Myford ML7 spindle internal taper/counterbore?
Home › Forums › Manual machine tools › Myford ML7 spindle internal taper/counterbore?
  • #284162
      Just looking over the world's most abused lathe that I recently picked up at a garage sale, an ML7, and noticed that the 2MT internal taper in the headstock spindle does not start at the very front of the spindle. It is counterbored parallel for almost an inch and then the 2MT taper starts. Seems a bit odd as any centre used in the headstock spindle is then sticking out almost an inch from the taper before it even starts to poke out to where it can be used. Not a great set up, one would think, with all that extra overhang.
      Question is: Is this the standard Myford set-up with the first inch or so of the bore parallel? Or has the abusive previous owner poked a boring bar down the spindle at some stage of its unfortunate career?
      Edited By Hopper on 14/02/2017 12:56:43
      #12898
        #284169
        roy entwistle
          @royentwistle24699
          The taper should start at the end of the bore, nothing parallel
          Roy
          #284205
            Ha ha, maybe the abusive previous owner needed to mount something longer than the bed?sad ie from tailstock centre to back of chuck was not quite enough…. Or perhaps fell asleep while taking a cut on a job and was using a boring bar an Iinch and a half longer than needed?smiley
            This thread should be in the 'tool abuse' thread!
            Edited By not done it yet on 14/02/2017 15:24:59
            #284222
            Brian Oldford
              @brianoldford70365
              New spindle or the bay I'd hazard.
              #284225
              John Stevenson 1
                @johnstevenson1
                No it’s not. Out on site at moment so post later but now you have the chance to drag the design kicking and screaming into the 19th century
                #284235
                  Is the design that old! Would that be early or late 19th century, John? Err, 1810 or 1890 … ish?smiley
                  #284237
                  Nick_G
                    @nick_g
                    Posted by not done it yet on 14/02/2017 17:49:55:
                    I think John was being nothing more than flippant and tongue in cheek. smiley
                    Nick
                    #284254
                    daveb
                      @daveb17630
                      Might be an ex school lathe, the little boys could work wonders with a boring tool. It's not too bad though, they usually bored the spindle nose away so the chuck fell off.
                      #284306
                      John Stevenson 1
                        @johnstevenson1
                        Could be long – go get a coffee or a drink of tea and anyone of a mild disposition or who has Myford grey in their veins might do better to log off..
                        First off and this is just my take on it the only reason for the MT2 in the spindle nose is to run work between centres but the smart set can still do this by leaving the 3 jaw chuck on, placing a bar in the chuck and turn a centre on it and provided that you don't remove said bar then it will run perfectly true and you can use one of the jaws to drive the carrier. Nothing new, people have been doing this for years.
                        So this is a spare head stock off a ML7 with a MT 2 drill fitted to give an idea of where and how it goes..
                        Now this is an ER20 collet offered up to a reasonable decent spindle.
                        And the two compared.
                        As you can see the thick end of the ER20 is bigger than the MT2 but the small end is smaller than that part of a MT2.
                        However all is not lost. Seeing as out intrepid hero, Hooper has got a stuffed up spindle to start with he's nothing to loose.
                        So for your perusal here is a CAD [ clown assisted drawing ] of the spindle with bits superimposed.
                        Going from left to right in the centre we start off with a nominal 9/16" clearance hole as fitted as standard, this then develops into the MT2 and super imposed on this is the ER20 collet, all drawn to scale.
                        The ER 20 at the fat end is believe it or not 20mm diameter, so if the spindle was bored to say 22mm diameter for a depth of 1" and a slug of steel pressed and loctited in, then bored in situ at 8 degrees half included angle to accept an ER20 collet, all that is left is to make a new collet nut but with a 1 1/8" x 12 Whit form thread.
                        Job done and you now have a useful size collet system that can hold any size from 0.5mm up to 13mm.
                        #284316
                        Nick Hulme
                          @nickhulme30114
                          John,
                          That's far too logical and will never catch on
                          I haven't stripped and had The Clown draw my ER40 roller bearing S7 head so I can't yet provide details for and suggest that as an alternative 😀
                          Edited By Nick Hulme on 14/02/2017 23:57:26
                          #284318
                            Now, that's a darn good idea. Thank you Mr Stevenson. Instead a piece of abuse it may turn out to be an improvement after all, with a little judicious fettling! I like the idea of the ER20 collets a lot — they are cheap as chips to buy online, even the good ones.
                            And as you say, who ever uses the MT2? In the Mighty Drummond, I always do as you describe and use a soft centre held in the three jaw and have a couple of drive dogs made up that fit very nicely around the jaws without slapping about. I found that trying to use the "correct" live centre and catchplate leaves too much of the job over the gap in the bed and so the carriage is too far away from it for practical use.
                            I was planning on using the MT2, though, for seating a homemade testbar to check headstock alignment when I scrape the headstock bearings in but there are other ways to skin that cat — turned bar in three jaw etc — so that's not a huge problem. And there is probably enough MT2 left in the spindle to get a seating good enough for initial alignment check anyways.
                            And I remember distinctly thinking when I pulled the spindle out of the all pulleys and gears mounted on it that finally, finally I had found a piece on this lathe that does not have hammer or chisel marks on it, or other signs of abuse. So I can honestly say now that every single part of this machine bears some sign of abuse! There are even chisel marks on the pulleys.n The electricians have a lot to answer for.
                            I'll measure up the counterbore in the spindle and see how it sits for adding collets.
                            #284549
                              Interesting. After I removed the honking great burr from the mouth of the counterbore, it measured up at exactly .750" diameter by .760 deep and appears to have been bored and either honed or emery papered to a nice finish. So pretty easy to sleeve and bore to fit ER collets as suggested.
                              Incidentally the burr on the end was a mystery — until I noticed the circular grooved gouged out of the end of the spindle. It looked kind of familiar. Just like the gouges in the face plate. Put them together and sho' nuff, whoever grooved up the face plate managed to get one groove spot on the end of the spindle nose. Must have been a dead blunt tool from the burr it threw up. I just can't for the life of me imagine what they were doing that caused those grooves. It obviously was not a one-time whoopsie but more of a SOP over a long period.
                              The counterbore is clearly visible in the lower pic, as is the groove in the spindle nose.
                              Edited By Hopper on 16/02/2017 06:35:09
                              Edited By Hopper on 16/02/2017 06:44:24
                              Edited By Hopper on 16/02/2017 06:46:37
                              #284550
                                Posted by daveb on 14/02/2017 18:57:47:
                                No this one has professional-strength abuse all over it. The spindle bore is almost nothing by comparison to the hammer marks on the bed, ten thou slack in the headstock bearings, carriage so worn it has given itself a "wide guide" conversion by wearing down the narrow guide so far the rear surface has been rubbing on the rear shear. It was used in an electric motor reconditioning workshop. If you have ever seen how electricians use hand tools (multigrips and screwdriver to do everything) you may have some idea what this poor lathe went through. A few more details of its sad life are here **LINK**
                                #284700
                                Mark Rand
                                  @markrand96270
                                  I guess this counts as an 'ex-college machine, with little use' crying 2
                                  #284702
                                  John Stevenson 1
                                    @johnstevenson1
                                    Hopper,
                                    Sorry I spelt your name wrong in my post.
                                    If you are doing the ER 20 conversion you will have to bore out to 20mm plus to get the collet in.
                                    [Edit] No forget that it won't matter, too late at night here and any size will do it's just that there will be a transition line somewhere along the ER taper which won't matter anyway.
                                    The ML7 spindle is quite a simple piece of turning in a non exotic steel, I believe they used EN8 left soft on the white metal version and onece you are at this stage it would not be a lot more work to make a new spindle, with a flange.
                                    D1-3 would be well overkill for a 3 1/2" lathe but a straight stepped flange similar to the Chinese C3, C4, C6 series lathes with a simple shoulder, no taper, would be very easy to replicate.
                                    It would give you safe reversing, a source of cheap back plates and chucks.
                                    Fitting is also very easy.
                                    Stolen from the Mini late site of a review on the Sieg SC8 lathe.
                                    The rotating plate has three keyhole-shaped holes that rotate through about a 15-degree arc. After the nuts on the studs pass through the large end of the keyhole, the plate is rotated to bring the small end of the keyhole into place. Then the nuts are tightened down on the plate to lock the chuck securely in place.
                                    One advantage of this system is that you don't need to hold the heavy chuck in place with one hand while using the other hand to attempt to get the nuts in place in the limited space behind the spindle. Another advantage is that the nuts stay with the chuck, so are much less likely to get lost or to drop into the gap between the ways as you're trying to install them. A third advantage is that installing and removing the chuck is quicker.
                                    I have this system on my TOS with A1-4 chucks fitted, it's quick as the nuts always stay on the studs and it's impossible for them to vibrate loose as sometimes the D series camlock can under interupted cuts.
                                    #284706
                                      Certainly food for thought there JS. At this stage, shed time being very limited, the goal is to get to "Stage One" and get it cleaned up, inspected, painted and back together in a basic useable manner so I can see if I like using it as much as or more than the Mighty Drummond and make a decision on whether I keep it or not. Then if I decide to keep it I will make such mods as make it more useable.
                                      I like the idea of the flanged spindle and standard chucks, although the two chucks with it, original Burnerds, seem to be in good nick, especially the four jaw. The poor old faceplate seems to have been the preferred victim.
                                      Would the flange on those spindles just be pressed and loctited into position then machined true, or are they welded? (I'm sure the esteemed gentlemen in the Orient don't waste material machining them from the solid out of 100mm bar etc.
                                      #284707
                                        Posted by Mark Rand on 16/02/2017 23:33:54:
                                        Yes, the "College of Hard Knocks".
                                        #284708
                                        John Stevenson 1
                                          @johnstevenson1
                                          They start off as a forging, easy way to save money and material.
                                          #284711
                                            Posted by John Stevenson on 17/02/2017 02:27:23:
                                            Might be a bit beyond my workshop capabilities. Only forging I've done was my mother's signature on sick notes to school. But I suppose welded, stress relieved and machined would do the job.
                                            #284730
                                            Ian S C
                                              @iansc
                                              Hopper, I wonder if they used the face plate for cutting some form of gasket, or thin washer without using an expendable backing, that would give you the grooves.
                                              Ian S C
                                              #285272
                                                With the state of the Faceplate, pity that the lathe has not got Power Cross Feed! Although whatever the shortcoming of your hand feed might be, it will be nothing compared to what has gone before.
                                                Good work to be rectifying the brutality meted out by the former users.
                                                Stick at it!
                                                #285361
                                                Rick Kirkland 1
                                                  @rickkirkland1
                                                  Hopper, It appears there are two of these ML7's in the world. last night I was in The Shed and I was looking at one of the ML7's that are awaiting refurbishment and I noticed that the spindle on one of them is bored out in the end in an identical fashion to yours. The lathe has in fact been abused and I was told that it had been used mostly for cylindrical grinding. the fact that the threads on the leadscrew are nearly non existent seems to be testament to this. Still, , there's not much that can't be put right with a little time, effort and enthusiasm.
                                                  Rick.
