Boxford Lathe Rewiring
Home › Forums › Manual machine tools › Boxford Lathe Rewiring
  • #12817
    Brian H
      @brianh50089
      Adding a reversing switch and coolant facilities
      #266544
      Brian H
        @brianh50089
        With the very kind help of a fellow MEer, I have my Boxford lathe with reverse and coolant facilities.
        A much bigger job than anticipated as I'm more used to 3ph and am now on 1 ph.
        Useful in other ways as I found the primary drive belt about to break.
        #266561
        MalcB
          @malcb52554
          Just be very careful using reverse if its the screw on chuck model. Slow speed only else you will easily spin the chuck off.
          For its size they are a great lathe and are a very capable tool if its set up right.
          Enjoy.
          Malc
          #266571
          Brian H
            @brianh50089
            Thanks for that MalcB, I tend to wait until the chuck has stopped before reversing after my previous lathe with 3ph and wet plate clutch, spun off a 12" chuck through over enthusiastic reversing.
            I think it's worth leaving the comment on here as a warning to others.
