“Skidproof” screwdriver
Home › Forums › Workshop Tools and Tooling › “Skidproof” screwdriver
  • #289502
    OuBallie
      @ouballie
      Maples & Sons
      6.1/2" long with a nice wood handle and unusually ground blade.
      Ibe never seen one ground in this fashion, hollow ground yes.
      Marples & Sons
      Marples & Sons
      Marples & Sons
      Marples & Sons
      Marples & Sons
      Geoff – The whole family has a horrible head cold
      #18458
      OuBallie
        @ouballie
        Marples & Sons
        #289601
        Chris Evans 6
          @chrisevans6
          I have one of those, it was my Fathers. He always called it a cabinet screwdriver. I must search the boxes and find it. I still have his Marples wood chisels, they keep a superb edge.
          #289672
          Colin Heseltine
            @colinheseltine48622
            My father always taught me to hollow grind the blade of screwdrivers. They always lock into the slot in the screw, rather than use the taper of the blade to twist out of slot.
            Colin
            #289680
            KWIL
              @kwil
              = London Pattern woodworker's screwdriver.
              #289681
                Posted by KWIL on 20/03/2017 17:09:45:
                London pattern usually has an all flat blade and flats on the handle too. Also usually in the larger sizes
                Whoever said cabinet screwdriver had it right
                #289684
                Phil P
                  @philp
                  Am I seeing the blade hollow ground cross wise and not lengthwise as is more common.
                  I think this is the point the OP was trying to make, we have all seen hollow ground ones done lengthwise, but I have not seen one ground like this before.
                  I would be interested in seeing a photo of the tip end on.
                  Phil
                  Edited By Phil P on 20/03/2017 17:19:25
                  #289688
                    "Skidproof"? Get a "posi-drive" and use modern screws! I know, I know – they are not as aesthetic as slotted brass. And cheap screws and screwdriver tips are rubbish.
                    All 'proper' screwdrivers (cabinet makers, gunsmith etc) called them something else. Turnscrews was the name and many were made to fit their own bespoke slotted screws.
                    Ordinary screwdrivers likely did not need to be precise – especially after the invention of the Birmingham type – along with soft steel screws which were made for single use only!
                    The only good thing going for slotted screws is that paint is more easily removed from the slot than posi or torx, etc.
                    If you can easily file the screwdriver tip parallel, it is probably carp quality. Tips for 'lectric screwdrivers usually have parallel tips, btw.
                    Who is now going to make a quality screwdriver, like yours, and expect it to sell these days?
                    #289690
                    Ian P
                      @ianp
                      Posted by Phil P on 20/03/2017 17:18:21:
                      Phil
                      I too am curious how the skid resistance is achieved?
                      I recall seeing screwdrivers some time ago that had fine 'serrations' across the driving faces of the tip that were supposed to stop the blade sliding out of the ends of the slot. Not sure what the manufacturer described them as, but think it was 'anti-skid'
                      Ian P
                      #289691
                      Jon Gibbs
                        @jongibbs59756
                        Posted by not done it yet on 20/03/2017 17:27:45:
                        …there are still some purists about.
                        Jon
                        #289692
                          Modern take on the nonslip screwdriver
                          #289832
                          Ian S C
                            @iansc
                            I have seen small containers of diamond grit in a paste for use on the tip of ordinary screwdrivers to prevent slipping.
                            Ian S C
                            #289866
                            OuBallie
                              @ouballie
                              Blade not hollow ground.
                              Marples & Sons
                              Side view of handle
                              Marples & Sons
                              Front view
                              Marples & Sons
                              Given up on getting that video uploaded for now.
                              Geoff – %^*+ computers!
                              #290017
                              OuBallie
                                @ouballie
                                Oh, just noticed a milestone for me.
                                I've passed 1000 posts without noticing.
                                Been very very lax of late, so time to either update my car thread, or start a general one showing progress on the Austin.
                                Geoff – Thoughts please, Yes or No.
                                #291300
                                  Geoff,
                                  Yes go on and show/tell us about you progress on the Austin.
                                  Now, with longer days and better weather, you have no excuse!
                                  Put us armchair engineers to shame.
                                  having just upgraded the computer, know EXACTLY what causes high blood pressure.
                                  Would "Hit Any Key When Ready" if I could find a big enough hammer!
                                  #291338
                                    @mike89748
                                    Time was when, for working on shotguns, I always used to make my own screwdrivers. Then I got lazy, and used to buy good ones from Britool or Snap-on. Now I just buy the best Chinese make I can find. The thing is, I always re-grind the points to hollow ground, no matter what they are to be used for.. When working on finely-engraved gun actions, you just can't allow a screwdriver to jump out of its slot, or you could cause hundreds, or even thousand poundsworth of damage. When working on stuff like this it makes sense to re-grind a screwdriver to fit an individual screw. I just can't think why all screwdrivers aren't supplied with hollow-ground points. Screwdriver bits for electric screwdrivers are, in my experience, always hollow ground – not that anyone would be daft enough to use an electric screwdriver on a shotgun.
                                    OuBallie, let me echo Howard Lewis's comment – you do put us armchair angineers to shame!
                                    #291351
                                    Enough!
                                      @enough
                                      Posted by Jon Gibbs on 20/03/2017 17:32:36:
                                      Or this
                                      #291353
                                        Posted by Bandersnatch on 31/03/2017 01:56:12:
                                        Or this
                                        Mmm … Interesting
                                        Must confess, I don't recall seeing that suggested before
                                        [ burnishing "little hooks" on the tip of the blade ]
                                        Edited By Michael Gilligan on 31/03/2017 07:16:40
                                        #291385
                                        Russell Eberhardt
                                          @russelleberhardt48058
                                          Posted by Michael Gilligan on 31/03/2017 07:15:33:
                                          Mmm … Interesting
                                          I suppose the sideways grinding on Geoff's screwdriver is intended to have the same effect.
                                          Russell.
