Aluminium cylinder blocks
Home Forums Locomotives Aluminium cylinder blocks
Viewing 25 posts - 1 through 25 (of 26 total)
  • #413184
    John Rutzen
      @johnrutzen76569
      Hi, I"d like to know if anyone has any knowledge of using light alloy for locomotive cylinder blocks. My reason for asking is that I want to reduce weight as much as possible to avoid having a front heavy locomotive. The loco in question is the Webb compound Jeanie Deans. On another thread I've been getting a lot of input on this loco so I am not asking for info about it but someone who is building one commented on how front heavy it was with the big cylinder up front. I remember reading an article by Neville Evans on one of his locos some years ago and he suggested light alloy cylinder blocks with cast iron liners. i don't know if he ever tried it. I have lots of alloy blocks so i have the material for nothing at hand. The problem as I see it would be how to manage the port face. I don't know if the alloy would wear satisfactorily or if it would be necessary to let in a piece of iron in which case how could it be made steam tight? I thought of loctite and I have used this satisfactorily to put liners into blocks. I don't know about sealing a flat surface though especially with the differential expansion.
      #1828
      John Rutzen
        @johnrutzen76569
        #413188
        Roger Clark
          @rogerclark
          Would there be any wear considering the input of steam oil?
          Roger
          #413201
            If you used a liner in the bore and milled a recess for an iron or bronze plate into the port face you could let that take all the wear. Seen it done a few times to rescue castings where the ports were cut or cast badly.
            #413208
            John Rutzen
              @johnrutzen76569
              Yes, I intended to use an iron liner for the bore but I couldn't think of how to bond the port face plate except using Loctite and I don't know whether I would get steam leakage from the inlet to exhaust. The valve chest bolts could hold it all together.
              #413214
              Anonymous
                It seems a lot of work for possibly not much gain. I'd be inclined to do the maths to work out the saving before committing to metal. It might be better, and easier, to remove excess material from the original cylinder block. At least the cast iron cylinder removes potential problems due to differential expansion. The coefficient for aluminium is more than twice that of steel.
                #413222
                  I've driven this 4" McLaren which has the CI plate retained to the CI cylinder with Araldite and a few CSK screws, JB Weld would be another option.
                  I have done a few IC engines where the iron liner is just retained with Loctite in the cast aluminium cylinder and a few machined from solid aluminium too.
                  #413319
                  John Rutzen
                    @johnrutzen76569
                    Hi, I don't have any cylinder castings so it's not as if I'd be wasting any. Looking at the drawings it looks a definite possibility and it would reduce the weight a great deal. Jason do you mean you have used aluminium without a liner in a I.C. engine?
                    #413336
                    duncan webster 1
                      @duncanwebster1
                      Posted by Andrew Johnston on 08/06/2019 09:06:35:
                      This makes more sense to me, I've seen quite a few cylinder blocks machined form solid but with all superfluous material machined away. I suspect this would finish up lighter than a composite setup.
                      Anyway as most model locos are light on their feet, can't you just put a big lump of lead at the back end?
                      #413339
                      David Taylor 4
                        @davidtaylor4
                        My late friend , Bob Darby, made several Simpexes using aluminum cylinder blocks cast from old I/C pistons. He used standard I/C piston rings running in the aluminum bore. It work fine. He reasoned the conditions in a wet steam cylinder bore were not as severe as an I/C engine, If you want to be really fussy anodize the bore.
                        Dave Taylor
                        #413341
                        Old School
                          @oldschool
                          A possible solution is to have the bores and the valve area hard chrome plated, like the high performance model aircraft engines. The challenge would be finding someone to do it.
                          #413346
                            Posted by John Rutzen on 08/06/2019 21:18:31:
                            No, Cylinders either from cast or solid aluminium, both with CI liners.
                            Though if you are going to have to make your own cylinders anyway then you may as well machine a lightweight one from CI or fabricate from Bronze. You should be able to keep flange thicknesses reasonably thin and the cylinder wall too which will go some way to compensating for any perceived excess weight. As Duncan says most models lack tractive weight so just put the ballast towards the rear which will stop it being front heavy.
                            Can you post a photo or scan of the bit of drawing that shows the cylinders?
                            #413349
                            FMES
                              @fmes
                              As traction is affected by weight I would be more tempted to balance the light back end with additional lead.
                              Just a thought
                              #413358
                              John Rutzen
                                @johnrutzen76569
                                Hi, thanks for all the input. I want to keep the weight down also to make it easier to manhandle. When you get over 70 lugging heavy locos in and out of a small car boot on your own isn't easy or a good idea. So I won't be adding lead. I have Don Young;s articles from the '70;s on constructing fabricated cylinders and if they were piston valve that would be the way to go. David, do you know how the Simplexes lasted long term? I don't know what alloy I have but it is 2 inch thick blocks and machines beautifully.
                                #413396
                                duncan webster 1
                                  @duncanwebster1
                                  Emma Victoria described by Henry Wood in ME had fabricated slide valve bronze cylinders
                                  #413410
                                  Phil Whitley
                                    @philwhitley94135
                                    I am not a steamie or a Smee, but what about aluminium bronze, good wear and corrosion resistance, light, and although expensive, you could make your own aluminium/copper alloy.
                                    #413427
                                    David Taylor 4
                                      @davidtaylor4
                                      Hi John,
                                      No, I have lived abroad for many years and lost touch with those who might know. The locos certainly worked well initially and gave no signs of cylinder problems.
                                      Aluminium comes in so many grades and conditions that it is not possible to guess what it's composition might be from machinability or visual examination.
                                      As far as differential expansion between the aluminum cylinder and steel or cast iron or bronze piston the main problem would probably be leakage because the aluminum bore would expand more than a steel piston head.
                                      Referring again to I/C practice, aluminum pistons in aluminum bores with cast iron piston rings work very well and there is no reason the same material combinations should not work in a low pressure, well lubricated steam cylinder. Anodizing provides an extremely hard surface which should be wear resistant.
                                      duncan webster 1
                                        @duncanwebster1
                                        Posted by Phil Whitley on 09/06/2019 13:23:19:
                                        very little difference in density and an absolute pig to drill and tap. Stick to bronze but machine away as much as possible if you want it light
                                        #415084
                                        Nigel Graham 2
                                          @nigelgraham2
                                          I can understand wanting to reduce weight for transport reasons, but is the locomotive really front-heavy? I'd be very surprised, since considered just as a dead-weight the cylinders would be balanced very much by the firebox.
                                          Looking at photos of this loco, it seems already rear-heavy by having the cylinders behind the smoke-box and leading wheels, with the much of the load including the cylinders carried on the rearwards-set coupled wheels.
                                          I would think its weight is quite well balanced, but on a miniature, aluminium cylinders might not be significantly lighter than bronze or cast-iron ones with excess metal cut away; as part of the loco's total weight..
                                          Besides, the loco needs to be heavy for adhesion.
                                          #415088
                                          old mart
                                            @oldmart
                                            Get the bores hard anodised and ground, probably a costly option but better than chrome which would also have to be ground.
                                            #415349
                                            David Taylor 4
                                              @davidtaylor4
                                              I don't think hard anodizing needs to be ground. The layer is very thin but very hard. I suspect it is so thin as to make grinding impractical.
                                              My experience is that it is not so expensive if you can find a firm to do it.
                                              #415452
                                              old mart
                                                @oldmart
                                                Hard anodising certainly does require grinding.
                                                #415480
                                                David Taylor 4
                                                  @davidtaylor4
                                                  I don't think so.
                                                  My experience of using it is that it is so thin as to make grinding nearly impossible without removing it completely.
                                                  If using 'O' ring seals, which would be a good idea, there is no need to grind the bore for either hard chrome or anodizing as the fits are not that close.
                                                  Very light lapping of either finish, with a very fine abrasive, is the most that may be required.
                                                  #415484
                                                  David George 1
                                                    @davidgeorge1
                                                    I have used hard anodising in tooling for plastic injection tooling and on disc breaks on racing motorcycles to reduce weight. You can get it done local to where I live and they also do PTFE coating on hard Anodising. There is no need to grind after treatment but there is a build up and that should be taken into account they will tell you the amount but it would be between 0.002 " and 0.005 ". Mansfield Anodisers Ltd. There may be other anodisers local to you.
                                                    David
                                                    #415708
                                                    old mart
                                                      @oldmart
                                                      1. My experiance of hard anodising is only with aircraft components which are produced to higher specifications than usual. My firm used to make uplocks for Airbus landing gear which had hydraulic actuator cylinders with a bore of about 3/8". The anodising was about 0.002" thick and was ground in house to a mirror finish, the unground ends of the cylinder were smooth, but not as good a finish as the bores. These pictures are of a hard anodised and ground tube which the swashplate spherical bearing slides up and down on for a helicopter. Possibly, a Bell Jet Ranger. The grinding may be visible in the photos. The diameter is about 4"._igp2394.jpg_igp2395.jpg
                                                      Edited By old mart on 23/06/2019 12:06:09
