collets I have, found some Schaublin F16 collets that appear almost identical in some aspects, they are a 15 degree taper, from the links you provided for Crawford, their dead length collets also use a 15 degree taper, the part that protrudes through the collar is the same size, the widest part of the taper is the same, I've tried checking the original collet, but it impossible to tell with 100% certainty using my protractor.
                              Down side, the collets are a bit too long, not much, might only need shortening 3/4 mm
                              You'll see on the photos, the polished back end on the Schaublin collet is slightly too wide to fit in the bore, but again not much, I measured the top of the bore inside the spindle, and it's 15.6mm, the Back end of the Schaublin collet is the thickest part at 16mm,
                              what I'm thinking, shorten the Schaublin collets about 4mm, while the machine is stripped down, take a small amount off the inside of the spindle bore, the original collet never went this far up anyway,
                              What the general consensus on the the original being a 15 degree taper, does anyone know if Crawford would have used this on a 1950ish British machine?
                              Original on the left,
                              Below, the original collet in the Collar.
                              Below the Schaublin F16 collet in the Collar
                              Below the 2 collets.
                              #407905
                                Posted by Peter F on 05/05/2019 23:48:39:
                                Ahh … That sort of 'Standard' devil
                                Thanks for posting the follow-up … and good luck
                                  Crawford was a Collet maker … so would have made 'anything and everything'
                                  Bespoke items for one machine were 'adopted' by others, and some became de facto 'standards'
                                  You probably need to find what other machines used this 'standard' … and then search old catalogues to confirm the design dimensions.
                                  Edited By Michael Gilligan on 06/05/2019 06:35:37
                                  #408025
                                  Pete.
                                    @pete-2
                                    Posted by Michael Gilligan on 06/05/2019 06:26:12:
                                    Having a think, I'd rather not alter the machine itself as this was more about restoring a rare old machine designed by a model engineer, than creating a machine I need to use.
                                    so I've thought if I shorten the schaublin collets say 4mm, I can hold the collet in the lathe somehow, and turning very very slowly, use an ezelap credit card periodically press on the polished thicker end of the collet, to lap it so it will fit, I only need to take off 0.2mm to bring it down to the same OD as the original Crawford collet, and it's only the shiny part, the black part on the schaublin collet is smaller OD than the Crawford.
                                    I used this method to deburr a B16 drill spindle with good results.
                                    #565567
                                    AJAX
                                      @ajax
                                      Posted by Pete. on 03/05/2019 22:14:52:
                                      Pete,
                                      I hope you don't mind me resurrecting such an old post but did you ever make any progress with finding any of these "standard" collets? I now have a Portmac miller and so maybe we should start an owners club.
                                      Out of interest, what motor do you have on yours? I'm tempted to change to 3 phase with VFD (that's what I have on everything else) but may possibly stick with the Servis (I think) motor that's on there now.
                                      Brian
                                      Brian
                                      #565580
                                      Pete.
                                        @pete-2
                                        Hi Brian,
                                        Unfortunately I had to sell mine to make some space, If I remember correctly I put 1/3hp motor on it, a 3 phase and vfd would be a better option.
                                        I never found any second hand collets for sale as I presume anyone who owned any probably had no idea what they were so the chances of finding any are non existent.
                                        I did find somewhere that would make these collets to order, D & J Workholding, hope this helps
                                        #565583
                                        AJAX
                                          @ajax
                                          Posted by Pete. on 04/10/2021 23:12:26:
                                          Hi Brian,
                                          Thanks for your reply, Pete. I have three collets (1/4, 3/8 and 1/2&quot so it will get me by for the moment. I'm guessing custom made collets would cost more than I paid for the machine and all the tooling it came with.
                                          #565584
                                          AJAX
                                            @ajax
                                            Posted by AJAX on 04/10/2021 23:21:04:
                                            Hi Brian,
                                            Thanks for your reply, Pete. I have three collets (1/4, 3/8 and 1/2" ) so it will get me by for the moment. I'm guessing custom made collets would cost more than I paid for the machine and all the tooling it came with.
                                            #565590
                                            Pete.
                                              @pete-2
                                              The cost was £50 each, so not too bad for small number made to order tooling, but not cheap.
                                              If you're not bothered about originality, you could have somewhere with a cylindrical grinder change the spindle bore to an ER collet maybe, just an idea.
                                              #565593
                                              jimmy b
                                                @jimmyb
                                                Pete,
                                                I'll email you a copy of the Crawford catalogue from back in the day.
                                                I've sent a PM
                                                Jim
                                                #565594
                                                AJAX
                                                  @ajax
                                                  Posted by jimmy b on 05/10/2021 05:36:36:
                                                  Pete,
                                                  I've sent a PM
                                                  Jim
                                                  Hello Jim,
                                                  If you've sent a personal message then I'm unable to find it. I've checked my inbox.
                                                  Brian
                                                  #565863
                                                  Pete.
                                                    @pete-2
                                                    Hi Jimmy, Thanks very much for the thought, I've actually sold my machine, It's Brian above now in the same dilemma.
